Bom dia ,..
Galera estou tentando instalar o squidguard, mas nao estou conseguindo, devido ao erro que me apresenta quando digito o make para compilar.
[root@proxytecmedd squidguard]# make making all in squidguard
make[1]: Entering directory `/usr/local/s_guard/squidGuard-1.2.0/src'
making all in src
gcc -I.. -I. -I. -I/usr/local/BerkeleyDB/include -DHAVE_CONFIG_H -g -O2 -I/usr/local/BerkeleyDB/include -c main.c
gcc -I.. -I. -I. -I/usr/local/BerkeleyDB/include -DHAVE_CONFIG_H -g -O2 -I/usr/local/BerkeleyDB/include -c sgLog.c
gcc -I.. -I. -I. -I/usr/local/BerkeleyDB/include -DHAVE_CONFIG_H -g -O2 -I/usr/local/BerkeleyDB/include -c sgDb.c
sgDb.c: In function `sgDbInit':
sgDb.c:101: warning: passing arg 2 of pointer to function from incompatible pointer type
sgDb.c:101: warning: passing arg 4 of pointer to function makes pointer from integer without a cast
sgDb.c:101: error: too few arguments to function
sgDb.c:107: warning: passing arg 2 of pointer to function from incompatible pointer type
sgDb.c:107: warning: passing arg 4 of pointer to function makes pointer from integer without a cast
sgDb.c:107: error: too few arguments to function
make[1]: ** [sgDb.o] Erro 1
make[1]: Leaving directory `/usr/local/s_guard/squidGuard-1.2.0/src'
make: ** [all] Erro 1
OBS:Estou usando o fedora 3, e o squidguard.tgz, pois nao encontrei o rpm..
Por favor caso alguem saiba me ajude...
Obrigado
Citação
