Bug em meu Kernel olhem meu log. Meu linux é um slackware 10.1 com kernel 2.4.29
Sep 16 16:58:51 bdados kernel: Linux version 2.4.29 ([email protected]) (gcc version 3.3.4) #6 Thu Jan 20 16:30:37 PST 2005
Sep 16 16:58:51 bdados kernel: BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
Sep 16 16:58:51 bdados kernel: BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
Sep 16 16:58:51 bdados kernel: BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Sep 16 16:58:51 bdados kernel: BIOS-e820: 0000000000100000 - 000000003fff0000 (usable)
Sep 16 16:58:51 bdados kernel: BIOS-e820: 000000003fff0000 - 000000003fff3000 (ACPI NVS)
Sep 16 16:58:51 bdados kernel: BIOS-e820: 000000003fff3000 - 0000000040000000 (ACPI data)
Sep 16 16:58:51 bdados kernel: BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
Sep 16 16:58:51 bdados kernel: Warning only 896MB will be used.
Sep 16 16:58:51 bdados kernel: Use a HIGHMEM enabled kernel.
Sep 16 16:58:51 bdados kernel: On node 0 totalpages: 229376
Sep 16 16:58:51 bdados kernel: zone(0): 4096 pages.
Sep 16 16:58:51 bdados kernel: zone(1): 225280 pages.
Sep 16 16:58:51 bdados kernel: zone(2): 0 pages.
Sep 16 16:58:51 bdados kernel: Kernel command line: BOOT_IMAGE=Linux ro root=302
Sep 16 16:58:51 bdados kernel: Detected 1666.223 MHz processor.
Sep 16 16:58:51 bdados kernel: Console: colour dummy device 80x25
Sep 16 16:58:51 bdados kernel: Calibrating delay loop... 3322.67 BogoMIPS
Sep 16 16:58:51 bdados kernel: Page-cache hash table entries: 262144 (order: 8, 1048576 bytes)
Sep 16 16:58:51 bdados kernel: CPU: AMD Athlon(tm) XP 2000+ stepping 01
Sep 16 16:58:51 bdados kernel: POSIX conformance testing by UNIFIX
Sep 16 16:58:51 bdados kernel: mtrr: v1.40 (20010327) Richard Gooch ([email protected])
Sep 16 16:58:51 bdados kernel: mtrr: detected mtrr type: Intel
Sep 16 16:58:51 bdados kernel: PCI: Probing PCI hardware (bus 00)
Sep 16 16:58:51 bdados kernel: Initializing RT netlink socket
Sep 16 16:58:51 bdados kernel: Starting kswapd
Sep 16 16:58:51 bdados kernel: Console: switching to colour frame buffer device 128x48
Sep 16 16:58:51 bdados kernel: pty: 512 Unix98 ptys configured
Sep 16 16:58:51 bdados kernel: keyboard: Timeout - AT keyboard not present?(ed)
Sep 16 16:58:51 bdados kernel: RAMDISK driver initialized: 16 RAM disks of 7777K size 1024 blocksize
Sep 16 16:58:51 bdados kernel: hda: MAXTOR 4K040H2, ATA DISK drive
Sep 16 16:58:51 bdados kernel: blk: queue c03ad460, I/O limit 4095Mb (mask 0xffffffff)
Sep 16 16:58:51 bdados kernel: ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Sep 16 16:58:51 bdados kernel: hda: attached ide-disk driver.
