[email protected]:/etc/postgresql$ /usr/local/pgsql/bin/initdb -D /usr/local/pgsql/data
The files belonging to this database system will be owned by user "postgres".
This user must also own the server process.
The database cluster will be initialized with locale pt_BR.
The default database encoding has accordingly been set to LATIN1.
creating directory /usr/local/pgsql/data ... ok
creating directory /usr/local/pgsql/data/global ... ok
creating directory /usr/local/pgsql/data/pg_xlog ... ok
creating directory /usr/local/pgsql/data/pg_xlog/archive_status ... ok
creating directory /usr/local/pgsql/data/pg_clog ... ok
creating directory /usr/local/pgsql/data/pg_subtrans ... ok
creating directory /usr/local/pgsql/data/base ... ok
creating directory /usr/local/pgsql/data/base/1 ... ok
creating directory /usr/local/pgsql/data/pg_tblspc ... ok
selecting default max_connections ... 100
selecting default shared_buffers ... 1000
creating configuration files ... ok
creating template1 database in /usr/local/pgsql/data/base/1 ... ok
initializing pg_shadow ... ok
enabling unlimited row size for system tables ... ok
initializing pg_depend ... ok
creating system views ... ok
loading pg_description ... ok
creating conversions ... ok
setting privileges on built-in objects ... ok
creating information schema ... ok
vacuuming database template1 ... ok
copying template1 to template0 ... ok
WARNING: enabling "trust" authentication for local connections
You can change this by editing pg_hba.conf or using the -A option the
next time you run initdb.
Success. You can now start the database server using:
/usr/local/pgsql/bin/postmaster -D /usr/local/pgsql/data
or
/usr/local/pgsql/bin/pg_ctl -D /usr/local/pgsql/data -l logfile start
