  1. Amigo quanto inicio meu named ele da ok mais quando dou o nslookup accesspower.com.br da o seguinte erro
    server: 200.223.252.243
    adress: 200.223.252.243#53
    ** server can't find accesspower.com.br: SERVFAIL
    Agora vou por meus arquivos pra ninguem me xingar de novo.
    ------> NAMED.CONF
    // generated by named-bootconf.pl
    options {
    directory "/var/named";
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    version "[EF DNS SERVER]";
    query-source address * port 53;
    dump-file "/var/named/dump/named_dump.db";
    statistics-file "/var/named/dump/named.stats";
    allow-transfer { 200.223.252.243 ; };
    // memstatistics-file "/var/named/dump/named.memstats";
    // remove this next line if you want named to listen on
    // all available interfaces, or adjust add new ones as
    // you see fit
    listen-on { 200.223.252.243; 127.0.0.1; };
    // a caching only nameserver config
    zone "." {
    type hint;
    file "named.ca";
    zone "0.0.127.in-addr.arpa" {
    type master;
    file "named.local";
    zone "accesspower.com.br" {
    type master;
    file "accesspower.com.br.db";
    zone "252.223.200.in-addr.arpa" {
    type master;
    file "accesspower.com.br.rev";
    // a shared secret for the rndc tool
    // this key must be the same one that is in the
    // /etc/rndc.conf file
    key key_rndc {
    algorithm "hmac-md5";
    secret "k9uIPpgbI+lUL4MbjpGOlA==";
    // a control channel for the new rndc tool
    controls {
    inet 127.0.0.1 allow { localhost; } keys { key_rndc; };
    ------> NAMED.LOCAL
    @ IN SOA localhost. root.localhost. (
    1997022700 ; Serial
    28800 ; Refresh
    14400 ; Retry
    3600000 ; Expire
    86400 ) ; Minimum
    IN NS localhost.
    1 IN PTR localhost.
    ------> MEU DOMINIO ACCESSPOWER.COM.BR.DB
    accesspower.com.br. IN SOA ns1.accesspower.com.br. root.ns1.accesspower.com.br. (
    950000
    86400
    3600
    3600000
    3600 )
    accesspower.com.br. IN A 200.223.252.243
    accesspower.com.br. IN NS ns1.accesspower.com.br.
    accesspower.com.br. IN MX 5 ns1.accesspower.com.br.
    www IN A 200.223.252.243
    -------> MEU RESOLV ACCESSPOWER.COM.BR.REV
    252.223.200.in-addr.arpa. IN SOA ns1.accesspower.com.br. root.ns1.accesspower.com.br. (
    950000
    86400
    3600
    3600000
    3600 )
    252.223.200.in-addr.arpa. IN NS ns1.accesspower.com.br.
    1 IN PTR ns1.accesspower.com.br.
    Agradeço a todos que puderem e quiserem me ajudar ok.
  2. posta o /etc/resolv.conf
  1. DNS Correto Mais Reverso da Erro
    Por uoquisala no fórum Servidores de Rede
    Respostas: 11
    Último Post: 10-05-2006, 08:02
  2. Servidor Red Hat 9.0 Dá erro no Bind
    Por Hawthorn no fórum Servidores de Rede
    Último Post: 03-06-2004, 14:55
  3. cbq da erro
    Por bouncer no fórum Servidores de Rede
    Último Post: 10-02-2004, 14:11
  4. shapecfg - 2 interfaces dá erro
    Por vandemberg no fórum Servidores de Rede
    Último Post: 19-09-2003, 11:36
  5. Cdrw não consigo gravar da erro ?
    Último Post: 26-04-2003, 14:30