Sep 16 16:58:51 bdados kernel: hda: host protected area => 1
Sep 16 16:58:51 bdados kernel: kmod: failed to exec /sbin/modprobe -s -k scsi_hostadapter, errno = 2
Sep 16 16:58:51 bdados last message repeated 2 times
Sep 16 16:58:51 bdados kernel: 8regs : 2388.400 MB/sec
Sep 16 16:58:51 bdados kernel: 32regs : 1591.600 MB/sec
Sep 16 16:58:51 bdados kernel: pIII_sse : 4524.800 MB/sec
Sep 16 16:58:51 bdados kernel: pII_mmx : 3899.200 MB/sec
Sep 16 16:58:51 bdados kernel: p5_mmx : 4982.000 MB/sec
Sep 16 16:58:51 bdados kernel: raid5: using function: pIII_sse (4524.800 MB/sec)
Sep 16 16:58:51 bdados kernel: FAT: bogus logical sector size 0
Sep 16 16:58:51 bdados kernel: reiserfs: found format "3.6" with standard journal
Sep 16 16:58:51 bdados kernel: reiserfs: checking transaction log (device ide0(3,2)) ...
Sep 16 16:58:51 bdados kernel: for (ide0(3,2))
Sep 16 16:58:51 bdados kernel: reiserfs: replayed 5 transactions in 0 seconds
Sep 16 16:58:51 bdados kernel: ide0(3,2):Using r5 hash to sort names
Sep 16 16:58:51 bdados kernel: VFS: Mounted root (reiserfs filesystem) readonly.
Sep 16 16:58:51 bdados kernel: reiserfs: checking transaction log (device ide0(3,3)) ...
Sep 16 16:58:51 bdados kernel: for (ide0(3,3))
Sep 16 16:58:51 bdados kernel: ide0(3,3):Using r5 hash to sort names
Sep 16 16:58:52 bdados cardmgr[77]: no pcmcia driver in /proc/devices
Sep 16 16:58:52 bdados kernel: 3c59x: Donald Becker and others. www.scyld.com/network/vortex.html
Sep 16 16:58:54 bdados kernel: shpchp: shpc_init : shpc_cap_offset == 0
Sep 16 16:58:54 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/shpchp.o.gz: init_module: No such device
Sep 16 16:58:54 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/shpchp.o.gz: Hint: insmod errors can be caused by in
correct module parameters, including invalid IO or IRQ parameters. You may find more information in syslog or the output
from dmesg
Sep 16 16:58:54 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/shpchp.o.gz: insmod shpchp failed
Sep 16 16:58:54 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/pciehp.o.gz: init_module: No such device
Sep 16 16:58:54 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/pciehp.o.gz: Hint: insmod errors can be caused by in
from dmesg
Sep 16 16:58:54 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/pciehp.o.gz: insmod pciehp failed
from dmesg
from dmesg
from dmesg
from dmesg
Sep 16 16:58:55 bdados kernel: shpchp: shpc_init : shpc_cap_offset == 0
Sep 16 16:58:55 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/shpchp.o.gz: init_module: No such device
Sep 16 16:58:55 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/shpchp.o.gz: Hint: insmod errors can be caused by in
from dmesg
Sep 16 16:58:55 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/shpchp.o.gz: insmod shpchp failed
Sep 16 16:58:55 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/pciehp.o.gz: init_module: No such device
Sep 16 16:58:55 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/pciehp.o.gz: Hint: insmod errors can be caused by in
from dmesg
Sep 16 16:58:55 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/pciehp.o.gz: insmod pciehp failed
from dmesg
from dmesg
from dmesg
from dmesg
Sep 16 16:58:56 bdados kernel: shpchp: shpc_init : shpc_cap_offset == 0
Sep 16 16:58:56 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/shpchp.o.gz: init_module: No such device
Sep 16 16:58:56 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/shpchp.o.gz: Hint: insmod errors can be caused by in
from dmesg
Sep 16 16:58:56 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/shpchp.o.gz: insmod shpchp failed
Sep 16 16:58:56 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/pciehp.o.gz: init_module: No such device
Sep 16 16:58:56 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/pciehp.o.gz: Hint: insmod errors can be caused by in
from dmesg
Sep 16 16:58:56 bdados insmod: /lib/modules/2.4.29/kernel/drivers/hotplug/pciehp.o.gz: insmod pciehp failed
from dmesg
from dmesg
from dmesg
from dmesg
from dmesg
from dmesg
