    Padrão PostFix + SASL2 PROBLEMAS
    Galera, eu estou conseguindo usar a autenticação smtp, mas quando o problema é o seguinte, ele está aceitando logon anonimo no meu servidor de SMTP.
    Já fiz os seguintes teste.
    1 - Logon com um usuario correto.
    2 - Logon com um usuario incorreto - ñ logou.
    3 - Sem autenticação - logou.
    Olhem os meus arquivos de confs.
    Postfix:
    smtpd_sasl_auth_enable = yes
    smtpd_sasl_security_options = noanonymous
    broken_sasl_auth_clients = yes
    smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination
    SASL2:
    pwcheck_method: saslauthd
    valeu!!!
    tenta colocar assim:
    Código :
    smtpd_sasl_local_domain =
            permit_mynetworks,
            reject_unlisted_recipient,
            reject_unlisted_sender,
            reject_unauth_destination,
            reject_unknown_sender_domain,
            reject_non_fqdn_sender,
            reject_non_fqdn_recipient,
            reject_unknown_recipient_domain,
            reject_unauth_pipelining,
            reject_maps_rbl,
            check_relay_domains,
    Mesma coisa cara...
    posta o main.cf
    Eu mudei as linhas do SASL2 pq eu estou tentando algo diferente... mas nao dá...valeu!
