- Profiles do Samba
Profiles do Samba
Amigos estou precisando de uma ajuda e nao estou achando onde estou errando...
Fiz o WinXP logar no dominio samba perfeitamente... acontece que os profiles estao sendo gravados no diretorio home do usuario.. eu queria
que fosse gravado localmente na maquina...
Como faço isso????
[global]
dos charset =
unix charset = iso8859-1
display charset = cp850
workgroup = REDE
server string = Conectiva Linux SMB Server
username map = /etc/samba/smbusers
log level = 2
log file = /var/log/samba/%m.log
max log size = 50
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
add machine script = /usr/sbin/adduser -n -r -g machines -c "Samba machine" -d /dev/null -s /bin/false %u
logon script = logon.bat
logon home = \\%N\netlogon
domain logons = Yes
os level = 100
preferred master = Yes
domain master = Yes
ldap ssl = no
idmap uid = 16777216-33554431
idmap gid = 16777216-33554431
recycle:maxsize = 80000000
recycle:repository = .recycle
recycle:noversions = .doc|.xls|.ppt
recycle:versions = false
recycle:touch = True
recycle:keeptree = True
recycle:exclude = *.tmp *.temp *.o *.obj ~$*
create mask = 0777
directory mask = 0777
vfs objects = recycle
[homes]
comment = Home Directories
read only = No
browseable = No
[pub]
comment = Diretorio Publico
path = /dados/pub
read only = No
force create mode = 0777
force security mode = 0777
force directory mode = 0777
guest ok = Yes
