Olá caros amigos!
Estou com problemas de lentidão na hora em que acesso a pasta e a impressora compartilhada no meu Servidor de Impressão. Acessando tanto de estações XP ou 98. Em algumas estações ele não consegue nem acessar o servidor via NOME...via IP tenho acesso e o acesso é bem mais rápido...
Alguém tem alguma idéia??
Segue meu smb.conf (Conectiva 10)
[global]
workgroup = GAIOTTO
server string = printerserver
printcap name = cups
load printers = yes
printing = cups
printcap name = /etc/printcap
log file = /var/log/samba/%m.log
max log size = 50
debug level = 0
security = share
domain master = no
domain logons = no
wins support = yes
encrypt passwords = yes
# smb passwd file = /etc/samba/smbpasswd
# username map = /etc/samba/smbusers
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
add machine script = /usr/sbin/adduser -n -r -g machines -c "Samba machine" -d /dev/null -s /bin/false %u
# see the smb.conf(5) manpage for other important backends, such as tdbsam and ldap
# passdb backend = smbpasswd
#============================ Share Definitions ==============================
[homes]
comment = Home Directories
browseable = no
writable = yes
# Un-comment the following and create the netlogon directory for Domain Logons
; [netlogon]
; comment = Network Logon Service
; path = /home/netlogon
; guest ok = yes
; writable = no
; share modes = no
# Un-comment the following to provide a specific roving profile share
# the default is to use the user's home directory
[Dados]
comment = Diretorio de Acesso Global
path = /home/gaiotto
browseable = yes
guest ok = yes
writable = yes
public = yes
ready only = no
force create mode = 777
force directory = 777
# automatic printer driver download support
[print$]
path = /var/lib/samba/drivers
guest ok = yes
browseable = yes
read only = no
; since this share is configured as read only, then we need
; a 'write list'. Check the file system permissions to make
; sure this account can copy files to the share. If this
; is setup to a non-root account, then it should also exist
; as a 'printer admin'
write list = root
[printers]
comment = All Printers
print command = lpr -P %p -o raw %s -r
lpq command = lpstat -o %p
lprm command = cancel %p-%j
path = /var/spool/samba
browseable = yes
# Set public = yes to allow user 'guest account' to print
guest ok = yes
writable = yes
printable = yes
printer admin = root
Valeu!!!!!
  Citação