    # Global Postfix configuration file. This file lists only a subset
    # of all 300+ parameters. See the postconf(5) manual page for a
    # complete list.
    # The general format of each line is: parameter = value. Lines
    # that begin with whitespace continue the previous line. A value can
    # contain references to other $names or ${name}s.
    # NOTE - CHANGE NO MORE THAN 2-3 PARAMETERS AT A TIME, AND TEST IF
    # POSTFIX STILL WORKS AFTER EVERY CHANGE.
    # SOFT BOUNCE
    # The soft_bounce parameter provides a limited safety net for
    # testing. When soft_bounce is enabled, mail will remain queued that
    # would otherwise bounce. This parameter disables locally-generated
    # bounces, and prevents the SMTP server from rejecting mail permanently
    # (by changing 5xx replies into 4xx replies). However, soft_bounce
    # is no cure for address rewriting mistakes or mail routing mistakes.
    #soft_bounce = no
    # LOCAL PATHNAME INFORMATION
    # The queue_directory specifies the location of the Postfix queue.
    # This is also the root directory of Postfix daemons that run chrooted.
    # See the files in examples/chroot-setup for setting up Postfix chroot
    # environments on different UNIX systems.
    queue_directory = /var/spool/postfix
    # The command_directory parameter specifies the location of all
    # postXXX commands.
    command_directory = /usr/sbin
    # The daemon_directory parameter specifies the location of all Postfix
    # daemon programs (i.e. programs listed in the master.cf file). This
    # directory must be owned by root.
    daemon_directory = /usr/libexec/postfix
    # QUEUE AND PROCESS OWNERSHIP
    # The mail_owner parameter specifies the owner of the Postfix queue
    # and of most Postfix daemon processes. Specify the name of a user
    # account THAT DOES NOT SHARE ITS USER OR GROUP ID WITH OTHER ACCOUNTS
    # AND THAT OWNS NO OTHER FILES OR PROCESSES ON THE SYSTEM. In
    # particular, don't specify nobody or daemon. PLEASE USE A DEDICATED
    # USER.
    mail_owner = postfix
    # The default_privs parameter specifies the default rights used by
    # the local delivery agent for delivery to external file or command.
    # These rights are used in the absence of a recipient user context.
    # DO NOT SPECIFY A PRIVILEGED USER OR THE POSTFIX OWNER.
    #default_privs = nobody
    # INTERNET HOST AND DOMAIN NAMES
    # The myhostname parameter specifies the internet hostname of this
    # mail system. The default is to use the fully-qualified domain name
    # from gethostname(). $myhostname is used as a default value for many
    # other configuration parameters.
    myhostname = paulvandyk.intranet.int.br
    myhostname = intranet.int.br
    # The mydomain parameter specifies the local internet domain name.
    # The default is to use $myhostname minus the first component.
    # $mydomain is used as a default value for many other configuration
    # parameters.
    mydomain = intranet.int.br
    # SENDING MAIL
    # The myorigin parameter specifies the domain that locally-posted
    # mail appears to come from. The default is to append $myhostname,
    # which is fine for small sites. If you run a domain with multiple
    # machines, you should (1) change this to $mydomain and (2) set up
    # a domain-wide alias database that aliases each user to
    # [email protected]host.
    # For the sake of consistency between sender and recipient addresses,
    # myorigin also specifies the default domain name that is appended
    # to recipient addresses that have no @domain part.
    #myorigin = $myhostname
    #myorigin = $mydomain
    # RECEIVING MAIL
    # The inet_interfaces parameter specifies the network interface
    # addresses that this mail system receives mail on. By default,
    # the software claims all active interfaces on the machine. The
    # parameter also controls delivery of mail to [email protected][ip.address].
    # See also the proxy_interfaces parameter, for network addresses that
    # are forwarded to us via a proxy or network address translator.
    # Note: you need to stop/start Postfix when this parameter changes.
    #inet_interfaces = all
    #inet_interfaces = $myhostname
    #inet_interfaces = $myhostname, localhost
    # The proxy_interfaces parameter specifies the network interface
    # addresses that this mail system receives mail on by way of a
