    Padrão firewall controla mac X ip mas com um problema;;;;
    ola pessoal, espero que alguem possa me ajudar!
    montei um firewall com controle de MAC x IP
    ele esta controlando ip e mac perfeitamente so que estou tendo o seguinte problema:
    os clientes não navegam, nao pinga o servidor e nem o proprio servidor pinga o ip dele mesmo.
    fico agrade... com sua colabora.....
    #!/bin/bash
    MACLIST=/etc/maclist
    ### Forward
    /sbin/modprobe iptable_nat
    /sbin/modprobe iptable_filter
    /sbin/modprobe iptable_mangle
    /sbin/modprobe ip_tables
    /sbin/modprobe ip_conntrack
    /sbin/modprobe ip_conntrack_ftp
    /sbin/modprobe ip_queue
    /sbin/modprobe ip_nat_ftp
    /sbin/modprobe ip_nat_irc
    /sbin/modprobe ipt_limit
    /sbin/modprobe ipt_conntrack
    /sbin/modprobe ipt_mac
    /sbin/modprobe ipt_mark
    /sbin/modprobe ipt_multiport
    /sbin/modprobe ipt_owner
    /sbin/modprobe ipt_state
    /sbin/modprobe ipt_tcpmss
    /sbin/modprobe ipt_tos
    /sbin/modprobe ipt_LOG
    /sbin/modprobe ipt_REJECT
    /sbin/modprobe ipt_MASQUERADE
    /sbin/modprobe ipt_MARK
    /sbin/modprobe ipt_REDIRECT
    /sbin/modprobe ipt_TCPMSS
    /sbin/modprobe ipt_TOS
    iptables -F
    iptables -t nat -F
    iptables -t filter -F
    iptables -t mangle -F
    iptables -P FORWARD ACCEPT
    iptables -A INPUT -i lo -j ACCEPT
    iptables -A OUTPUT -o lo -j ACCEPT
    ### Inicio Controle MAC e Regras para Graficos - Clientes
    for i in `cat $MACLIST`; do
    STATUS=`echo $i | cut -d ';' -f 1`
    IPSOURCE=`echo $i | cut -d ';' -f 3`
    MACSOURCE=`echo $i | cut -d ';' -f 2`
    # Compara IP e MAC
    iptables -A INPUT -s $IPSOURCE -m mac --mac-source $MACSOURCE -j ACCEPT
    # NAT
    iptables -t filter -A FORWARD -d 0/0 -s $IPSOURCE -m mac --mac-source $MACSOURCE -j ACCEPT
    iptables -t filter -A FORWARD -d $IPSOURCE -s 0/0 -j ACCEPT
    iptables -t nat -A POSTROUTING -s $IPSOURCE -d 0/0 -j MASQUERADE
    # Proxy
    iptables -A INPUT -s $IPSOURCE --match mac --mac-source $MACSOURCE -p tcp --dport 8080 -j ACCEPT
    iptables -t nat -A PREROUTING -s $IPSOURCE --match mac --mac-source $MACSOURCE -p tcp --dport 80 -j REDIRECT --to-port 8080
    # Bloqueia Restante
    iptables -t filter -P FORWARD DROP
    iptables -A INPUT -i eth0 -j DROP
    done
    ### Fim Controle MAC
    Padrão esqueci de um etalhe
    o arquivo da mac liste esta sendo montado dentro da seguinte forma
    a;192.168.0.1;00:00:00:00:00:00;nome_do_cliente
    casper-linux
    Vou te oferecer outra solução para controle de mac e ip no seu servidor...
    ok
    Utilize o controle arp nativo do linux.
    Para isso basta que você coloque o ip e o mac permitido no arquivo /etc/ethers
    se o arquivo não existir, então crie-o. E para os ips que não estiverem sendo utilizados coloque a seguinte notação:
    192.168.1.100 00:00:00:00:00:00
    já para os liberados
    192.168.1.200 00:02:2d:ae:77:56
    sempre depois de modificar esse arquivo você deve digitar o comando:
    arp -f /etc/ethers
    caso você ainda não esteja utilizando esse controle você pode digitar: arp -an
    que ele vai te mostrar todos os ips e mac que estiverem conectados no seu servidor.
    É uma solução prática e rápida...
    Valeu
    Fabrício
    casper-linux
    sobre os seus clientes não navegarem pode ser essa regra:
    se essa for a sua interface externa (ligada na internet) ninguém vai navegar mesmo, pense da seguinte forma....
    * quando um cliente for navegar ele faz uma requisição de uma nova conexão:
    * seu firewall vai passar regra por regra até achar uma que permita.
    * vamos supor que ele achou., uma regra que libere na eth1 (sua interface da rede interna).
    * o seu pacote saiu para internet e alguém vai responder (na eth0).
    * ess alguém responde, e o pacote chega na eth0, seu firewall começa a analizar as regras, e a única coisa que ele encontra é a regra: iptables -A INPUT -i eth0 -j DROP, e ele obedece.
    Mata seu pacote e ninguém navega.
    Se você quer bloquear as conexões externas, utilize uma regra baseado no estado da conexão. Pois quando você inicia uma conexão o pacote esta com o estado "new", depois quando *alguém* responde ela esta com o estado "estabilizado ou relacionado", então na eth0 (se for sua interface de saida) a regra melhor adquada seria:
    iptables -A INPUT -i eth0 -m state --state ESTABLISHED,RELATED -j ACCEPT
    Tente ai,
    Valeu
    Fabrício
