  1. Pessoal. Instalei o Suse 9.3 e o bichinho está com problemas. No primeiro Boot ele iniciou o Server X sem problemas mas agora ele está apresentando erro na hora de iniciar o X. Já reinstalei o sistema para resolver esse mesmo problema. Queria que de inicio ele já caisse naquela tela de login com opção de escolher qual o ambiente que quero (KDE, Gnome). como ele não está aparecendo essa tela e fica na tela para login em modo texto mesmo eu estou tentando usar o startx para iniciar. Ai aparece o erro:
    Código :
    X Window System Version 6.8.1
    Release Date: 17 September 2004
    X Protocol Version 11, Revision 0, Release 6.8.1
    Build Operating System: SuSE Linux [ELF] SuSE
    Current Operating System: Linux white-tiger 2.6.8-24-default #1 Wed Oct 6 09:16:23 UTC 2004 i686
    Build Date: 04 October 2004
    	Before reporting problems, check http://wiki.X.Org
    	to make sure that you have the latest version.
    Module Loader present
    Markers: (--) probed, (**) from config file, (==) default setting,
    	(++) from command line, (!!) notice, (II) informational,
    	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
    (==) Log file: "/var/log/Xorg.0.log", Time: Wed Oct 31 20:16:34 2001
    (==) Using config file: "/etc/X11/xorg.conf"
    (EE) SIS(0): **************************************************
    (EE) SIS(0):                       ERROR:
    (EE) SIS(0): Virtual screen too big for memory; 1536K needed, 1532K available
    (EE) SIS(0):                   END OF MESSAGE
    (EE) Screen(s) found, but none have a usable configuration.
    Fatal server error:
    no screens found
    Please consult the The X.Org Foundation support
    	 at http://wiki.X.Org
     for help.
    Please also check the log file at "/var/log/Xorg.0.log" for additional information.
    XIO:  fatal IO error 104 (Connection reset by peer) on X server ":0.0"
          after 0 requests (0 known processed) with 0 events remaining.
    Já usei o xf86config mas continua a mesma coisa. Segue o meu /etc/X11/Xorg.conf
    Código :
    # SaX generated X11 config file
    # Created on: 2005-08-10T00:29:55-0400.
    # Version: 4.8
    # Contact: Marcus Schaefer <sax@suse.de>, 2002
    # Automatically generated by [ISaX] (4.8)
    # PLEASE DO NOT EDIT THIS FILE!
    Section "Files"
      FontPath     "/usr/X11R6/lib/X11/fonts/misc:unscaled"
      FontPath     "/usr/X11R6/lib/X11/fonts/local"
      FontPath     "/usr/X11R6/lib/X11/fonts/75dpi:unscaled"
      FontPath     "/usr/X11R6/lib/X11/fonts/100dpi:unscaled"
      FontPath     "/usr/X11R6/lib/X11/fonts/Type1"
      FontPath     "/usr/X11R6/lib/X11/fonts/URW"
      FontPath     "/usr/X11R6/lib/X11/fonts/Speedo"
      FontPath     "/usr/X11R6/lib/X11/fonts/PEX"
      FontPath     "/usr/X11R6/lib/X11/fonts/cyrillic"
      FontPath     "/usr/X11R6/lib/X11/fonts/latin2/misc:unscaled"
      FontPath     "/usr/X11R6/lib/X11/fonts/latin2/75dpi:unscaled"
      FontPath     "/usr/X11R6/lib/X11/fonts/latin2/100dpi:unscaled"
      FontPath     "/usr/X11R6/lib/X11/fonts/latin2/Type1"
      FontPath     "/usr/X11R6/lib/X11/fonts/latin7/75dpi:unscaled"
      FontPath     "/usr/X11R6/lib/X11/fonts/baekmuk:unscaled"
      FontPath     "/usr/X11R6/lib/X11/fonts/japanese:unscaled"
      FontPath     "/usr/X11R6/lib/X11/fonts/kwintv"
      FontPath     "/usr/X11R6/lib/X11/fonts/truetype"
      FontPath     "/usr/X11R6/lib/X11/fonts/uni:unscaled"
      FontPath     "/usr/X11R6/lib/X11/fonts/CID"
      FontPath     "/usr/X11R6/lib/X11/fonts/ucs/misc:unscaled"
      FontPath     "/usr/X11R6/lib/X11/fonts/ucs/75dpi:unscaled"
      FontPath     "/usr/X11R6/lib/X11/fonts/ucs/100dpi:unscaled"
      FontPath     "/usr/X11R6/lib/X11/fonts/hellas/misc:unscaled"
      FontPath     "/usr/X11R6/lib/X11/fonts/hellas/75dpi:unscaled"
      FontPath     "/usr/X11R6/lib/X11/fonts/hellas/100dpi:unscaled"
      FontPath     "/usr/X11R6/lib/X11/fonts/hellas/Type1"
      FontPath     "/usr/X11R6/lib/X11/fonts/misc/sgi:unscaled"
      FontPath     "/usr/X11R6/lib/X11/fonts/xtest"
      FontPath     "/opt/kde3/share/fonts"
      InputDevices "/dev/ttyS0"
      InputDevices "/dev/ttyS1"
      InputDevices "/dev/ttyS2"
      InputDevices "/dev/ttyS3"
      InputDevices "/dev/ttyS4"
      InputDevices "/dev/ttyS5"
      InputDevices "/dev/ttyS6"
      InputDevices "/dev/ttyS7"
      InputDevices "/dev/ttyS8"
      InputDevices "/dev/psaux"
      InputDevices "/dev/logibm"
      InputDevices "/dev/sunmouse"
      InputDevices "/dev/atibm"
