    bau
    Padrão Urgente FTP Disconecta sozinho.
    Eae Galera...
    Seguinte configurei o Proftpd em uma rede interna e estou passando por um pequeno problema.
    Ele fica conectado apenas por alguns minutos e logo em seguida desconecta.
    [[email protected]_server proftp]# tail -f /var/proftpd/proftpd.log
    Aug 10 11:42:58 contab_server proftpd[5130] contab_server: Failed binding to 0.0.0.0, port 21: Address already in use
    Aug 10 11:42:58 contab_server proftpd[5130] contab_server: Check the ServerType directive to ensure you are configured correctly.
    Percebi essa mensagem no log, alguém pode me ajudar?
    # /etc/proftpd.conf -- This is a basic ProFTPD configuration file.
    # To really apply changes reload proftpd after modifications.
    ServerName "FTP_Server"
    ServerType standalone
    DeferWelcome off
    ServerAdmin "Se detectado algum problema. E-mail [email protected]"
    MultilineRFC2228 on
    DefaultServer on
    ShowSymlinks on
    TimeoutNoTransfer 600
    TimeoutStalled 600
    TimeoutIdle 1200
    DisplayLogin welcome.msg
    DisplayFirstChdir .message
    ListOptions "-l"
    DenyFilter \*.*/
    WtmpLog off
    SystemLog /var/proftpd/proftpd.log
    DefaultRoot ~
    # Uncomment this if you are using NIS or LDAP to retrieve passwords:
    #PersistentPasswd off
    # Uncomment this if you would use TLS module:
    #TLSEngine on
    # Uncomment this if you would use quota module:
    #Quotas on
    # Uncomment this if you would use ratio module:
    #Ratios on
    # Port 21 is the standard FTP port.
    Port 21
    # To prevent DoS attacks, set the maximum number of child processes
    # to 30. If you need to allow more than 30 concurrent connections
    # at once, simply increase this value. Note that this ONLY works
    # in standalone mode, in inetd mode you should use an inetd server
    # that allows you to limit maximum number of processes per service
    # (such as xinetd)
    MaxInstances 30
    # Set the user and group that the server normally runs at.
    User nobody
    Group nogroup
    # Umask 022 is a good standard umask to prevent new files and dirs
    # (second parm) from being group and world writable.
    Umask 022 022
    # Normally, we want files to be overwriteable.
    AllowOverwrite on
    # Delay engine reduces impact of the so-called Timing Attack described in
    # http://security.lss.hr/index.php?pag...LSS-2004-10-02
    # It is on by default.
    #DelayEngine off
    # A basic anonymous configuration, no upload directories.
    # <Anonymous ~ftp>
    # User ftp
    # Group nogroup
    # # We want clients to be able to login with "anonymous" as well as "ftp"
    # UserAlias anonymous ftp
    # # Cosmetic changes, all files belongs to ftp user
    # DirFakeUser on ftp
    # DirFakeGroup on ftp
    # RequireValidShell off
    # # Limit the maximum number of anonymous logins
    # MaxClients 10
    # # We want 'welcome.msg' displayed at login, and '.message' displayed
    # # in each newly chdired directory.
    # DisplayLogin welcome.msg
    # DisplayFirstChdir .message
    # # Limit WRITE everywhere in the anonymous chroot
    # <Directory *>
    # <Limit WRITE>
    # DenyAll
    # </Limit>
    # </Directory>
    # # Uncomment this if you're brave.
    # # <Directory incoming>
    # # # Umask 022 is a good standard umask to prevent new files and dirs
    # # # (second parm) from being group and world writable.
    # # Umask 022 022
    # # <Limit READ WRITE>
    # # DenyAll
    # # </Limit>
    # # <Limit STOR>
    # # AllowAll
    # # </Limit>
    # # </Directory>
    # </Anonymous>
    Agradeço.
    [ ] 's
    Bau
    bau
    Galera estou usando o Fedora Core 4.
    kernel 2.6.10. Já desabilitei o xinetd e o problema continua.
    Por favor alguém me ajude.
    [ ] 's
    slice
    aumente o tempo de timeout...
