Depois de desempacotar, 17,5MB de espaço em disco serão liberados.
Quer continuar? [S/n]S
Obtendo:1 ftp://ftp.br.debian.org testing/main libc6-dev 2.3.5-6 [2680kB]
Obtendo:2 ftp://ftp.br.debian.org testing/main locales 2.3.5-6 [4059kB]
Obtendo:3 ftp://ftp.br.debian.org testing/main libc6 2.3.5-6 [4931kB]
Obtendo:4 ftp://ftp.br.debian.org testing/main e2fslibs 1.38-2 [78,9kB]
Obtendo:5 ftp://ftp.br.debian.org testing/main e2fsprogs 1.38-2 [526kB]
Obtendo:6 ftp://ftp.br.debian.org testing/main libpq3 1:7.4.8-17 [59,4kB]
Obtendo:7 ftp://ftp.br.debian.org testing/main postgresql-common 27 [76,1kB]
Obtendo:8 ftp://ftp.br.debian.org testing/main postgresql-client-7.4 1:7.4.8-17 [440kB]
Obtendo:9 ftp://ftp.br.debian.org testing/main postgresql-7.4 1:7.4.8-17 [2620kB]
Obtendo:10 ftp://ftp.br.debian.org testing/main postgresql-client 7.5.11 [3254B]
Obtendo:11 ftp://ftp.br.debian.org testing/main postgresql 7.5.11 [5192B]
Baixados 15,5MB em 45s (340kB/s)
Preconfiguring packages ...
(Lendo banco de dados ... 30635 arquivos e diretórios atualmente instalados.)
Removendo kernel-image-2.4.27-1-386 ...
You are running a kernel (version 2.4.27-1-386) and attempting to remove
the same version. This is a potentially disastrous action. Not only
will /boot/vmlinuz-2.4.27-1-386 be removed, making it impossible to boot
it, (you will have to take action to change your boot loader to boot
a new kernel), it will also remove all modules under the directory
/lib/modules/2.4.27-1-386. Just having a copy of the kernel image is not
enough, you will have to replace the modules too.
I repeat, this is very dangerous. If at all in doubt, answer
no. If you know exactly what you are doing, and are prepared to
hose your system, then answer Yes.
Remove the running kernel image (not recommended) [No]? No
dpkg: erro processando kernel-image-2.4.27-1-386 (--remove):
subprocesso pre-removal script retornou código de saída de error 1
dpkg: initrd-tools: problemas de dependência, mas removendo assim mesmo conforme pedido:
kernel-image-2.4.27-1-386 depende de initrd-tools (>= 0.1.48).
Removendo initrd-tools ...
Erros foram encontrados durante processamento de:
E: Sub-process /usr/bin/dpkg returned an error code (1)
