    Padrão Erro Kylix 3
    Olá pessoal estou tentando instalar o Kylix 3 no Fedora core 4, mas estou com dificuldades e são as seguintes:
    quando executo ./setup.sh ele faz o seguinte
    BORLAND KYLIX 3
    Checking dependencies...
    WARNING: could not locate libX11.so
    Kernel version >= 2.2.0....OK
    Glibc version >= 2.1.2....OK
    X11 Server....OK
    Libjpeg version >= 6.2.0....OK
    Libgtk version >= 1.2.0....OK
    ----====== Borland Kylix 3 installation program ======----
    You are running a x86 machine with glibc-2.1 or later.
    Hit Control-C anytime to cancel this installation program.
    ..... Aqui entra na licença
    Do you agree with the license? [Y/n]
    Would you like to read the README file ? [Y/n]
    ..... Aqui entra no README
    Please enter the installation path [/usr/local/kylix3]
    Please enter the path in which to create the symbolic links [/usr/local/bin]
    Install Main Program Files? [Y/n/?]
    Install dbExpress (includes InterBase and MySQL drivers)? [Y/n/?]
    Install dbExpress Oracle Driver? [Y/n/?]
    Install dbExpress DB2 Driver? [Y/n/?]
    Install dbExpress Informix Driver? [Y/n/?]
    Install dbExpress PostgreSQL Driver? [Y/n/?]
    Install Help Files? [Y/n/?]
    Install Internet Components? [Y/n/?]
    Install WebSnap? [Y/n/?]
    Install Mozilla Preview Widget? [Y/n/?]
    Install Web Services? [Y/n/?]
    Install VisiBroker/CORBA Components for Delphi? [N/y/?]
    Do you want to install GNOME/KDE menu items? [Y/n]
    Installing to /usr/local/kylix3
    618 MB available, 439 MB will be installed.
    Continue install? [Y/n]
    erro: Failed dependencies:
    libstdc++-libc6.1-1.so.2 is needed by kylix3_main_program_files-1.0-1.i386
    Unable to install RPM file: 'setup.data/packages/kylix3_main_program_files-1.0-1.i386.rpm'
    An error has occurred during installation.
    Error Code: -10
    Setup cannot continue.
    If this error persists, please contact technical support.
    Install aborted - cleaning up files
    Alguem sabe resolver esse problema?
    Depois tentei executar ./setup.sh -m
    dai parece que instalou mas quando tento executar startdelphi dah o seguinte erro
    /usr/local/kylix3/bin/delphi: error while loading shared libraries: /usr/local/kylix3/bin/libkernel32.borland.so: cannot restore segment prot after reloc: Permission denied
    Padrão Erro Kylix 3
    Qual a versão do seu kernel?
    Se não me engano o Kylix não funciona na série 2.6 ... não tenho certeza.
    Qualquer coisa tenta dar uma olhada no Lazarus. É bastante parecido com o Kylix, com a diferença de que o Lazarus ainda é desenvolvido(ao contrário do Kylix).
    Padrão Erro Kylix 3
    Desculpe-me entrar nesse tópico.
    Mas também sugiro isso. Veja o site www.lazarus.freepascal.org.
    É o Delphi prá Linux. Está em franco desenvolvimento. Pelo menos está em desenvolvimento. Infelizmente o Kylix parou.
    Dê uma olhada no Lazarus. É o Delphi mesmo ....... mas ainda é um projeto embrião. Mas já tem bastante usuários utilizando.
    E vou até um pouco mais além. Vendo as respostas aqui no Underlinux, sobre isso. Entre o Delphi e o Lazarus, me sugeriram aprender o Java. É claro que o aprendizado, leva tempo, e imagino que você é claro quer uma resposta imediata sobre o seu tópico. Achei interessante no Java o fato de ser independente de plataforma. Eu particularmente estou tentando aprender Java pelo fato de poder usar no Linux e esquecer a outra plataforma M$. E poder utilizar nas duas plataformas.
    Mas sei lá caro amigo, dê uma busca no google sobre Kylix e veja quantos fóruns vais encontrar. Tem vários. Mas aí veja as últimas datas do fórum. Normalmente está em 2002, talvez 2004. Ou seja, os membros também desistiram. Afinal o software já está descontinuado. A sua busca é insólita e heróica.
    Não estou aqui te desanimando. Mas você está correndo atrás quase que sózinho.
    Inté amigo e que Deus te abençõe ........ :good:
