    Padrão Configurar uebmiau 2.7.8 Por Favor
    Ai galera eu não estou conseguindo configurar o UEBMIAU 2.7.8, não acho nada sobre na internet e não consegui fazer nada, será que alguem ai não poderia me ajudar ou indicar algum artigo que me ajuda a configurá-lo pois os que encontro na net são das versões antigas, onde o script do config.php e diferente.
    Ajuda ai blz galera.
    Aqui gente até tentei configurar sozinho mas não deu, olhem o arquivo config.php:
    Código :
    UebiMiau is a GPL'ed software developed by
     - Aldoir Ventura - [email][email protected][/email]
     - http://uebimiau.sourceforge.net
    Fell free to contact, send donations or anything to me :-)
    São Paulo - Brasil
    #Defaults:
    #1 - Yes/On/True
    #0 - No/Off/False
    # do not remove or change this
    define('yes',1);
    define('no',0);
    $ALL_OK = false;
    $themes 	= Array();
    $languages 	= Array();
    # _ Please attention _:
    # The temporary files will be stored on this folder
    # For security reasons, do not use web-shared folders
    # ** The Web Server needs write-permission on this folder
    # * Unix/Linux users use.
    # /tmp/uebimiau
    # * Win32 users
    # c:/winnt/temp/uebimiau
    # NEVER use backslashes (\). Always use forward slashes (/),
    # for all operating systems, INCLUDING Windows
    $temporary_directory = "database/";
    # Your local SMTP Server (alias or IP) such as "smtp.yourdomain.com"
    # eg. "server1;server2;server3"   -> specify main and backup server
    $smtp_server = "localhost";  #YOU NEED CHANGE IT !!
    # You should enable this option if you know what are doing
    $allow_filters = no;
    # The maximum size for stored files
    # In order to keep you system fast, use values better than 5MB
    # If you need disable it, set the value to 0 or leave it blank
    $quota_limit = 0;  //  in KB, eg. 4096 Kb = 4MB
    # Use SMTP password (AUTH LOGIN type)
    $use_password_for_smtp	= yes;
    # Redirect new users to the preferences page at first login
    $check_first_login		= yes;
    # Turn this option to 'yes' if you want allow users send messages using
    # they 'Reply to' preference's option as your 'From' header, otherwise
    # the From field will be the email wich the users log in
    $allow_modified_from	= yes;
    # Language & themes settings
    require("./inc/config.languages.php");
    # Security related settings
    require("./inc/config.security.php");
    # Server type:
    # allowed values:
    # "DETECT" -------->	Guess the pop3 server. If you are running UM
    # 					in a domain "[url]www.company.com"[/url], the script will
    #					use "PREFIX.company.com" as your server. you
    #					can set the "PREFIX" in the var $mail_detect_prefix.
    #					Also, the var $mail_detect_remove can be set
    #					to "[url]www."[/url], then the script get rid the "www" and
    #					put the prefix, eg. pop3.company.com.br
    #"ONE-FOR-EACH" -->	Each domain have your own mail server.
    #					The script will load the list of domains/servers from
    #					var $mail_servers.
    #"ONE-FOR-ALL" --->	If you use this option, your users must supply the
    #					full email address as username. You can set the mail
    #					server in the var $default_mail_server
    # LOGIN_TYPE
    # Note. You can supply the LOGIN_TYPE according to your MAIL SERVER.
    # Eg. If your mail server requires usernames in [email][email protected][/email], you must
    # specify the LOGIN_TYPE as "%user%@%domain%". You can combine it according to
    # your server. eg.
    # %user%
    # %user%@%domain%
    # %user%.%domain%
    # PROTOCOL and PORT
    # Choose "imap" as protocol to use the Internet Mail Access Protocol,
    # or "pop3" to use the Post Office Protocol.
    # The default ports are:
    # pop3 -> 110
    # imap -> 143
    # The imap is more fast, but all functions of UebiMiau works with POP3
    $mail_server_type 	= "ONE-FOR-EACH";
    # TYPE: DETECT
    $mail_detect_remove 		= "[url]www.";[/url]
    $mail_detect_prefix 		= "mail.";
    $mail_detect_login_type 	= "%user%@%domain%";
    $mail_detect_protocol 		= "pop3";
    $mail_detect_port 			= "110";
    $mail_detect_folder_prefix 	= "";
    # TYPE: ONE-FOR-EACH
    # Each domain have your own mail server
    $mail_servers[] = Array( //sample using POP3
    	"domain" 		=> "uebimiau.org",
    	"server" 		=> "localhost",
    	"login_type" 	=> "%user%@%domain%",
    	"protocol"		=> "POP3",
    	"port"			=> "110",
    	"folder_prefix"	=> ""
    $mail_servers[] = Array( //sample using IMAP
    	"domain" 		=> "another-domain.com",
    	"server" 		=> "mail.another-domain.com",
    	"protocol"		=> "imap",
    	"port"			=> "143",
    	"folder_prefix"	=> "INBOX."
