[email protected] /tmp/mod_auth_pam# make
apxs -c mod_auth_pam.c -lpam
/home/httpd/build/libtool --silent --mode=compile i586-trustix-linux-gcc -prefer -pic -O3 -fomit-frame-pointer -pipe -s -mpentium -mcpu=pentium -march=pentium -f expensive-optimizations -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES=1 -D_LARGEFILE64_S OURCE=1 -DAP_HAVE_DESIGNATED_INITIALIZER -DLINUX=2 -D_REENTRANT -D_XOPEN_SOURCE= 500 -D_BSD_SOURCE -D_SVID_SOURCE -D_GNU_SOURCE -pthread -I/usr/include/apache - I/usr/include/apache -I/usr/include/apache -c -o mod_auth_pam.lo mod_auth_pa m.c && touch mod_auth_pam.slo
/home/httpd/build/libtool --silent --mode=link i586-trustix-linux-gcc -o mod_aut h_pam.la -rpath /usr/lib/apache -module -avoid-version mod_auth_pam.lo -lpam
apxs -c mod_auth_sys_group.c -lpam
/home/httpd/build/libtool --silent --mode=compile i586-trustix-linux-gcc -prefer -pic -O3 -fomit-frame-pointer -pipe -s -mpentium -mcpu=pentium -march=pentium -f expensive-optimizations -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES=1 -D_LARGEFILE64_S OURCE=1 -DAP_HAVE_DESIGNATED_INITIALIZER -DLINUX=2 -D_REENTRANT -D_XOPEN_SOURCE= 500 -D_BSD_SOURCE -D_SVID_SOURCE -D_GNU_SOURCE -pthread -I/usr/include/apache - I/usr/include/apache -I/usr/include/apache -c -o mod_auth_sys_group.lo mod_a uth_sys_group.c && touch mod_auth_sys_group.slo
/home/httpd/build/libtool --silent --mode=link i586-trustix-linux-gcc -o mod_aut h_sys_group.la -rpath /usr/lib/apache -module -avoid-version mod_auth_sys_gr oup.lo -lpam
[email protected] /tmp/mod_auth_pam# make install
apxs -i mod_auth_pam.la mod_auth_sys_group.la
/home/httpd/build/instdso.sh SH_LIBTOOL='/home/httpd/build/libtool' mod_auth_pam .la /usr/lib/apache
/home/httpd/build/libtool --mode=install cp mod_auth_pam.la /usr/lib/apache/
cp .libs/mod_auth_pam.so /usr/lib/apache/mod_auth_pam.so
cp .libs/mod_auth_pam.lai /usr/lib/apache/mod_auth_pam.la
cp .libs/mod_auth_pam.a /usr/lib/apache/mod_auth_pam.a
ranlib /usr/lib/apache/mod_auth_pam.a
chmod 644 /usr/lib/apache/mod_auth_pam.a
PATH="$PATH:/sbin" ldconfig -n /usr/lib/apache
Libraries have been installed in:
/usr/lib/apache
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
- use the `-Wl,--rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
chmod 755 /usr/lib/apache/mod_auth_pam.so
/home/httpd/build/instdso.sh SH_LIBTOOL='/home/httpd/build/libtool' mod_auth_sys _group.la /usr/lib/apache
/home/httpd/build/libtool --mode=install cp mod_auth_sys_group.la /usr/lib/apach e/
cp .libs/mod_auth_sys_group.so /usr/lib/apache/mod_auth_sys_group.so
cp .libs/mod_auth_sys_group.lai /usr/lib/apache/mod_auth_sys_group.la
cp .libs/mod_auth_sys_group.a /usr/lib/apache/mod_auth_sys_group.a
ranlib /usr/lib/apache/mod_auth_sys_group.a
chmod 644 /usr/lib/apache/mod_auth_sys_group.a
/usr/lib/apache
during execution
during linking
chmod 755 /usr/lib/apache/mod_auth_sys_group.so
[ -d /etc/pam.d/ -a ! -f /etc/pam.d/httpd ] && install -m 644 -o root -g root sa mples/httpd /etc/pam.d/
make: *** [install] Error 1
