    sando_pira
    Padrão log do squid não pega o ip´s clientes
    o meu squid não esta pegando os ip que estão acessando a internet. o que deve esta acontecendo. minha regra de proxy trans. e esta assim.
    __________________________________________________________
    #proxy trans.
    iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 80 -j REDIRECT --to-port 3128
    iptables -A INPUT -p TCP -s 10.0.0.0/24 --dport 3128 -m state --state NEW -j ACCEPT
    # NAT Rede Local
    iptables -t nat -A POSTROUTING -s 10.0.0.0/24 -o ppp0 -j MASQUERADE
    e meu squid.conf esta assim.
    # NETWORK OPTIONS
    http_port 3128
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    # OPTIONS WHICH AFFECT THE CACHE SIZE
    cache_mem 64 MB
    cache_swap_low 90
    cache_swap_high 95
    # LOGFILE PATHNAMES AND CACHE DIRECTORIES
    cache_dir ufs /usr/local/squid/var/cache 1024 16 256
    cache_access_log /usr/local/squid/var/logs/access.log
    cache_log /usr/local/squid/var/logs/cache.log
    cache_store_log /usr/local/squid/var/logs/store.log
    emulate_httpd_log on
    log_ip_on_direct on
    mime_table /usr/local/squid/etc/mime.conf
    log_mime_hdrs on
    pid_filename /usr/local/squid/var/logs/squid.pid
    debug_options ALL,1
    client_netmask 255.255.255.0
    # OPTIONS FOR EXTERNAL SUPPORT PROGRAMS
    auth_param basic children 5
    auth_param basic realm Squid proxy-caching web server
    auth_param basic credentialsttl 2 hours
    auth_param basic casesensitive off
    # OPTIONS FOR TUNING THE CACHE
    #Suggested default:
    refresh_pattern . 0 20% 4320
    # ACCESS CONTROLS
    #Examples:
    #acl macaddress arp 09:00:2b:23:45:67
    #acl myexample dst_as 1241
    #acl password proxy_auth REQUIRED
    #acl fileupload req_mime_type -i ^multipart/form-data$
    #acl javascript rep_mime_type -i ^application/x-javascript$
    #Recommended minimum configuration:
    acl all src 0.0.0.0/0.0.0.0
    #acl to_localhost dst 127.0.0.0/8
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    #Minhas Permiçoes de acesso
    acl rede src 10.0.0.0/24
    acl clientes src "/usr/local/squid/etc/controle/clientes"
    acl sites url_regex -i "/usr/local/squid/etc/controle/sites"
    # TAG: http_access
    #Default:
    # http_access deny all
    # Only allow cachemgr access from localhost
    http_access deny manager
    # Deny requests to unknown ports
    http_access deny !Safe_ports
    # Deny CONNECT to other than SSL ports
    #Minhas regras de acesso
    http_access allow clientes
    http_access deny rede !sites
    http_reply_access allow all
    icp_access allow all
    # ADMINISTRATIVE PARAMETERS
    #Default:
    cache_effective_user squid
    cache_effective_group squid
    # HTTPD-ACCELERATOR OPTIONS
    httpd_accel_host virtual
    httpd_accel_port 80
    httpd_accel_single_host off
    httpd_accel_with_proxy on
    icon_directory /usr/local/squid/share/icons
    error_directory /usr/local/squid/share/errors/Portuguese
    por valor uma LUZ...
    Padrão O seguinte
    O erro que da não é que aparece apenas a sua subrede não é tipo 10.0.0.0 é isso se for faz o seguinte
    muda essas linhas ai
    essa
    por essa
    acl localhost src 10.0.0.0/24
    e comenta essa acl rede src 10.0.0.0/24
    :@: 6)
    client_netmask 255.255.255.255
    :good:
    Padrão num entendi
    client mask