    # proxy or network address translation unit. This setting extends
    # the address list specified with the inet_interfaces parameter.
    # You must specify your proxy/NAT addresses when your system is a
    # backup MX host for other domains, otherwise mail delivery loops
    # will happen when the primary MX host is down.
    #proxy_interfaces =
    #proxy_interfaces = 1.2.3.4
    # The mydestination parameter specifies the list of domains that this
    # machine considers itself the final destination for.
    # These domains are routed to the delivery agent specified with the
    # local_transport parameter setting. By default, that is the UNIX
    # compatible delivery agent that lookups all recipients in /etc/passwd
    # and /etc/aliases or their equivalent.
    # The default is $myhostname + localhost.$mydomain. On a mail domain
    # gateway, you should also include $mydomain.
    # Do not specify the names of virtual domains - those domains are
    # specified elsewhere (see VIRTUAL_README).
    # Do not specify the names of domains that this machine is backup MX
    # host for. Specify those names via the relay_domains settings for
    # the SMTP server, or use permit_mx_backup if you are lazy (see
    # STANDARD_CONFIGURATION_README).
    # The local machine is always the final destination for mail addressed
    # to [email protected][the.net.work.address] of an interface that the mail system
    # receives mail on (see the inet_interfaces parameter).
    # Specify a list of host or domain names, /file/name or type:table
    # patterns, separated by commas and/or whitespace. A /file/name
    # pattern is replaced by its contents; a type:table is matched when
    # a name matches a lookup key (the right-hand side is ignored).
    # Continue long lines by starting the next line with whitespace.
    # See also below, section "REJECTING MAIL FOR UNKNOWN LOCAL USERS".
    mydestination = $myhostname, localhost.$mydomain, localhost
    #mydestination = $myhostname, localhost.$mydomain, localhost, $mydomain
    #mydestination = $myhostname, localhost.$mydomain, localhost, $mydomain,
    # mail.$mydomain, www.$mydomain, ftp.$mydomain
    # REJECTING MAIL FOR UNKNOWN LOCAL USERS
    # The local_recipient_maps parameter specifies optional lookup tables
    # with all names or addresses of users that are local with respect
    # to $mydestination, $inet_interfaces or $proxy_interfaces.
    # If this parameter is defined, then the SMTP server will reject
    # mail for unknown local users. This parameter is defined by default.
    # To turn off local recipient checking in the SMTP server, specify
    # local_recipient_maps = (i.e. empty).
    # The default setting assumes that you use the default Postfix local
    # delivery agent for local delivery. You need to update the
    # local_recipient_maps setting if:
    # - You define $mydestination domain recipients in files other than
    # /etc/passwd, /etc/aliases, or the $virtual_alias_maps files.
    # For example, you define $mydestination domain recipients in
    # the $virtual_mailbox_maps files.
    # - You redefine the local delivery agent in master.cf.
    # - You redefine the "local_transport" setting in main.cf.
    # - You use the "luser_relay", "mailbox_transport", or "fallback_transport"
    # feature of the Postfix local delivery agent (see local(8)).
    # Details are described in the LOCAL_RECIPIENT_README file.
    # Beware: if the Postfix SMTP server runs chrooted, you probably have
    # to access the passwd file via the proxymap service, in order to
    # overcome chroot restrictions. The alternative, having a copy of
    # the system passwd file in the chroot jail is just not practical.
    # The right-hand side of the lookup tables is conveniently ignored.
    # In the left-hand side, specify a bare username, an @domain.tld
    # wild-card, or specify a [email protected] address.
    #local_recipient_maps = unixasswd.byname $alias_maps
    #local_recipient_maps = proxy:unixasswd.byname $alias_maps
    # The unknown_local_recipient_reject_code specifies the SMTP server
    # response code when a recipient domain matches $mydestination or
    # ${proxy,inet}_interfaces, while $local_recipient_maps is non-empty
    # and the recipient address or address local-part is not found.
