- ProFTPD Exclusivo
ProFTPD Exclusivo
Galera, estou precisando montar um servidor ftp anonimo.
E o seguinte, os usuarios podem copiar os arquivos e podem enviar tambem e criar pastas. Tambem preciso q so seja possivel logar como anonimo. Esta configuracao esta correta? Ha algum detalhe a acrescentar ou algo que precise ser corrigido? Obrigado!!!
# This sample configuration file illustrates configuring two
# anonymous directories, and a guest (same thing as anonymous but
# requires a valid password to login)
ServerName "Provider FTP Server"
ServerType standalone
DefaultServer on
# Port 21 is the standard FTP port.
Port 21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask 022
# If you don't want normal users logging in at all, uncomment this
# next section
<Limit LOGIN>
DenyAll
</Limit>
# Set the user and group that the server normally runs at.
User nobody
Group nogroup
# To cause every FTP user to be "jailed" (chrooted) into their home
# directory, uncomment this line.
DefaultRoot ~
# To prevent DoS attacks, set the maximum number of child processes
# to 30. If you need to allow more than 30 concurrent connections
# at once, simply increase this value. Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances 30
# Set the maximum number of seconds a data connection is allowed
# to "stall" before being aborted.
TimeoutStalled 300
# We want 'welcome.msg' displayed at login, and '.message' displayed
# in each newly chdired directory.
DisplayLogin welcome.msg
DisplayFirstChdir .message
# Normally, we want files to be overwriteable.
<Directory />
AllowOverwrite on
</Directory>
# Our "basic" anonymous configuration, including a single
# upload directory ("uploads")
<Anonymous ~ftp>
# Allow logins if they are disabled above.
<Limit LOGIN>
AllowAll
</Limit>
# Maximum clients with message
MaxClients 5 "Sorry, max %m users -- try again later"
User ftp
Group ftp
# We want clients to be able to login with "anonymous" as well as "ftp"
UserAlias anonymous ftp
# Limit WRITE everywhere in the anonymous chroot
<Limit WRITE>
DenyAll
</Limit>
# An upload directory that allows storing files but not retrieving
# or creating directories.
<Directory uploads/*>
<Limit READ>
DenyAll
</Limit>
<Limit STOR MKD XMKD>
AllowAll
</Limit>
</Directory>
</Anonymous>