    # TYPE: ONE-FOR-ALL
    # the default mail server for all domains
    $default_mail_server 	= "mail.YOUR-UNIQUE-SERVER.com.br";
    $one_for_all_login_type	= "%user%@%domain%";
    $default_protocol		= "pop3";
    $default_port			= "110";
    $default_folder_prefix	= "";
    # Specify mail transport
    # Allowed values:
    # "smtp" 		- To use an external SMTP Server specified in $smtp_server
    # "sendmail" 	- To server's sendmail-compatible MTA. If you need to change
    #				  the path, look into /inc/class.phpmailer.php and search for
    #				  var $Sendmail          = "/usr/sbin/sendmail";
    # "mail"		- To use default PHP's mail() function
    $mailer_type		= "smtp";
    # In some POP3 servers, if you send a "RETR" command, your
    # message will be automatically deleted :(
    # This option prevents this inconvenience
    $mail_use_top = yes;
    # Name and Version, it's used in many places, like as
    # "X-Mailer" field, footer
    $appversion = "2.7.8";
    $appname = "UebiMiau";
    # Add a "footer" to sent mails
    $footer = "
    ________________________________________________
    Message sent using $appname $appversion
    # Enable debug :)
    # no - disabled
    # 1 or yes -> enabled with full results
    # 2 -> enable with servers communications only
    $enable_debug = no;
    # Order setting
    $default_sortby = "date";
    $default_sortorder = "DESC";
    # Default preferences...
    $default_preferences = Array(
    	"send_to_trash_default" 	=> yes,		# send deleted messages to trash
    	"st_only_ready_default" 	=> yes,		# only read messages, otherwise, delete it
    	"save_to_sent_default"		=> yes,		# send sent messages to sent
    	"empty_trash_default"		=> yes,		# empty trash on logout
    	"sortby_default"			=> "date",	# alowed: "attach","subject","fromname","date","size"
    	"sortorder_default"			=> "DESC",	# alowed: "ASC","DESC"
    	"rpp_default"				=> 20,		# records per page (messages), alowed: 10,20,30,40,50,100,200
    	"add_signature_default"		=> no,		# add the signature by default
    	"signature_default"			=> "",		# a default signature for all users, use text only, with multiple lines if needed
    	"timezone_default"			=> "+0000",	# timezone, format (+|-)HHMM (H=hours, M=minutes)
    	"display_images_default"	=> yes,		# automatically show attached images in the body of message
    	"editor_mode_default"		=> "html",	# use "html" or "text" to set default editor. "html" will be used only in IE5+ browsers
    	"refresh_time_default"		=> 10		# after this time, the message list will be refreshed, in minutes
    don't touch here
    $ALL_OK = true;
    Por favor me ajudem, meu chefe esta me precionando.
    Citação Postado originalmente por juniovitorino
    Código :
    São Paulo - Brasil
    #Defaults:
    #1 - Yes/On/True
    #0 - No/Off/False
    define('yes',1);
    define('no',0);
    $ALL_OK = false;
    $themes 	= Array();
    # /tmp/uebimiau
    # * Win32 users
    # Server type:
    # allowed values:
    # LOGIN_TYPE
    # your server. eg.
    # %user%
    # %user%@%domain%
    # %user%.%domain%
    # PROTOCOL and PORT
    # pop3 -> 110
    # imap -> 143
    # TYPE: DETECT
    	"port"			=> "110",
    	"port"			=> "143",
    # TYPE: ONE-FOR-ALL
    # Allowed values:
    $footer = "
    # Enable debug :)
    # no - disabled
    $enable_debug = no;
    # Order setting
    don't touch here
    $ALL_OK = true;
    Kra olha esse tuto.. aki
    certeza ke com ele vc consegue configurar naum tem segredo
    http://www.vivaolinux.com.br/dicas/v...hp?codigo=1816
    Padrão uebimiau
    Me chama aí pelo MSN pra gente resolver essa parada!
    [email protected]
    Valew
    Padrão resposta
    cara adiciona meu msn e passo tudo pra vc
    ou tenta faze isso.
    - Aldoir Ventura - [email protected]
    São Paulo - Brasil
    #Defaults:
    #1 - Yes/On/True
    #0 - No/Off/False
    define('yes',1);
    define('no',0);
    $ALL_OK = false;
    $themes = Array();
    # /tmp/uebimiau
    # * Win32 users
    $smtp_server = "smtp.servi.org.br"; #YOU NEED CHANGE IT !!
    $use_password_for_smtp = no;
    # Server type:
    # allowed values:
    # in a domain "www.company.com", the script will
    # to "www.", then the script get rid the "www" and
    # LOGIN_TYPE
    # Eg. If your mail server requires usernames in [email protected], you must
    # your server. eg.
    # %user%
    # %user%@%domain%
    # %user%.%domain%
    # PROTOCOL and PORT
    # pop3 -> 110
    # imap -> 143
    # TYPE: DETECT
    $mail_detect_remove = "www.";
    "domain" => "server.org.br",
    "server" => "server.org.br",
    "login_type" => "%user%",
    "port" => "110",
    "port" => "143",
    # TYPE: ONE-FOR-ALL
    $default_mail_server = "pop3.amm.org.br";
    # Allowed values:
    $mailer_type = "mail";
    $footer = "
    # Enable debug
    # no - disabled
    $enable_debug = no;
    # Order setting
    don't touch here
    $ALL_OK = true;