    # The default setting is 550 (reject mail) but it is safer to start
    # with 450 (try again later) until you are certain that your
    # local_recipient_maps settings are OK.
    unknown_local_recipient_reject_code = 550
    # TRUST AND RELAY CONTROL
    # The mynetworks parameter specifies the list of "trusted" SMTP
    # clients that have more privileges than "strangers".
    # In particular, "trusted" SMTP clients are allowed to relay mail
    # through Postfix. See the smtpd_recipient_restrictions parameter
    # in postconf(5).
    # You can specify the list of "trusted" network addresses by hand
    # or you can let Postfix do it for you (which is the default).
    # By default (mynetworks_style = subnet), Postfix "trusts" SMTP
    # clients in the same IP subnetworks as the local machine.
    # On Linux, this does works correctly only with interfaces specified
    # with the "ifconfig" command.
    # Specify "mynetworks_style = class" when Postfix should "trust" SMTP
    # clients in the same IP class A/B/C networks as the local machine.
    # Don't do this with a dialup site - it would cause Postfix to "trust"
    # your entire provider's network. Instead, specify an explicit
    # mynetworks list by hand, as described below.
    # Specify "mynetworks_style = host" when Postfix should "trust"
    # only the local machine.
    #mynetworks_style = class
    #mynetworks_style = subnet
    #mynetworks_style = host
    # Alternatively, you can specify the mynetworks list by hand, in
    # which case Postfix ignores the mynetworks_style setting.
    # Specify an explicit list of network/netmask patterns, where the
    # mask specifies the number of bits in the network part of a host
    # address.
    # You can also specify the absolute pathname of a pattern file instead
    # of listing the patterns here. Specify type:table for table-based lookups
    # (the value on the table right-hand side is not used).
    mynetworks = 10.1.1.0/24, 192.168.1.0/24, 127.0.0.0/8
    #mynetworks = $config_directory/mynetworks
    #mynetworks = hash:/etc/postfix/network_table
    # The relay_domains parameter restricts what destinations this system will
    # relay mail to. See the smtpd_recipient_restrictions description in
    # postconf(5) for detailed information.
    # By default, Postfix relays mail
    # - from "trusted" clients (IP address matches $mynetworks) to any destination,
    # - from "untrusted" clients to destinations that match $relay_domains or
    # subdomains thereof, except addresses with sender-specified routing.
    # The default relay_domains value is $mydestination.
    # In addition to the above, the Postfix SMTP server by default accepts mail
    # that Postfix is final destination for:
    # - destinations that match $inet_interfaces or $proxy_interfaces,
    # - destinations that match $mydestination
    # - destinations that match $virtual_alias_domains,
    # - destinations that match $virtual_mailbox_domains.
    # These destinations do not need to be listed in $relay_domains.
    # Specify a list of hosts or domains, /file/name patterns or type:name
    # lookup tables, separated by commas and/or whitespace. Continue
    # long lines by starting the next line with whitespace. A file name
    # is replaced by its contents; a type:name table is matched when a
    # (parent) domain appears as lookup key.
    # NOTE: Postfix will not automatically forward mail for domains that
    # list this system as their primary or backup MX host. See the
    # permit_mx_backup restriction description in postconf(5).
    #relay_domains = $mydestination
    # INTERNET OR INTRANET
    # The relayhost parameter specifies the default host to send mail to
    # when no entry is matched in the optional transport(5) table. When
    # no relayhost is given, mail is routed directly to the destination.
    # On an intranet, specify the organizational domain name. If your
    # internal DNS uses no MX records, specify the name of the intranet
    # gateway host instead.
    # In the case of SMTP, specify a domain, host, hostort, [host]ort,
    # [address] or [address]ort; the form [host] turns off MX lookups.
    # If you're connected via UUCP, see also the default_transport parameter.
    #relayhost = $mydomain
    #relayhost = [gateway.my.domain]
    #relayhost = [mailserver.isp.tld]
    #relayhost = uucphost
    #relayhost = [an.ip.add.ress]
