ae galera, to com esse problema e não to conseguindo resolver:
assim q abro o kde 3.3 ele da essa msg de erro:
o aplicativo SoundServer(artsd) terminou anormalmente e causou o sinal 11(SIGSEGV)
backtrace:
(no debugging symbols found)
Using host libthread_db library "/lib/tls/libthread_db.so.1".
[Thread debugging using libthread_db enabled]
[New Thread -1218128192 (LWP 7286)]
[KCrash handler]
#38 0xb7d072c2 in _snd_pcm_adpcm_open () from /usr/lib/libasound.so.2
#39 0x00000800 in ?? ()
#40 0xb795ae74 in ?? () from /usr/lib/libstdc++.so.6
#41 0x08100070 in ?? ()
#42 0xb7865808 in __malloc_initialize_hook () from /lib/tls/libc.so.6
#43 0x00000002 in ?? ()
#44 0x00000000 in ?? ()
#45 0x00000800 in ?? ()
#46 0xb7cb6b38 in ?? () from /usr/lib/libasound.so.2
#47 0xb7d53d33 in ?? () from /usr/lib/libasound.so.2
#48 0xb7cf2dcc in snd_pcm_mmap_begin () from /usr/lib/libasound.so.2
#49 0xb7863ff4 in ?? () from /lib/tls/libc.so.6
#50 0x00000002 in ?? ()
#51 0x00000002 in ?? ()
#52 0xb7203000 in ?? ()
#53 0x0008b53c in ?? ()
#54 0x00000000 in ?? ()
#55 0x00000000 in ?? ()
#56 0xb7d601b4 in ?? () from /usr/lib/libasound.so.2
#57 0x00001d66 in ?? ()
#58 0x080c3d48 in ?? ()
#59 0x080c3c90 in ?? ()
#60 0xb7d09e6d in _snd_pcm_adpcm_open () from /usr/lib/libasound.so.2
#61 0x00001000 in ?? ()
no /etc/modprobe.conf
# --- BEGIN: Generated by ALSACONF, do not edit. ---
# --- ALSACONF verion 1.0.8 ---
options snd device_mode=0666
alias snd-card-0 snd-ca0106
alias sound-slot-0 snd-ca0106
# --- END: Generated by ALSACONF, do not edit. ---
[[email protected] user]#lspci
05:04.0 Multimedia audio controller: Creative Labs SB Audigy LS
ao tentar executar artsd
[[email protected] user]# artsd
unix_connect: can't connect to server (unix:/tmp/mcop-root/localhost-35e0-42d3b1c4)
There are already artsd objects registered, looking if they are active...
... cleaned 5 unused mcop global references.
Segmentation fault
[[email protected] user]# rpm -qa |grep alsa
libalsa2-1.0.8-15mdk
alsa-utils-1.0.8-1mdk
libalsa-data-1.0.8-15mdk
[[email protected] user]# rpm -qa |grep arts
libarts1-1.3.2-6mdk
arts-1.3.2-6mdk
xine-arts-1.0-8mdk
To usando o kde 3.3 no mandriva 10.2 minha maquina: hp d325
Obrigado
