Salve meus amigos da LIsta!!!!!
Estave eu utilizando o SAMBA 2.0 e Fiz a migração para o SAMBA 3.0
Tudo esta funcionando perfeitamente.. Os usuarios acessam as pastas de acordo com as permissoes mas estou recebendo umas mensagens de log que nao consegui descobrir o por que .. Nem o mestre dos Magos GOOGLE foi capaz de me salvar desta vez---- As msgs sao as seguintes:
DETALHE ESTE IP 10.42.0.222 É DA MINHA PLACA DE REDE EXTERNA CUJO OS USUARIOS QUE ESTAO NELA NAO TEM ACESSO MINHA REDE INTERNA É 192.168.100.X
[2005/07/14 00:04:58, 0] nmbd/nmbd_browsesync.c:get_domain_master_name_node_status_fail(488)
get_domain_master_name_node_status_fail:
Doing a node status request to the domain master browser at IP 10.42.0.222 failed.
Cannot get workgroup name.
[2005/07/14 00:05:00, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(396)
Samba name server SERVER is now a local master browser for workgroup MAMATA on subnet 192.168.100.254
OUTRA MENSAGEM É EM RELAÇÃO AO PRINTCAP .... NAO SEI POR QUE APARECE ISSO POIS NO MEU SMB.CONF NAO TEM NADA QUE SE REFERE A IMPRESSÃO !
[2005/07/14 00:28:40, 0] smbd/server.c:main(798)
smbd version 3.0.14a-Debian started.
Copyright Andrew Tridgell and the Samba Team 1992-2004
[2005/07/14 00:28:40, 0] printing/pcap.ccap_cache_reload(149)
Unable to open printcap file /etc/printcap for read!
Alguém já passou por algo assim ou saberia me dizer por que isso ocorre... estou mandando meu smb.conf abaixo!!!!!!
GRATO DESDE JÁ!
#Sample configuration file for the Samba suite for Debian GNU/Linux.
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options most of which
# are not shown in this example
# Any line which starts with a ; (semi-colon) or a # (hash)
# is a comment and is ignored. In this example we will use a #
# for commentary and a ; for parts of the config file that you
# may wish to enable
# NOTE: Whenever you modify this file you should run the command
# "testparm" to check that you have not many any basic syntactic
# errors.
#======================= Global Settings =======================
[global]
## Browsing/Identification ###
# Samba Server Time for clients
time server = yes
# Change this to the workgroup/NT-domain name your Samba server will part of
workgroup = MAMATA
# server string is the equivalent of the NT Description field
server string = Servidor de Teste
# Ethernet Configuration Suport Samba
interfaces = eth0
bind interfaces only = Yes
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable its WINS Server
wins support = yes
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
; wins server = w.x.y.z
# This will prevent nmbd to search for NetBIOS names through DNS.
dns proxy = no
# What naming service and in what order should we use to resolve host names
# to IP addresses
; name resolve order = lmhosts host wins bcast
#### Debugging/Accounting ####
# This tells Samba to use a separate log file for each machine
# that connects
log file = /var/log/samba/log.%m
# Put a capping on the size of the log files (in Kb).
max log size = 0
# Do something sensible when Samba crashes: mail the admin a backtrace
panic action = /usr/share/samba/panic-action %d
####### Authentication #######
# "security = user" is always a good idea. This will require a Unix account
# in this server for every user accessing the server. See
# /usr/share/doc/samba-doc/htmldocs/ServerType.html in the samba-doc
# package for details.
security = user
# You may wish to use password encryption. See the section on
# 'encrypt passwords' in the smb.conf(5) manpage before enabling.
encrypt passwords = true
# If you are using encrypted passwords, Samba will need to know what
# password database type you are using.
smb passwd file = /etc/samba/smbpasswd
obey pam restrictions = yes
guest account = nobody
invalid users = root
######## TESTAR ESTA PARTE
# This boolean parameter controls whether Samba attempts to sync the Unix
# password with the SMB password when the encrypted SMB password in the
# passdb is changed.
# unix password sync = yes
# For Unix password sync to work on a Debian GNU/Linux system, the following
# parameters must be set (thanks to Augustin Luton <[email protected]ics.fr> for
# sending the correct chat script for the passwd program in Debian Potato).
# passwd program = /usr/bin/passwd %u
# passwd chat = *Enter\snew\sUNIX\spassword:* %n\n *Retype\snew\sUNIX\spassword:* %n\n .
# This boolean controls whether PAM will be used for password changes
# when requested by an SMB client instead of the program listed in
# 'passwd program'. The default is 'no'.
; pam password change = no
############ Misc ############
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
; include = /home/samba/etc/smb.conf.%m
# Using the dollowing lines enables the character equal your timezone
unix charset = iso8859-1
display charset = cp850
# Most people will find that this option gives better performance.
# See smb.conf(5) and /usr/share/doc/samba-doc/htmldocs/speed.html
# for details
# You may want to add the following on a Linux system:
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
# Configure remote browse list synchronisation here
# request announcement to, or browse list sync from:
# a specific host or from / to a whole subnet (see below)
; remote browse sync = 192.168.3.25 192.168.5.255
# The following parameter is useful only if you have the linpopup package
# installed. The samba maintainer and the linpopup maintainer are
# working to ease installation and configuration of linpopup and samba.
; message command = /bin/sh -c '/usr/bin/linpopup "%f" "%m" %s; rm %s'
# Browser Control Options:
# set local master to no if you don't want Samba to become a master
# browser on your network. Otherwise the normal election rules apply
local master = yes
# Domain Master specifies Samba to be the Domain Master Browser. If this
# machine will be configured as a BDC (a secondary logon server), you
# must set this to 'no'; otherwise, the default behavior is recommended.
domain master = yes
# Preferred Master causes Samba to force a local browser election on startup
# and gives it a slightly higher chance of winning the election
preferred master = yes
# OS Level determines the precedence of this server in master browser
# elections. The default value should be reasonable
os level = 65
# Enable this if you want Samba to be a domain logon server for
# Windows95 workstations.
; domain logons = yes
# if you enable domain logons then you may want a per-machine or
# per user logon script
# run a specific logon batch file per workstation (machine)
; logon script = %m.bat
# run a specific logon batch file per username
; logon script = %U.bat
# All NetBIOS names must be resolved to IP Addresses
# 'Name Resolve Order' allows the named resolution mechanism to be specified
# the default order is "host lmhosts wins bcast". "host" means use the unix
# system gethostbyname() function call that will use either /etc/hosts OR
# DNS or NIS depending on the settings of /etc/host.config, /etc/nsswitch.conf
# and the /etc/resolv.conf file. "host" therefore is system configuration
# dependant. This parameter is most often of use to prevent DNS lookups
# in order to resolve NetBIOS names to IP Addresses. Use with care!
# The example below excludes use of name resolution for machines that are NOT
# on the local network segment
# - OR - are not deliberately to be known via lmhosts or via WINS.
; name resolve order = wins lmhosts bcast
#============================ Share Definitions ==============================
[web]
comment = Area de compartilhamento WEB
path = /shares/disc0/web
browseable = yes
printable = no
public = no
create mask = 0664
directory mask = 0775
valid users = +webmaster
write list = +webmaster
# errors.
[global]
time server = yes
workgroup = MAMATA
interfaces = eth0
wins support = yes
dns proxy = no
# to IP addresses
# that connects
max log size = 0
security = user
# parameters must be set (thanks to Augustin Luton <[email protected]> for
# for details
local master = yes
domain master = yes
os level = 65
[web]
browseable = yes
printable = no
public = no
create mask = 0664
