  1. ESTAVA USANDO O GNOME MAIS DEREPENTE TÁ DANDO UM ERRO QUANDO TENTO ENTRAR NO GNOME
    gnome
    XFree86 Version 4.3.0
    Release Date: 27 February 2003
    X Protocol Version 11, Revision 0, Release 6.6
    Build Operating System: Linux 2.4.20-26373clenterprise i686 [ELF]
    Build Date: 23 March 2003
    Before reporting problems, check http://www.XFree86.Org/
    to make sure that you have the latest version.
    Module Loader present
    Markers: (--) probed, (**) from config file, (==) default setting,
    (++) from command line, (!!) notice, (II) informational,
    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
    (==) Log file: "/var/log/XFree86.0.log", Time: Tue Oct 11 17:21:05 2005
    (==) Using config file: "/etc/X11/XF86Config-4"
    (EE) Failed to load module "glx" (module does not exist, 0)
    (EE) Failed to load module "dri" (module does not exist, 0)
    (EE) Failed to load module "freetype" (module does not exist, 0)
    (EE) Mouse0: Unknown protocol "imps2"
    (EE) PreInit failed for input device "Mouse0"
    No core pointer
    Fatal server error:
    failed to initialize core devices
    When reporting a problem related to a server crash, please send
    the full server output, not just the last messages.
    This can be found in the log file "/var/log/XFree86.0.log".
    Please report problems to xfree86@distro.conectiva.com.br.
    XIO: fatal IO error 104 (Connection reset by peer) on X server ":0.0"
    after 0 requests (0 known processed) with 0 events remaining.
    Como faço pra iniciar o gnome como estava antes?
    pre-feit0
    Existe um arquivo chamado /etc/X11/XF86Config-4
    Nele estão armazenadas as informações para subir o servidor X.
    Ta vendo a linha:
    No core pointer
    Ela significa: pau no mouse! hehehe
    Você pode tentar trocar o protocolo para auto, IMPS/2 (letra maiuscula) ou para qualquer outro que achar na net.
    Tem também outra alternativa:
    https://under-linux.org/noticia5221.html
    Boa sorte.
  1. Respostas: 10
    Último Post: 10-10-2010, 18:31
  2. Erro do gnome-Detectei um painel já em uso e vou sair agora
    Por Duca no fórum Servidores de Rede
    Último Post: 25-01-2006, 11:13
  3. erro executando algumas coisas no Gnome
    Último Post: 11-11-2003, 08:16
  4. Erro na aplicação "gnome-panel"
    Último Post: 16-05-2003, 18:48
  5. Erro - na aplicação "gnome-panel"
    Último Post: 09-05-2003, 17:10
