    Padrão kismet
    Gente estou tentando fazer funcionar o kismet aqui mas ta dando esse erro alguem ja usou e pode me dar uma dica do que pode estar havendo?
    [[email protected] run]# kismet
    Server options: none
    Client options: none
    Starting server...
    Waiting for server to start before starting UI...
    Will drop privs to juliano (500) gid 500
    No specific sources given to be enabled, all will be enabled.
    Enabling channel hopping.
    Disabling channel splitting.
    Source 0 (orinocosource): Enabling monitor mode for orinoco source interface eth0 channel 6...
    Source 0 (orinocosource): Opening orinoco source interface eth0...
    Spawned channelc control process 3204
    Dropped privs to juliano (500) gid 500
    Allowing clients to fetch WEP keys.
    Limiting dumpfile to 1 packets each.
    Logging networks to Kismet-Aug-09-2005-1.network
    Logging networks in CSV format to Kismet-Aug-09-2005-1.csv
    Logging networks in XML format to Kismet-Aug-09-2005-1.xml
    Logging cryptographically weak packets to Kismet-Aug-09-2005-1.weak
    Logging cisco product information to Kismet-Aug-09-2005-1.cisco
    Logging gps coordinates to Kismet-Aug-09-2005-1.gps
    Logging data to Kismet-Aug-09-2005-1.dump
    Writing data files to disk every 300 seconds.
    Mangling encrypted and fuzzy data packets.
    Tracking probe responses and associating probe networks.
    Reading AP manufacturer data and defaults from /usr/local/etc/ap_manuf
    Reading client manufacturer data and defaults from /usr/local/etc/client_manuf
    Using network-classifier based data encryption detection
    FATAL: Dump file error: Unable to open dump file Kismet-Aug-09-2005-1.dump (Permission denied)
    Sending termination request to channel control child 3204...
    Waiting for channel control child 3204 to exit...
    WARNING: Sometimes cards don't always come out of monitor mode
    cleanly. If your card is not fully working, you may need to
    restart or reconfigure it for normal operation.
    Kismet exiting.
    [[email protected] run]# :toim: :toim: :toim: :toim: :toim:
    lluner
    Padrão kismet
    qual é a sua placa wireless , qual modulo que vc esta usando , ela permite utilizar o rf monitor mode ?
    Padrão kismet
    de permissao
    Padrão kismet
    Citação Postado originalmente por mistymst
    de permissao
    entao eu to tentando rodar ele como root
    ta dando erro de permissão, eu ja vasculhei e nao sei o que ta barrando
    Padrão kismet
    Citação Postado originalmente por lluner
    ta instalado num notebook, acer 3000 com conectiva 10, a placa é uma pcmcia orinoco gold e ta configurada navegando normalmente
