  1. Pessoal, meu squid de um problema e estou tentando entender o que aconteceu. De um dia para o outro ele passou a apresentar esse problema. Ele foi reiniciado de madrugada, acho que por falta de energia elétrica, não consegui encontrar indícios de invasão. Primeiro não conseguia fazer cache e depois ao tentar apagar o cache e criar novamente, ele não consegue nem mais iniciar. Acusa problemas de permissão de acesso a diversos arquivos.
    O usuário de acesso ao cache é o squid, grupo squid (uid 23).
    Ai a saida do comando squid -X -N -D (squid -z não consegue criar o swap):
    2005/09/17 18:17:31| fd_open FD 0 stdin
    2005/09/17 18:17:31| fd_open FD 1 stdout
    2005/09/17 18:17:31| fd_open FD 2 stderr
    2005/09/17 18:17:31| leave_suid: PID 15162 called
    2005/09/17 18:17:31| leave_suid: PID 15162 giving up root, becoming 'squid'
    WARNING: Cannot write log file: /var/log/squid/cache.log
    /var/log/squid/cache.log: Permission denied
    messages will be sent to 'stderr'.
    2005/09/17 18:17:31| WARNING: Closing open FD 2
    2005/09/17 18:17:31| Starting Squid Cache version 2.5.STABLE9 for i586-mandrake-linux-gnu...
    2005/09/17 18:17:31| Process ID 15162
    2005/09/17 18:17:31| With 1024 file descriptors available
    2005/09/17 18:17:31| parseEtcHosts: /etc/hosts: (13) Permission denied
    2005/09/17 18:17:31| DNS Socket created at 0.0.0.0, port 1028, FD 3
    2005/09/17 18:17:31| /etc/resolv.conf: (13) Permission denied
    2005/09/17 18:17:31| Warning: Could not find any nameservers. Trying to use localhost
    2005/09/17 18:17:31| Please check your /etc/resolv.conf file
    2005/09/17 18:17:31| or use the 'dns_nameservers' option in squid.conf.
    2005/09/17 18:17:31| User-Agent logging is disabled.
    2005/09/17 18:17:31| Referer logging is disabled.
    2005/09/17 18:17:31| errorTryLoadText: '/etc/squid/errors/ERR_READ_TIMEOUT': (13) Permission denied
    2005/09/17 18:17:31| errorTryLoadText: '/usr/squid/errors/ERR_READ_TIMEOUT': (13) Permission denied
    FATAL: failed to find or read error text file.
    Squid Cache (Version 2.5.STABLE9): Terminated abnormally.
    CPU Usage: 0.017 seconds = 0.011 user + 0.006 sys
    Maximum Resident Size: 0 KB
    Page faults with physical i/o: 0
    Aborted
    O swap está em /cache/squid , que é uma partição separada (montada em /cache) do mesmo HD.
    Já tentei de tudo alterando as permissões (chmod 777). Ai embaixo as permissões dos arquivos que apresentaram problema:
    # ls -l /etc/hosts /etc/resolv.conf /var/log/squid /etc/squid/errors/ERR_READ_TIMEOUT
    -rw-r--r-- 2 root root 187 Sep 16 11:11 /etc/hosts
    -rw-r--r-- 1 root root 190 Sep 6 05:29 /etc/resolv.conf
    -rwxr--r-- 1 squid squid 889 Sep 12 14:17 /etc/squid/errors/ERR_READ_TIMEOUT
    /var/log/squid:
    total 6
    drwxr-xr-x 2 squid squid 80 Sep 16 18:13 .
    drw-r----- 15 root root 2392 Sep 17 04:02 ..
    -rw-r----- 1 root root 610 Sep 16 18:14 squid.out
    O mesmo acontece com o apache, que diz não encotnrar o arquivo .htaccess, ai da erro de acesso. Só que no diretório raiz nunca usei .htaccess, pois o acesso a página principal era livre.
    Será problema do suid?
    Estou tentando resolver até para entender o que aconteceu, mas em todo caso vou reinstalar.
    Ah, uso o Mandrake 2005LE.
    antoniobrandao
    Parece que vc nao está com nenhum servidor dns especificado.
    Edite o /etc/resolv.conf e coloque uma linha:
    namseserver <IP>
    sendo <IP> o servidor dns seu
    acho que daí é só reiniciar o squid
  3. Não é este o problema não.
    Pior, fui reiniciar o named e agora este também parou de funcionar. Diz que não tem permissão de ler o resolv.conf. Parece que nenhum daemon funciona mais. Ele diz que roda como root, mas ai dá problema. O que pode ser?
    antoniobrandao
    Vc usa qual distro?
    veja se o selinux está ligado.
    Dentro de /etc/sysconfig/selinux
    altere para SELINUX=disabled
    depois tem que rebootar a maquina...
    Citação Postado originalmente por cleberlr
  5. Coloquei na mensagem. Uso o Mandrake 2005LE.
    Não tem o SELINUX. Não sei se porque não instalei (fiz uma instalação bem enxuta), mas tentei localizar em outros diretórios e não encontrei.
  1. Problemas com Squid
    Por doliveira no fórum Servidores de Rede
    Último Post: 16-06-2003, 18:06
  2. Respostas: 0
    Último Post: 07-06-2003, 13:20
  3. Problemas com squid
    Por _edinh0_ no fórum Servidores de Rede
    Último Post: 11-04-2003, 09:33
  4. Problemas com Squid
    Por egriga no fórum Servidores de Rede
    Respostas: 6
    Último Post: 17-02-2003, 20:12
  5. Problemas com squid e rota
    Por ATNunes no fórum Servidores de Rede
    Último Post: 10-02-2003, 11:22
