    Airwalk
    Padrão Erro no proftpd
    Boa tarde pessoal!
    Estou configurando o proftpd e não autentica o ftp quando tento acessá-lo através do endereço ftp://localhost. A mensagem de erro que eu recebo é "530 Login incorrect".
    Recebo essa mensagem tentando autenticar com a conta de sistema root e também com a conta anonymous.
    Segue a configuração do arquivo proftpd.conf. Agradeço antecipadamente a ajuda!
    # /etc/proftpd.conf -- This is a basic ProFTPD configuration file.
    # To really apply changes reload proftpd after modifications.
    ServerName "Debian"
    ServerType standalone
    DeferWelcome off
    MultilineRFC2228 on
    DefaultServer on
    ShowSymlinks on
    TimeoutNoTransfer 600
    TimeoutStalled 600
    TimeoutIdle 1200
    DisplayLogin welcome.msg
    DisplayFirstChdir .message
    ListOptions "-l"
    DenyFilter \*.*/
    # Uncomment this if you are using NIS or LDAP to retrieve passwords:
    #PersistentPasswd off
    # Uncomment this if you would use TLS module:
    #TLSEngine on
    # Uncomment this if you would use quota module:
    #Quotas on
    # Uncomment this if you would use ratio module:
    #Ratios on
    # Port 21 is the standard FTP port.
    Port 21
    # To prevent DoS attacks, set the maximum number of child processes
    # to 30. If you need to allow more than 30 concurrent connections
    # at once, simply increase this value. Note that this ONLY works
    # in standalone mode, in inetd mode you should use an inetd server
    # that allows you to limit maximum number of processes per service
    # (such as xinetd)
    MaxInstances 30
    # Set the user and group that the server normally runs at.
    User nobody
    Group nogroup
    # Umask 022 is a good standard umask to prevent new files and dirs
    # (second parm) from being group and world writable.
    Umask 022 022
    # Normally, we want files to be overwriteable.
    AllowOverwrite on
    # Delay engine reduces impact of the so-called Timing Attack described in
    # http://security.lss.hr/index.php?pag...LSS-2004-10-02
    # It is on by default.
    #DelayEngine off
    # A basic anonymous configuration, no upload directories.
    # <Anonymous ~ftp>
    User ftp
    Group nogroup
    # # We want clients to be able to login with "anonymous" as well as "ftp"
    UserAlias anonymous ftp
    # # Cosmetic changes, all files belongs to ftp user
    DirFakeUser on ftp
    DirFakeGroup on ftp
    # RequireValidShell off
    # # Limit the maximum number of anonymous logins
    # MaxClients 10
    # # We want 'welcome.msg' displayed at login, and '.message' displayed
    # # in each newly chdired directory.
    # DisplayLogin welcome.msg
    # DisplayFirstChdir .message
    # # Limit WRITE everywhere in the anonymous chroot
    # <Directory *>
    # <Limit WRITE>
    # DenyAll
    # </Limit>
    # </Directory>
    # # Uncomment this if you're brave.
    # # <Directory incoming>
    # # # Umask 022 is a good standard umask to prevent new files and dirs
    # # # (second parm) from being group and world writable.
    # # Umask 022 022
    # # <Limit READ WRITE>
    # # DenyAll
    # # </Limit>
    # # <Limit STOR>
    # # AllowAll
    # # </Limit>
    # # </Directory>
    # </Anonymous>
    # Linhas para o cacic
    DefaultRoot ~
    Com o usuario root voce nao deve conseguir pois por padrao ele vem incluido no arquivo /etc/ftpusers . Ve se `e o seu caso. Nao aconselho remover.
    Ja o anonymous as linhas estao comentadas nao? # <Anonymous ~ftp>
    da uma olhada no arquivo de configuracao com relacao ao trecho do anonymous.
    Falou.
    Abra;os
    Airwalk
    Padrão Problema persiste...
    Criei um novo usuário e adiocionei o nome da conta no arquivos ftpusers... não funcionou...
    O mais estranho é que agora eu consigo autenticar o login para FTP, porém com uma conta que não está listada no ftpusers!
    Agradeço a ajuda e se alguém tiver um arquivo proftpd.conf redondinho e o processo para adicionar novos usuários ftp e a configuração da pasta raiz do ftp para cada usuário... eu agradeço muito!!!
    Um abraço, Ricardo
    vc deixou comentando a linha do Dirtorio do anonymous as linhas estao comentadas nao
    # <Anonymous ~ftp>
    e veja se é este seu diretório de Ftp.
    no meu caso por exemplo, fica no /srv/ftp
    <Anonymous /srv/ftp>
    blz
    abraços
    Jeff
    A funçao do ftpusers é justamente proibir o acesso de determinados usuários.
    Por exemplo, os usuarios do sistema e o root. Usuarios listados neste arquivo não podem logar.
    Com relaçao ao proftpd descomente o trecho que vai de # <Anonymous ~ftp> para o anonymous poder logar.