    # REJECTING UNKNOWN RELAY USERS
    # The relay_recipient_maps parameter specifies optional lookup tables
    # with all addresses in the domains that match $relay_domains.
    # mail for unknown relay users. This feature is off by default.
    # In the left-hand side, specify an @domain.tld wild-card, or specify
    # a [email protected] address.
    #relay_recipient_maps = hash:/etc/postfix/relay_recipients
    # INPUT RATE CONTROL
    # The in_flow_delay configuration parameter implements mail input
    # flow control. This feature is turned on by default, although it
    # still needs further development (it's disabled on SCO UNIX due
    # to an SCO bug).
    # A Postfix process will pause for $in_flow_delay seconds before
    # accepting a new message, when the message arrival rate exceeds the
    # message delivery rate. With the default 100 SMTP server process
    # limit, this limits the mail inflow to 100 messages a second more
    # than the number of messages delivered per second.
    # Specify 0 to disable the feature. Valid delays are 0..10.
    #in_flow_delay = 1s
    # ADDRESS REWRITING
    # The ADDRESS_REWRITING_README document gives information about
    # address masquerading or other forms of address rewriting including
    # username->Firstname.Lastname mapping.
    # ADDRESS REDIRECTION (VIRTUAL DOMAIN)
    # The VIRTUAL_README document gives information about the many forms
    # of domain hosting that Postfix supports.
    # "USER HAS MOVED" BOUNCE MESSAGES
    # See the discussion in the ADDRESS_REWRITING_README document.
    # TRANSPORT MAP
    # ALIAS DATABASE
    # The alias_maps parameter specifies the list of alias databases used
    # by the local delivery agent. The default list is system dependent.
    # On systems with NIS, the default is to search the local alias
    # database, then the NIS alias database. See aliases(5) for syntax
    # details.
    # If you change the alias database, run "postalias /etc/aliases" (or
    # wherever your system stores the mail alias file), or simply run
    # "newaliases" to build the necessary DBM or DB file.
    # It will take a minute or so before changes become visible. Use
    # "postfix reload" to eliminate the delay.
    #alias_maps = dbm:/etc/aliases
    #alias_maps = hash:/etc/postfix/aliases
    #alias_maps = hash:/etc/aliases, nis:mail.aliases
    #alias_maps = netinfo:/aliases
    # The alias_database parameter specifies the alias database(s) that
    # are built with "newaliases" or "sendmail -bi". This is a separate
    # configuration parameter, because alias_maps (see above) may specify
    # tables that are not necessarily all under control by Postfix.
    #alias_database = dbm:/etc/aliases
    #alias_database = dbm:/etc/mail/aliases
    #alias_database = hash:/etc/aliases
    #alias_database = hash:/etc/aliases, hash:/opt/majordomo/aliases
    # ADDRESS EXTENSIONS (e.g., user+foo)
    # The recipient_delimiter parameter specifies the separator between
    # user names and address extensions (user+foo). See canonical(5),
    # local(8), relocated(5) and virtual(5) for the effects this has on
    # aliases, canonical, virtual, relocated and .forward file lookups.
    # Basically, the software tries user+foo and .forward+foo before
    # trying user and .forward.
    #recipient_delimiter = +
    # DELIVERY TO MAILBOX
    # The home_mailbox parameter specifies the optional pathname of a
    # mailbox file relative to a user's home directory. The default
    # mailbox file is /var/spool/mail/user or /var/mail/user. Specify
    # "Maildir/" for qmail-style delivery (the / is required).
    #home_mailbox = Mailbox
    #home_mailbox = Maildir/
    # The mail_spool_directory parameter specifies the directory where
    # UNIX-style mailboxes are kept. The default setting depends on the
    # system type.
    #mail_spool_directory = /var/mail
    #mail_spool_directory = /var/spool/mail
    # The mailbox_command parameter specifies the optional external
    # command to use instead of mailbox delivery. The command is run as
    # the recipient with proper HOME, SHELL and LOGNAME environment settings.
    # Exception: delivery for root is done as $default_user.
    # Other environment variables of interest: USER (recipient username),
    # EXTENSION (address extension), DOMAIN (domain part of address),
    # and LOCAL (the address localpart).
    # Unlike other Postfix configuration parameters, the mailbox_command
    # parameter is not subjected to $parameter substitutions. This is to
    # make it easier to specify shell syntax (see example below).
    # Avoid shell meta characters because they will force Postfix to run
    # an expensive shell process. Procmail alone is expensive enough.
    # IF YOU USE THIS TO DELIVER MAIL SYSTEM-WIDE, YOU MUST SET UP AN
    # ALIAS THAT FORWARDS MAIL FOR ROOT TO A REAL USER.
    #mailbox_command = /some/where/procmail
    #mailbox_command = /some/where/procmail -a "$EXTENSION"
    # The mailbox_transport specifies the optional transport in master.cf
    # to use after processing aliases and .forward files. This parameter
    # has precedence over the mailbox_command, fallback_transport and
    # luser_relay parameters.
    # Specify a string of the form transport:nexthop, where transport is
    # the name of a mail delivery transport defined in master.cf. The
    # :nexthop part is optional. For more details see the sample transport
    # configuration file.
    # NOTE: if you use this feature for accounts not in the UNIX password
    # file, then you must update the "local_recipient_maps" setting in
    # the main.cf file, otherwise the SMTP server will reject mail for
    # non-UNIX accounts with "User unknown in local recipient table".
    #mailbox_transport = lmtp:unix:/file/name
    #mailbox_transport = cyrus
    # The fallback_transport specifies the optional transport in master.cf
    # to use for recipients that are not found in the UNIX passwd database.
    # This parameter has precedence over the luser_relay parameter.
    #fallback_transport = lmtp:unix:/file/name
    #fallback_transport = cyrus
    # The luser_relay parameter specifies an optional destination address
    # for unknown recipients. By default, mail for [email protected]$mydestination,
    # [email protected][$inet_interfaces] or [email protected][$proxy_interfaces] is returned
    # as undeliverable.
    # The following expansions are done on luser_relay: $user (recipient
    # username), $shell (recipient shell), $home (recipient home directory),
    # $recipient (full recipient address), $extension (recipient address
    # extension), $domain (recipient domain), $local (entire recipient
    # localpart), $recipient_delimiter. Specify ${name?value} or
    # ${name:value} to expand value only when $name does (does not) exist.
    # luser_relay works only for the default Postfix local delivery agent.
    # file, then you must specify "local_recipient_maps =" (i.e. empty) in
    #luser_relay = [email protected]
