    eltern
    Padrão vmware no suse 9.3 - abortando
    Ola pessoal.
    Estou tentando configurar o VMWARE 5 no SuSE 9.3 , mas em todas as tentativas ocorre a seguinte mensagem
    Código :
    Configuring fallback GTK+ 2.4 libraries.
    * Updating MIME database in /usr/share/mime...
    In which directory do you want to install the mime type icons?
    [/usr/share/icons]
    What directory contains your desktop menu entry files? These files have a
    .desktop file extension. [/usr/share/applications]
    In which directory do you want to install the application's icon?
    [/usr/share/pixmaps]
    Trying to find a suitable vmmon module for your running kernel.
    None of the pre-built vmmon modules for VMware Workstation is suitable for your
    running kernel.  Do you want this program to try to build the vmmon module for
    your system (you need to have a C compiler installed on your system)? [yes]
    Using compiler "/usr/bin/gcc". Use environment variable CC to override.
    What is the location of the directory of C header files that match your running
    kernel? [/usr/src/linux/include]
    Extracting the sources of the vmmon module.
    Building the vmmon module.
    Using 2.6.x kernel build system.
    make: Entering directory `/tmp/vmware-config0/vmmon-only'
    make -C /usr/src/linux/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. modules
    make[1]: Entering directory `/usr/src/linux-2.6.11.4-21.9'
    Makefile:494: .config: No such file or directory
    WARNING: Symbol version dump /usr/src/linux-2.6.11.4-21.9/Module.symvers is  missing; modules will have no modversions.
      CC [M]  /tmp/vmware-config0/vmmon-only/linux/driver.o
    /bin/sh: scripts/basic/fixdep: No such file or directory
    make[2]: *** [/tmp/vmware-config0/vmmon-only/linux/driver.o] Error 1
    make[1]: *** [_module_/tmp/vmware-config0/vmmon-only] Error 2
    make[1]: Leaving directory `/usr/src/linux-2.6.11.4-21.9'
    make: *** [vmmon.ko] Error 2
    make: Leaving directory `/tmp/vmware-config0/vmmon-only'
    Unable to build the vmmon module.
    For more information on how to troubleshoot module-related problems, please
    visit our Web site at "http://www.vmware.com/download/modules/modules.html" and
    "http://www.vmware.com/support/reference/linux/prebuilt_modules_linux.html".
    Execution aborted.
    Alguem ja se deparo uco isso e consegui passar ?
    Obrigado dede já.
    eltern
    Ou Galera >> consegui solução aqui.
    cd /usr/src/linux
    make cloneconfig
    make prepare
    vmware-config.pl
    Dai foi tranquilo.
    -thiago-
    Fala Eltern, tive o mesmo problema, e a solução não me lembro exatamente, mas foi parecida, agora no SLES 9 não houve nenhum prob. com o VM5.
    Abraços,
    Thiago
    Padrão Re: vmware no suse 9.3 - abortando
    Citação Postado originalmente por eltern
    Ola pessoal.
    Código :
    [/usr/share/icons]
    Execution aborted.
    Obrigado dede já.
