    Padrão porta 3128 não levanta nem com viagra!!!
    Ola pessoa mais uma vez estou precisando da ajuda de vc´s.
    instalei o squid configureio squid.conf pra rodar em 3 placas de rede tudo ok, o problema eo seguinte quando vou testar a porta 3128 ela não navega.
    Alguem aki pode me ajudar?
    Cara,
    Como vc esta redirecionando o trafego para a porta 3128???
    [] Dotta :twisted:
    to fazendo assim
    iptables -t nat -A PREROUTING -i FACE -p tcp --dport 80 -j REDIRECT --to-port 3128
    e o squid.conf ta assim
    http_port 192.168.0.1:3128
    http_port 193.168.0.1:3128
    http_port 193.168.1.1:3128
    http_port 193.168.2.1:3128
    http_port 194.168.0.1:3128
    http_port 194.168.1.1:3128
    #hierarchy_stoplist cgi-bin ?
    #acl QUERY urlpath_regex cgi-bin ?
    #no_cache deny QUERY
    # memoria usada:
    cache_mem 128 MB
    #esvazia o cache:
    cache_swap_low 90
    cache_swap_high 93
    maximum_object_size 6144 KB
    minimum_object_size 0 KB
    maximum_object_size_in_memory 100 KB
    ipcache_size 1024
    ipcache_low 90
    ipcache_high 93
    cache_replacement_policy lru
    memory_replacement_policy lru
    # disco usado (5gb) :
    cache_dir ufs /var/cache/squid/cache 5000 16 256
    cache_log /var/log/squid/cache.log
    cache_store_log /var/log/squid/store.log
    visible_hostname servidor
    auth_param basic children 5
    auth_param basic realm Squid proxy-caching web server
    auth_param basic credentialsttl 2 hours
    refresh_pattern . 0 20% 4320
    acl all src 0.0.0.0/0.0.0.0
    acl rede1 src 192.168.0.0/30
    acl rede2 src 193.168.0.0/30
    acl rede3 src 193.168.1.0/30
    acl rede4 src 193.168.2.0/30
    acl rede5 src 194.168.0.0/30
    acl rede6 src 194.168.1.0/30
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    http_access allow localhost
    http_access allow rede1
    http_access allow rede2
    http_access allow rede3
    http_access allow rede4
    http_access allow rede5
    http_access allow rede6
    http_access deny manager
    http_access deny !Safe_ports
    http_access deny all
    http_reply_access allow all
    icp_access allow all
    cache_effective_user proxy
    cache_effective_group proxy
    httpd_accel_port 80
    httpd_accel_host virtual
    httpd_accel_with_proxy on
    Citação Postado originalmente por tianguapontocom
    to fazendo assim
    Caro,
    só redirecionar o trafego pra 3128 nao adianta. Vc tem que abrir a porta 3128 com regras de input pra sua rede.
    :good:
    pilantrox
    tenta deixar na linha da porta soh a porta mesmo sem ip....
    http_port 3128
    to fazendo assim
    # memoria usada:
    cache_mem 128 MB
    #esvazia o cache:
    cache_swap_low 90
    cache_swap_high 93
    ipcache_size 1024
    ipcache_low 90
    ipcache_high 93
    httpd_accel_port 80
