    Digital_man
    Padrão Servidor DNS naum funciona
    Bom amigos segui um artigo indicado aqui no forum quando estarto o named ele da ok mais o servidor naum roda
    Uso um link da telemar e um servidor com o conectiva 10 compartilhando a net e nele que quero por o servidor de nomes.
    Aqui vai minhas configurações pra vcs me ajudarem.
    ARQUIVO NAMED.CONF
    // generated by named-bootconf.pl
    options {
    directory "/var/named";
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    // query-source address * port 53;
    dump-file "/var/named/dump/named_dump.db";
    statistics-file "/var/named/dump/named.stats";
    # memstatistics-file "/var/named/dump/named.memstats";
    // remove this next line if you want named to listen on
    // all available interfaces, or adjust add new ones as
    // you see fit
    listen-on { 200.223.252.243/32; };
    allow-transfer { 200.223.252.244; };
    transfer-format many-answers;
    // a caching only nameserver config
    zone "." {
    type hint;
    file "named.ca";
    zone "0.0.127.in-addr.arpa" {
    type master;
    file "named.local";
    zone "252.223.200.in-addr.arpa" {
    type master;
    file "200.223.252.rev";
    zone "accesspower.com.br" {
    type master;
    file "accesspower.com.br";
    ARQUIVO 200.223.252.REV
    $TTL 600
    @ IN SOA accesspower.com.br. root.accesspower.com.br. (
    2005051000
    3600
    900
    1209600
    43200 )
    @ IN NS accesspower.com.br.
    243 IN PTR accesspower.com.br.
    244 IN PTR accesspower.com.br.
    ARQUIVO ACCESSPOWER.COM.BR
    $TTL 600
    2005062000 ; serial;
    3600 ; refresh
    900 ; retry
    1209600 ; expire
    43200 ) ; default_ttl
    @ IN NS ns1.accesspower.com.br.
    @ IN NS ns2.accesspower.com.br.
    @ IN MX 5 ns2.accesspower.com.br.
    ns1.accesspower.com.br. IN A 200.223.252.243
    ns2.accesspower.com.br IN A 200.223.252.244
    www IN CNAME ns1.accesspower.com.br.
    ftp IN CNAME ns1.accesspower.com.br.
    pop IN CNAME ns2.accesspower.com.br.
    smtp IN CNAME ns2.accesspower.com.br.
    ARQUIVO RESOLV.CONF
    domain accesspower.com.br
    nameserver 200.223.252.243
    ARQUIVO HOSTS
    127.0.0.1 localhost.localdomain localhost
    200.223.252.243 cascata.accesspower.com.br cascata
    Esta e minha configuração ele sobe legal mais quando dou um nslookup ela da SERVFAIL.
    mininumal
    deve ter algum erro ao subir o server
    qual sua distribuicao de linux ? e cole o erro gerado por ele no syslog.
    suspeito q vc deva estar com problemas de privilegio de usuario .... normal ter este erro
    Padrão DNS
    Citação Postado originalmente por mininumal
    Uso Conectiva 10
    So naum achei o Syslog??/
    psybox
    #cat /var/log/syslog >> ~/syslog.log
    Abra com seu editor preferido o ~/syslog.log e procure pelos erros.
    Tudo bem... Vou dar um palpite (É palpite porque implementei um servidor Bind aqui, nunca havia usado este servidor DNS, com auxilio do WEBMIN para saber quais eram os arquivos que ele usava, e onde gravava, e instalei numa boa - Tá funcionando que é uma beleza!)
    Como eu num sei muito Linux, vou pelo mais simples e vou complicando, testo, se funciona, eu continuo, senão, eu desfaço e tento novamente. Mas o Bind é super simples, gostei dele: Acho uns dos servidores mais legais do Linux.
    Minha distro é Conectiva 10, tbém: Se vc quiser tentar pelo be-a-ba como eu fiz:
    Instalei via Synaptic o Bind que estava na distro:
    rodei o Webmin e defini a minha zona, coloquei os registros que precisava.
    Certifiquei os caminhos dos arquivos criados se tudo estava apontado direitinho:
    Iniciei o servico
    E agora ele é um Servidor DNS apontado na Fapesp Funcionando, leve, é muito bom!
    Adiós!
    eae
    vo fazer uma pergunta boba...mas nunca se sabe neh...
    esse teu dominio ae jah eh registrado (to sem ponto de interrogacao)...
    pq se num tiver registrado...num vai dar mto certo naum....
    []s
