GALERA....DA UMA FORCINHA AI.. , INSTALEI O NOCAT, (AUTENTICADOR WEB) NO FREEBSD 5.3, SO QUE TENHO A NECESSIDADE DE REDIRECIONAR O TRAFEGO PARA A PORTA 3128 DEPOIS DE AUTENTICAR O USUARIO (NOCAT).
Segue abaixo o script
#!/bin/sh
# Note: your PATH is inherited from the gateway process
IPFW=/sbin/ipfw
# Enable IP forwarding
sysctl net.inet.ip.forwarding=1
# Enable ethernet filtering
sysctl net.link.ether.ipfw=1
# clear all packet filter rules
${IPFW} -fq flush
${IPFW} -fq pipe flush
# Pass external device traffic
${IPFW} add pass all from any to any via ${ExternalDevice}
# Pass loopback traffic
${IPFW} add pass all from any to any via lo0
# Capture rules #
# Pass all layer2
${IPFW} add 50000 pass layer2
# Pass Gateway
${IPFW} add pass tcp from any to any ${GatewayPort} in via ${InternalDevice}
${IPFW} add pass tcp from any to any ${GatewayPort} out via ${InternalDevice}
# Pass SSH for DEBUG
${IPFW} add pass tcp from any to any ssh in via any
${IPFW} add pass tcp from any to any ssh out via any
${IPFW} add pass tcp from any to any ftp in via any
${IPFW} add pass tcp from any to any ftp out via any
# Pass DNS
if [ "${DNSAddr}" != "" ]; then
# Use external DNS server
for a in ${DNSAddr}; do
${IPFW} add pass udp from any to ${a} domain in via ${InternalDevice} keep-state
done
else
# Use local DNS server on gateway
${IPFW} add pass udp from any to ${LocalNetwork} domain in via ${InternalDevice} keep-state
fi
# Allow access to the AuthService
${IPFW} add pass tcp from any to ${AuthServiceAddr} http,https,3128 in via ${InternalDevice}
# Forward all http and https traffic to the Gateway
${IPFW} add fwd ${GatewayAddr},${GatewayPort} tcp from any to any 3128,http,https in via ${InternalDevice}
#regra para squid (em teste)
#${IPFW} add fwd ${GatewayAddr},3128 tcp from any to any in via ${InternalDevice}
# Deny everything else
${IPFW} add deny log all from any to any in via ${InternalDevice}
# DummyNet rules #
# Members
${IPFW} add 60000 queue 1 all from any to any in
${IPFW} add 60000 queue 2 all from any to any out
${IPFW} add 60010 skipto 61000 all from any to any
${IPFW} queue 1 config mask src-ip 0xffffffff pipe 1 weight 75
${IPFW} queue 2 config mask dst-ip 0xffffffff pipe 2 weight 100
${IPFW} pipe 1 config
${IPFW} pipe 2 config
# Others
${IPFW} add 60100 queue 3 all from any to any in
${IPFW} add 60100 queue 4 all from any to any out
${IPFW} add 60110 skipto 61000 all from any to any
${IPFW} queue 3 config mask src-ip 0xffffffff pipe 3 weight 75
${IPFW} queue 4 config mask dst-ip 0xffffffff pipe 4 weight 100
${IPFW} pipe 3 config bw 128Mbit/s
${IPFW} pipe 4 config bw 512Mbit/s[/color][/size]
MSN: anailson@msn.com
Email: anailson@gmail.com
#Evite letras maiusculas para não poluir o post e assim os usuário se sentirem mais a vontade para responde - Moderador
