ola pessoa l, to tentando instalar o gmailfs mas quando vou instalar o "fuse-python" requerido pelo mesmo obtenho o erro abaixo...
alguem tem uma soluçao pra mim ou alguma receita? ja perdi hrs e nao consigo mesmo...
obrigado
marcelo- slackware 10.1
[email protected]:/aptra/gmail/fuse-python# python setup.py build
running build
running build_py
running build_ext
building '_fusemodule' extension
gcc -pthread -fno-strict-aliasing -DNDEBUG -O3 -march=i486 -mcpu=i686 -fPIC -I/usr/include/python2.4 -c _fus uild/temp.linux-i686-2.4/_fusemodule.o
_fusemodule.c:321: warning: `struct statfs' declared inside parameter list
_fusemodule.c:321: warning: its scope is only this definition or declaration, which is probably not what you
_fusemodule.c: In function `statfs_func':
_fusemodule.c:342: error: dereferencing pointer to incomplete type
_fusemodule.c:343: error: dereferencing pointer to incomplete type
_fusemodule.c:344: error: dereferencing pointer to incomplete type
_fusemodule.c:345: error: dereferencing pointer to incomplete type
_fusemodule.c:346: error: dereferencing pointer to incomplete type
_fusemodule.c:347: error: dereferencing pointer to incomplete type
