Opá pessoal, estou com problemas para instalar o freeradius 1.05
Quando inicio da erro, e colocando em modo debug tenho o seguinte erro abaixo!
[[email protected] raddb]# radiusd -X
Starting - reading configuration files ...
reread_config: reading radiusd.conf
Config: including file: /usr/local/etc/raddb/clients.conf
Config: including file: /usr/local/etc/raddb/snmp.conf
Config: including file: /usr/local/etc/raddb/eap.conf
Config: including file: /usr/local/etc/raddb/sql.conf
main: prefix = "/usr/local"
main: localstatedir = "/usr/local/var"
main: logdir = "/var/log/radius"
main: libdir = "/usr/local/lib"
main: radacctdir = "/var/log/radius/radacct"
main: hostname_lookups = no
main: max_request_time = 30
main: cleanup_delay = 5
main: max_requests = 1024
main: delete_blocked_requests = 0
main: port = 0
main: allow_core_dumps = no
main: log_stripped_names = no
main: log_file = "/var/log/radius/radius.log"
main: log_auth = yes
main: log_auth_badpass = yes
main: log_auth_goodpass = no
main: pidfile = "/usr/local/var/run/radiusd/radiusd.pid"
main: user = "nobody"
main: group = "nobody"
main: usercollide = no
main: lower_user = "no"
main: lower_pass = "no"
main: nospace_user = "no"
main: nospace_pass = "no"
main: checkrad = "/usr/local/sbin/checkrad"
main: proxy_requests = no
security: max_attributes = 200
security: reject_delay = 1
security: status_server = no
main: debug_level = 0
read_config_files: reading dictionary
Errors reading dictionary: dict_init: /usr/local/etc/raddb/dictionary[27]: unknown vendor -
Errors reading radiusd.conf
Alguém poderia dar uma luz?
Tentei varias coisas:
1 - permissoes
2 - checar caminhos
3 - comentar a linha do erro, linha 27 "ATTRIBUTE User-Name 1 string - [LR-RLR]"
4 - recompilei
5 - procurei na internet
Espero que alguem tenha passado por isso. Pra me dizer uma solução.
:toim: :toim: :toim:
