    thiagog
    Padrão IPTABLES me deixando louco . . .
    ola gente tudo bom ?
    tenho um fw iptables com 3 interfaces de rede eth0 -> internet; eth1 -> dmz e eth2 -> lan
    como faco para ajustar minhas regras?
    regras
    regras
    #!/bin/bash
    #limpando tabelas
    iptables -F &&
    iptables -X &&
    iptables -t nat -F &&
    iptables -t nat -X &&
    #variaveis de ambiente
    lan="172.16.0.0/16"
    dmz="10.10.0.0/16"
    int_ext="200.200.200.162"
    int_dmz="10.10.10.30"
    int_interna="172.16.0.1"
    suporte="200.200.100.5"
    ### libera o PROXY squid para internet
    iptables -A INPUT -s 10.10.10.51 -j ACCEPT
    iptables -A FORWARD -s 10.10.10.51 -j ACCEPT
    iptables -A OUTPUT -s 10.10.10.51 -j ACCEPT
    ### Libera o loopback
    iptables -A OUTPUT -p tcp --syn -s 127.0.0.1/255.0.0.0 -j ACCEPT
    ### saida
    iptables -A OUTPUT -j ACCEPT &&
    ### libera tudo entre lan e dmz
    iptables -A INPUT -s $lan -d $dmz -j ACCEPT
    iptables -A FORWARD -s $lan -d $dmz -j ACCEPT
    iptables -A OUTPUT -s $lan -d $dmz -j ACCEPT
    iptables -A INPUT -s $dmz -d $lan -j ACCEPT
    iptables -A FORWARD -s $dmz -d $lan -j ACCEPT
    iptables -A OUTPUT -s $dmz -d $lan -j ACCEPT
    ### libera tudo da dmz para INTERNET
    iptables -A INPUT -s $lan -d 0/0 -j ACCEPT
    iptables -A FORWARD -s $lan -d 0/0 -j ACCEPT
    iptables -A OUTPUT -s $lan -d 0/0 -j ACCEPT
    #liberando acesso interno da rede
    ####################### TOTAL
    #Ip's que devem ser liberados:
    user1=100.100.100.20
    user2=100.100.100.117
    for i in $user1 $user2
    do
    iptables -A FORWARD -s $i -d 0.0.0.0/0 -p tcp -j ACCEPT
    iptables -A FORWARD -d $i -p tcp -j ACCEPT
    iptables -A FORWARD -s $i -d 0.0.0.0/0 -p udp -j ACCEPT
    iptables -A FORWARD -d $i -p udp -j ACCEPT
    iptables -A FORWARD -s $i -d 0.0.0.0/0 -p icmp -j ACCEPT
    iptables -A FORWARD -d $i -p icmp -j ACCEPT
    done
    ####################### PARCIAL - MSN
    user3=100.100.100.104
    user4=100.100.100.103
    for j in $user3 $user4
    do
    iptables -A FORWARD -s $j -d 0.0.0.0/0 -p tcp -m multiport --dport 25,53,80,110,443,8080 -j ACCEPT
    iptables -A FORWARD -d $j -p tcp -m multiport --sport 25,53,80,110,443,8080 -j ACCEPT
    iptables -A FORWARD -s $j -d 0.0.0.0/0 -p udp --dport 53 -j ACCEPT
    iptables -A FORWARD -d $j -p udp --sport 53 -j ACCEPT
    ### msn
    iptables -A FORWARD -s $j -p tcp --dport 1863 -j ACCEPT
    iptables -A FORWARD -s $j -d loginnet.passport.com -j ACCEPT
    iptables -A FORWARD -s $j -d webmessenger.msn.com -j ACCEPT
    done
    ####################### FIM - PARCIAL - MSN
    ####################### REDE 172.16/16
    REDEINTERNA="172.16.0.0/16"
    for ri in $REDEINTERNA
    do
    iptables -A FORWARD -s $ri -d 0.0.0.0/0 -p tcp -m multiport --dport 25,53,80,110,443,8080 -j ACCEPT
    iptables -A FORWARD -d $ri -p tcp -m multiport --sport 25,53,80,110,443,8080 -j ACCEPT
    iptables -A FORWARD -s $ri -d 0.0.0.0/0 -p udp --dport 53 -j ACCEPT
    iptables -A FORWARD -d $ri -p udp --sport 53 -j ACCEPT
    done
    ####################### FIM REDE 172.16/16
    #nat PROXY redirecionamento SQUID
    iptables -t nat -A PREROUTING -i eth2 -s 100.100.100.7 -p tcp --dport 80 -j DNAT --to 10.10.10.51:3128
    ####################### NAT 1:1
    iptables -A PREROUTING -t nat -d 200.200.200.163 -j DNAT --to 10.10.10.50
    iptables -A POSTROUTING -t nat -s 10.10.10.50 -j SNAT --to 200.200.200.163
    ############# REGRAS PARA OS NATS #############
    iptables -A FORWARD -d 200.200.200.163 -p tcp -dport 80 -j ACCEPT
    iptables -A FORWARD -d 200.200.200.163 -p tcp -dport 443 -j ACCEPT
    iptables -A FORWARD -d 200.200.200.163 -p tcp -dport 25 -j ACCEPT
    iptables -A FORWARD -d 200.200.200.163 -p tcp -dport 110 -j ACCEPT
    iptables -A FORWARD -d 200.200.200.163 -p tcp -dport 143 -j ACCEPT
    iptables -A FORWARD -d 200.200.200.163 -p tcp -dport 993 -j ACCEPT
    iptables -A FORWARD -d 200.200.200.163 -p tcp -dport 995 -j ACCEPT
    #compartilhando a web na rede interna
    iptables -t nat -A POSTROUTING -s 172.16.0.0/255.255.0.0 -o eth0 -j MASQUERADE &&
    iptables -t nat -A POSTROUTING -s 10.10.0.0/255.255.0.0 -o eth0 -j MASQUERADE &&
    echo 1 > /proc/sys/net/ipv4/ip_forward &&
    # Protecao contra port scanners ocultos
    #iptables -A INPUT -p tcp --tcp-flags SYN,ACK,FIN,RST RST -m limit --limit 1/s -j ACCEPT
    # Bloqueando tracertroute
    #iptables -A INPUT -p udp -s 0/0 -i eth1 --dport 33435:33525 -j DROP
    #Protecoes contra ataques
    #iptables -A INPUT -m state --state INVALID -j DROP
    ### bloqueia TODO o resto
    iptables -A INPUT -j DROP &&
    iptables -A FORWARD -j DROP &&
    #Configura aliases
    /etc/sysconfig/aliases.sh &&
    Avenger
    Depende do que você quer ajustar nela...
    A princípio é só você, sabendo o que quer mudar, adicionar a linha antes das DROP ou, no final do arquivo, adicionar com o comando -I no lugar de -A (o -I faz a linha do iptables entrar antes de todas da corrente que você instalou). Falei grego? Cada Corrente tem uma ordem em que ela passa, é bom você saber inglês ou pegar um dicionário, correr no linux e dar uma olhada no texto exibido pelo comando man iptables. Ali é explicado onde o pacote entra primeiro e onde ele passa por último, e -se- passa por tal corrente.
    Pela pergunta, pareceu também que você não é nada familiarizado com o IPTables... Prá mecher nessas regras do script, você vai ter que entender o que cada linha que começa com 'iptables' faz -- a fundo.
    Após modificar o arquivo, para testar as opções sem reiniciar o servidor, você pode fazer:
    iptables -F -t nat ; iptables -F -t mangle ; iptables -F ; /root/scriptzinhodefirewall.sh
    (claro, o que tem depois do último ponto-e-vírgula deve ser alterado para o caminho e nome-de-arquivo do seu script de firewall.. Isso aí vai limpar as regras e reinseri-las com as novas regras ou ajustes.
    cara...
    tipo.. o script postado tah bem bagunçado...
    talvez eu esteja errado, mas a pessoa q fez o script nao manja muito de iptables...
    e vc quer ajuda pra ajustar as regras..
    mas.. ajustar oq?? o script todo??
    isso nao seria ajuda, seria fazer a coisa pra vc...
    lógico q estamos aqui para ajudar, mas a melhor coisa eh ajudar em dúvidas...
    fazendo a coisa pra vc vc nao aprenderia.. e nos tomaria muito tempo...
    acredito q se vc ler a parte de iptbles do www.guiafoca.org vc entenderá muita coisa...
    o comando está bem esplanado neste guia, e vc entenderá muita coisa....
    depois q vc fizer isso, e surgerem as duvidas, poste-as aqui...
    valew
