Ai e o seguinte já instalei vairias veze o modulo da PRO/Wireless 2200BG e não Funciona. ;-(
Veja a resposta :
[[email protected] apt]# iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
sit0 no wireless extensions.
eth1 unassociated ESSIDff/any
Mode:Managed Channel=0 Access Point: 00:00:00:00:00:00
Bit Rate=0 kb/s Tx-Power=off
RTS thrff Fragment thr
ff
Encryption keyff
Power Managementff
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
[[email protected] apt]# iwlist scanning
lo Interface doesn't support scanning.
eth0 Interface doesn't support scanning.
sit0 Interface doesn't support scanning.
eth1 No scan results
Obrigado .. e com posso reoslve isso .. :-(
Obrigado :