    #luser_relay = admin+$local
    # JUNK MAIL CONTROLS
    # The controls listed here are only a very small subset. The file
    # SMTPD_ACCESS_README provides an overview.
    # The header_checks parameter specifies an optional table with patterns
    # that each logical message header is matched against, including
    # headers that span multiple physical lines.
    # By default, these patterns also apply to MIME headers and to the
    # headers of attached messages. With older Postfix versions, MIME and
    # attached message headers were treated as body text.
    # For details, see "man header_checks".
    #header_checks = regexp:/etc/postfix/header_checks
    # FAST ETRN SERVICE
    # Postfix maintains per-destination logfiles with information about
    # deferred mail, so that mail can be flushed quickly with the SMTP
    # "ETRN domain.tld" command, or by executing "sendmail -qRdomain.tld".
    # See the ETRN_README document for a detailed description.
    # The fast_flush_domains parameter controls what destinations are
    # eligible for this service. By default, they are all domains that
    # this server is willing to relay mail to.
    #fast_flush_domains = $relay_domains
    # SHOW SOFTWARE VERSION OR NOT
    # The smtpd_banner parameter specifies the text that follows the 220
    # code in the SMTP server's greeting banner. Some people like to see
    # the mail version advertised. By default, Postfix shows no version.
    # You MUST specify $myhostname at the start of the text. That is an
    # RFC requirement. Postfix itself does not care.
    smtpd_banner = $myhostname ESMTP - Mail Server
    #smtpd_banner = $myhostname ESMTP $mail_name ($mail_version)
    smtpd_recipient_limit = 100
    smtpd_helo_required = yes
    strict_rfc821_envelopes = yes
    smtpd_sender_restrictions = reject_non_fqdn_sender, reject_unknown_sender_domain, reject_unauth_pipelining
    # PARALLEL DELIVERY TO THE SAME DESTINATION
    # How many parallel deliveries to the same user or domain? With local
    # delivery, it does not make sense to do massively parallel delivery
    # to the same user, because mailbox updates must happen sequentially,
    # and expensive pipelines in .forward files can cause disasters when
    # too many are run at the same time. With SMTP deliveries, 10
    # simultaneous connections to the same domain could be sufficient to
    # raise eyebrows.
    # Each message delivery transport has its XXX_destination_concurrency_limit
    # parameter. The default is $default_destination_concurrency_limit for
    # most delivery transports. For the local delivery agent the default is 2.
    #local_destination_concurrency_limit = 2
    #default_destination_concurrency_limit = 20
    # DEBUGGING CONTROL
    # The debug_peer_level parameter specifies the increment in verbose
    # logging level when an SMTP client or server host name or address
    # matches a pattern in the debug_peer_list parameter.
    debug_peer_level = 2
    # The debug_peer_list parameter specifies an optional list of domain
    # or network patterns, /file/name patterns or type:name tables. When
    # an SMTP client or server host name or address matches a pattern,
    # increase the verbose logging level by the amount specified in the
    # debug_peer_level parameter.
    #debug_peer_list = 127.0.0.1
    #debug_peer_list = some.domain
    # The debugger_command specifies the external command that is executed
    # when a Postfix daemon program is run with the -D option.
    # Use "command .. & sleep 5" so that the debugger can attach before
    # the process marches on. If you use an X-based debugger, be sure to
    # set up your XAUTHORITY environment variable before starting Postfix.
    debugger_command =
    PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin
    xxgdb $daemon_directory/$process_name $process_id & sleep 5
    # If you can't use X, use this to capture the call stack when a
    # daemon crashes. The result is in a file in the configuration
    # directory, and is named after the process name and the process ID.
    # debugger_command =
    # PATH=/bin:/usr/bin:/usr/local/bin; export PATH; (echo cont;
    # echo where) | gdb $daemon_directory/$process_name $process_id 2>&1
    # >$config_directory/$process_name.$process_id.log & sleep 5
    # Another possibility is to run gdb under a detached screen session.
    # To attach to the screen sesssion, su root and run "screen -r
    # <id_string>" where <id_string> uniquely matches one of the detached
    # sessions (from "screen -list").
    # PATH=/bin:/usr/bin:/sbin:/usr/sbin; export PATH; screen
    # -dmS $process_name gdb $daemon_directory/$process_name
    # $process_id & sleep 1
    # INSTALL-TIME CONFIGURATION INFORMATION
    # The following parameters are used when installing a new Postfix version.
    # sendmail_path: The full pathname of the Postfix sendmail command.
    # This is the Sendmail-compatible mail posting interface.
    #sendmail_path =
    # newaliases_path: The full pathname of the Postfix newaliases command.
    # This is the Sendmail-compatible command to build alias databases.
    #newaliases_path =
    # mailq_path: The full pathname of the Postfix mailq command. This
    # is the Sendmail-compatible mail queue listing command.
    #mailq_path =
    # setgid_group: The group for mail submission and queue management
    # commands. This must be a group name with a numerical group ID that
    # is not shared with other accounts, not even with the Postfix account.
    #setgid_group =
    # html_directory: The location of the Postfix HTML documentation.
    #html_directory =
    # manpage_directory: The location of the Postfix on-line manual pages.
    #manpage_directory =
    # sample_directory: The location of the Postfix sample configuration files.
    # This parameter is obsolete as of Postfix 2.1.
    #sample_directory =
    # readme_directory: The location of the Postfix README files.
    #readme_directory =
    permit_mynetworks,
    check_relay_domains
