    icefox
    Padrão squid instalado mas nao autentica
    Ola pessoal, estou usando o slackware 10.1, tento usar a autenticacao do squid mas ele diz nao encontrar a maquina, nao sei mais o que fazer, portanto vou relatar tudo o que fiz desde o inicio.
    1 - instalacao do squid
    # ps aux | grep squid
    root 5057 0.0 0.1 1688 600 pts/1 R+ 14:45 0:00 grep squid
    2 - meu squid.conf
    # Inicio do squid.conf
    http_port 3128
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    icp_port 0
    cache_mem 150 MB
    maximum_object_size 4096 KB
    cache_dir ufs /var/spool/squid 500 16 256
    auth_param basic program /usr/libexec/ncsa_auth /etc/squid/passwd
    auth_param basic children 30
    auth_param basic realm Digite seu Login e Senha
    connect_timeout 2 minutes
    refresh_pattern . 0 20% 4320
    acl all src 0.0.0.0/0.0.0.0
    cache_log /var/log/squid/cache.log
    cache_store_log none
    emulate_httpd_log off
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    acl horario_normal time MTWHF 06:00-20:00
    acl rede_interna src 10.100.21.0/255.255.255.0
    acl porno url_regex -i "/etc/squid/porno"
    acl regraurl urlpath_regex "/etc/squid/regra_de_url"
    acl password proxy_auth REQUIRED
    http_access allow password
    http_access allow rede_interna
    http_access allow horario_normal
    http_access deny porno
    http_access deny regraurl all
    http_access deny manager
    http_access deny !Safe_ports
    http_access deny all
    http_reply_access allow all
    icp_access allow all
    miss_access allow all
    cache_mgr [email protected]
    cache_effective_group squid
    visible_hostname localhost
    store_avg_object_size 4 KB
    #httpd_accel_port 80
    #httpd_accel_host virtual
    #httpd_accel_with_proxy on
    #httpd_accel_uses_host_header on
    coredump_dir /var/spool/squid
    3 - minhas regras de firewall (ja to aceitando tudo, nao recuso quase nada)
    #!/bin/sh
    touch /var/lock/subsys/local
    echo 1>/proc/sys/net/ipv4/ip_forward
    # carrega os modulos de ip
    modprobe ip_tables
    modprobe iptable_nat
    # limpa todas as regras de firewall
    iptables -F
    iptables -t nat -F
    # aceita tudo
    iptables -A INPUT -j ACCEPT
    iptables -A OUTPUT -j ACCEPT
    iptables -A FORWARD -j ACCEPT
    # para o squid
    iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 80 -j REDIRECT --to-port 3128
    # rede local receber e-mails
    iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
    # abre para rede local
    iptables -A INPUT -p tcp --syn -s 10.100.21.0/255.255.255.0 -j ACCEPT
    # FECHA A PORTA SSH E ABRE APENAS PARA OS ESPECIFICOS
    iptables -A INPUT -p tcp --syn --dport 22 -j DROP
    iptables -A INPUT -p tcp --syn -s 10.30.26.2 --dport 22 -j ACCEPT
    iptables -A INPUT -p tcp --syn -s 10.100.16.1 --dport 22 -j ACCEPT
    # PORTA MSN
    iptables -A INPUT -p tcp --syn --dport 1863 -j ACCEPT
    pronto somente isso, mas eu tenho outras regras basicas, pacotes danificados, ping malicioso, etc...
    4 - configurei as estacoes win98 para o proxie e qdo tento acessar a internet pelo explorer ele diz localizando 10.100.21.1 e depois acusa NAO ENCONTRADO, mas se eu nao encontrasse nao estaria podendo trabalhar com o SAMBA, o que estou fazendo de errado ?
    wrochal
    Caro,
    Entre em contato comigo para ajudar-lo.
    Falou,
    Padrão Re: squid instalado mas nao autentica
    é esse mesmo o caminho onde se encontra o ncsa_auth ???
    mesmo essa linha como esta nao ta dando nenhum erro???
    Porque essa linha ???
    como foi que vc configurou as estaçoes ???
    Nao da nenhum erro ??? apenas nao funciona ??? O que acontece ???
    Valeu !!!
    icefox
    visible_hostname localhauth_param basic nao acusa nenhum erro; program /usr/libexec/ncsa_auth /etc/squid/passwdost, sim o caminho he esse mesmo, ja copiei o ncsa_auth para dentro do /usr/bin e tambem nao funcionou;
    iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 80 -j REDIRECT --to-port 3128, serve para redirecionar toda a saida da porta 80 para a porta 3128, caso algum usuario modifique as configuracoes de proxie da maquina windows ela nao navega;
    qdo aciono o IE ele diz,procurando 10.100.21.1, servidor nao localizado, ja me falaram que poderia ser o DNS, estou configurando a maquina para ser servidor de dns tambem,
