vamos la, mais um passo para frente...
Segue meu main.cf
Código :command_directory = /usr/sbin daemon_directory = /usr/lib/postfix default_privs = nobody myhostname = frigoking mydomain = brturbo.com myorigin = $mydomain inet_interfaces = all mydestination = $myhostname, localhost.$mydomain, $mydomain,mail.$mydomain,www.$mydomain,ftp.$mydomain #mynetworks = 168.100.189.0/28, 127.0.0.0/8 relay_domains = $mydomain relayhost = smtp.brturbo.com #relay_recipient_maps = hash:/etc/postfix/relay_recipients alias_maps = hash:/etc/postfix/aliases alias_database = hash:/etc/postfix/aliases #mail_spool_directory = /var/mail mailbox_command = /usr/bin/procmail #luser_relay = [email protected] smtpd_banner = $myhostname ESMTP $mail_name ($mail_version) debug_peer_level = 2 #debug_peer_list = 127.0.0.1 debugger_command = PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin xxgdb $daemon_directory/$process_name $process_id & sleep 5 sendmail_path = /usr/sbin/sendmail newaliases_path = /usr/bin/newaliases mailq_path = /usr/bin/mailq setgid_group = postdrop manpage_directory = /usr/share/man sample_directory = /etc/postfix/sample readme_directory = no append_dot_mydomain = no ###########################autenticação############################ smtp_sasl_auth_enable = yes smtp_sasl_password_maps = hash:/etc/postfix/sasl_passwd smtp_sasl_security_options = noanonymous
Agora ele envia com o smtp do provider, mas nao está fazendo autentificacao.
Posso colocar qualquer senha, ou mesmo sem senha, que fica assim o log.
Código :Sep 2 10:26:24 firewall postfix/smtpd[912]: connect from unknown[192.168.254.4] Sep 2 10:26:24 firewall postfix/smtpd[912]: 20FC52D402D: client=unknown[192.168.254.4] Sep 2 10:26:24 firewall postfix/cleanup[915]: 20FC52D402D: message-id=<[email protected]> Sep 2 10:26:24 firewall postfix/qmgr[910]: 20FC52D402D: from=<[email protected]>, size=1323, nrcpt=1 (queue active) Sep 2 10:26:24 firewall postfix/smtpd[912]: disconnect from unknown[192.168.254.4] Sep 2 10:26:35 firewall postfix/smtp[916]: 20FC52D402D: to=<[email protected]>, relay=smtp.brturbo.com[200.199.201.162], delay=11, status=sent (250 Ok: queued as D3F893887) Sep 2 10:26:35 firewall postfix/qmgr[910]: 20FC52D402D: removed
