-  Horde3/imp4/turba2.2
					 Horde3/imp4/turba2.2 Horde3/imp4/turba2.2
							Aew Galera..
 Següenteee..
 Instalei o Horde3 com o Imp4 para webmail.. até aí beleza.. ele ta funcionando que é uma magavilha.. só o problema é com o turba.. o gerenciador de contatos... escolhi a opcao pra ele gravar no mysql.. no meu caso.. o sources.php ficou da seguinte forma:
 *sources.php
 <?php
 $cfgSources['localsql'] = array(
 'title' => _("My Addressbook"),
 'type' => 'sql',
 // The default connection details are pulled from the Horde-wide SQL
 // connection configuration.
 // The old example illustrates how to use an alternate database
 // configuration.
 // New Example:
 'params' => array_merge($conf['sql'], array('table' => 'turba_objects')),
 // Old Example:
 // 'params' => array(
 //     'phptype' => 'mysql',
 //     'hostspec' => 'localhost',
 //     'username' => 'horde',
 //     'password' => '*****',
 //     'database' => 'horde',
 //     'table' => 'turba_objects',
 //     'charset' => 'iso-8859-1'
 'map' => array(
 '__key' => 'object_id',
 '__owner' => 'owner_id',
 '__type' => 'object_type',
 '__members' => 'object_members',
 '__uid' => 'object_uid',
 'name' => 'object_name',
 'email' => 'object_email',
 'alias' => 'object_alias',
 'homeAddress' => 'object_homeaddress',
 'workAddress' => 'object_workaddress',
 'homePhone' => 'object_homephone',
 'workPhone' => 'object_workphone',
 'cellPhone' => 'object_cellphone',
 'fax' => 'object_fax',
 'title' => 'object_title',
 'company' => 'object_company',
 'notes' => 'object_notes',
 'pgpPublicKey' => 'object_pgppublickey',
 'smimePublicKey' => 'object_smimepublickey',
 'freebusyUrl' => 'object_freebusyurl'
 'search' => array(
 'name',
 'email'
 'strict' => array(
 'object_id',
 'owner_id',
 'object_type',
 'public' => false,
 'readonly' => false,
 'admin' => array(),
 'export' => true
 $cfgSources['prefs'] = array(
 'title' => _("Private Address Book"),
 'type' => 'prefs',
 'params' => array(
 'name' => 'prefs',
 'charset' => NLS::getCharset()
 'map' => array(
 '__key' => 'id',
 '__type' => '_type',
 '__members' => '_members',
 '__uid' => 'uid',
 'name' => 'name',
 'email' => 'mail',
 'alias' => 'alias'
 'search' => array(
 'name',
 'email',
 'alias'
 'strict' => array(
 'id',
 '_type',
 'public' => false,
 'export' => true
 Só que a bagaça é a seguinte... meus contatos são adicionados e tudo mais.. só que ele fica compartilhado entre todos os clientes do webmail.. ou seja.. eu adiciono um contato.. e todos os outros conseguem vê-lo..
 Entao.. gostaria de saber se alguem ja instalou e se deu o mesmo pau.. ou sabe o que eu to fazendo de errado?!
 Valeu Under's!