      InputDevices "/dev/amigamouse"
      InputDevices "/dev/atarimouse"
      InputDevices "/dev/inportbm"
      InputDevices "/dev/gpmdata"
      InputDevices "/dev/mouse"
      InputDevices "/dev/usbmouse"
      InputDevices "/dev/adbmouse"
      InputDevices "/dev/input/mice"
      InputDevices "/dev/input/event0"
      InputDevices "/dev/pointer0"
      InputDevices "/dev/pointer1"
      InputDevices "/dev/pointer2"
      InputDevices "/dev/pointer3"
    EndSection
    Section "ServerFlags"
      Option       "AllowMouseOpenFail"
    EndSection
    Section "Module"
      Load         "dbe"
      Load         "type1"
      Load         "freetype"
      Load         "extmod"
      Load         "glx"
      Load         "v4l"
    EndSection
    Section "InputDevice"
      Driver       "kbd"
      Identifier   "Keyboard[0]"
      Option       "Protocol" "Standard"
      Option       "XkbLayout" "us_intl"
      Option       "XkbModel" "pc105"
      Option       "XkbRules" "xfree86"
    EndSection
      Driver       "mouse"
      Identifier   "Mouse[1]"
      Option       "Device" "/dev/ttyS0"
      Option       "Emulate3Buttons" "on"
      Option       "Name" "PLUG AND PLAY SCROLLING MOUSE"
      Option       "Protocol" "microsoft"
      Option       "Vendor" "Sysp"
    EndSection
    Section "Monitor"
      DisplaySize  280 210
      HorizSync    28-54
      Identifier   "Monitor[0]"
      ModelName    "LG ELECTRONICS STUDIOWORKS 5 20SI"
      Option       "DPMS"
      VendorName   "GSM"
      VertRefresh  43-90
      UseModes     "Modes[0]"
    EndSection
    Section "Modes"
      Identifier   "Modes[0]"
      Modeline 	"1024x768" 73.89 1024 1224 1336 656 768 769 772 799
      Modeline 	"800x600" 36.88 800 832 912 1024 600 601 604 621
      Modeline 	"800x600" 44.13 800 840 920 1040 600 601 604 624
      Modeline 	"800x600" 51.73 800 840 928 1056 600 601 604 628
      Modeline 	"800x600" 58.73 800 840 928 1056 600 601 604 632
      Modeline 	"640x480" 23.06 640 656 720 800 480 481 484 497
      Modeline 	"640x480" 27.74 640 664 728 816 480 481 484 500
      Modeline 	"640x480" 32.64 640 672 736 832 480 481 484 503
      Modeline 	"640x480" 36.97 640 672 736 832 480 481 484 505
    EndSection
    Section "Screen"
      DefaultDepth 16
      SubSection "Display"
        Depth      15
        Modes      "1024x768" "800x600" "640x480"
      EndSubSection
        Depth      16
      EndSubSection
        Depth      24
      EndSubSection
        Depth      32
      EndSubSection
        Depth      8
      EndSubSection
      Device       "Device[0]"
      Identifier   "Screen[0]"
      Monitor      "Monitor[0]"
    EndSection
    Section "Device"
      BoardName    "SiS630 GUI Accelerator+3D"
      BusID        "1:0:0"
      Driver       "sis"
      Identifier   "Device[0]"
      VendorName   "SiS"
    EndSection
    Section "ServerLayout"
      Identifier   "Layout[all]"
      InputDevice  "Keyboard[0]" "CoreKeyboard"
      InputDevice  "Mouse[1]" "CorePointer"
      Option       "Clone" "off"
      Option       "Xinerama" "off"
      Screen       "Screen[0]"
    EndSection
    Section "DRI"
        Group      "video"
        Mode       0660
    EndSection
    Section "Extensions"
    EndSection
    Se for preciso tenho o /var/log/Xorg.0.log também mas ele está grande e acho que o post já ficou enorme.
  2. Aeee povu. Ninguem pode me ajudar?
    felco
    Voce mexeu na memoria da placa de video, diminuiu?
    Pra iniciar aquela tela de login nao e com o startx... voce pode usa ou o kdm ou xdm
    Eu uso o xdm, mas antes de usar qualquer um dos 2 configura seu X, se ele nao estiver funcionando quando o xdm entrar ele fica em looping(muitas vezes) tentando iniciar o X...
  4. Eu tenho um problema sério. Minha Bios não guarda as informações. Pq? Não sei. Já troquei a bateria e nada.
    felco
    Hummm voce já verifico se o jumper de reset CMOS esta desligado?
  1. Servidor PROFTPD não aceita conexão...
    Por FabioRB no fórum Servidores de Rede
    Respostas: 5
    Último Post: 29-12-2004, 14:50
  2. Proftpd nao starta.
    Por vandemberg no fórum Servidores de Rede
    Último Post: 19-07-2004, 15:52
  3. servidor samba não imprimi
    Por mcyberx no fórum Servidores de Rede
    Respostas: 6
    Último Post: 22-06-2004, 10:06
  4. orinoco nao starta
    Por muganga no fórum Redes
    Último Post: 10-04-2004, 21:46
  5. Postfix não Starta ???
    Por celosc no fórum Servidores de Rede
    Último Post: 07-08-2003, 16:14
