    calthc
    Padrão DNS unknown class/type
    Alguem poderia me ajudar estou com o named levantado para configurar o DNS interno e a mensagem no MESSAGES é a seguinte:
    dns_master_load: zone/rev.greenline:1: unknown RR type 'Greenline'
    zone 16.200.000.132.in-addr.arpa/IN: loading master file zone/rev.greenline: unknown class/type
    dns_master_load: zone/db.greenline:1: unknown RR type 'DNS'
    zone greenline.lan.br/IN: loading unknown class/type
    zone localhost/IN: loaded serial 42
    running
    arranque do named succeeded
    Mas não funciona usando o dig greenline.lan.br
    posta seu arquivos de zona e suas conf do named.conf. ae qualquer coisa da uma olhada neste link aki http://www.linuxstar.com.br/modules.php?name=Content
    calthc
    Padrão Valeu la vai o arquivo
    -------------named.conf--------------------------
    // generated by named-bootconf.pl
    options {
    directory "/var/named";
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    // query-source address * port 53;
    // a caching only nameserver config
    //controls {
    // inet 127.0.0.1 allow { localhost; } keys { rndckey; };
    zone "." IN {
    type hint;
    file "named.ca";
    zone "localhost" IN {
    type master;
    file "localhost.zone";
    allow-update { none; };
    zone "0.0.127.in-addr.arpa" IN {
    type master;
    file "named.local";
    zone "greenline.lan.br" {
    type master;
    file "zone/db.greenline";
    zone "16.200.000.132.in-addr.arpa" {
    type master;
    file "zone/rev.greenline";
    ------------------fim-----------------------
    -----------------rev.greenline------------
    #DND Greenline
    $TTL 86400
    #linha abaixo esta comentada mas nãentendo o porque 4linux
    @ IN SOA 4linux.com.br. postmaster.4linux.com.br. (
    #@ IN SOA greenline.lan.br. postmaster.greenline.lan.br. (
    2003092002 ; Serial
    28800 ; Refresh
    14400 ; Retry
    3600000 ; Expire
    86400 ) ; Minimum
    @ IN NS greenline.lan.br.
    16.200.000.132.in-addr.arpa. IN PTR greenline.lan.br.
    -----------------db.greenline-------------
    # DNS Claudio
    $TTL 86400
    2003090200 ; Serial
    28800 ; Refresh
    14400 ; Retry
    3600000 ; Expire
    86400 ) ; Minimum
    IN NS ns.greenline.lan.br.
    IN A 132.0.200.16
    IN MX 5 mail.greenline.lan.br.
    ns IN A 132.0.200.16
    ftp IN A 132.0.200.16
    www IN CNAME greenline.lan.br.
    mail IN A 132.0.200.16
    pop IN CNAME mail.greenline.lan.br.
    smtp IN CNAME mail.greenline.lan.br.
    -------------------fim-----------------------------------
    Super_Diaulas
    será por causa do # Greenline do inicio do arquivo???
    se eu não me engano nestes arquivos o comentário é ; ou //, não me lembro agora, o # não é considerado comentário
