- Sem acesso ao HDC e HDD
gente é o seguinte compilei o kernel 2.6.12-3 mas agora estou sem acesso a gravadora de dvd e cd no casos as unidades são IDE e seriam respectivamente os dispositivos hdc e hdd mas não existe os arquivos /dev/hdc e /dev/hdd
O comando dmesg dá a seguinte saída:
Linux version 2.6.12.3-dUKer ([email protected]) (gcc version 3.3.4) #4 Sun Nov 6 23:10:48 BRST 2005
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 0000000017ff0000 (usable)
BIOS-e820: 0000000017ff0000 - 0000000017ff8000 (ACPI data)
BIOS-e820: 0000000017ff8000 - 0000000018000000 (ACPI NVS)
BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
383MB LOWMEM available.
found SMP MP-table at 000fb820
On node 0 totalpages: 98288
DMA zone: 4096 pages, LIFO batch:1
Normal zone: 94192 pages, LIFO batch:31
HighMem zone: 0 pages, LIFO batch:1
DMI 2.3 present.
ACPI: RSDP (v000 AMI ) @ 0x000fa5a0
ACPI: RSDT (v001 AMIINT VIA_K7 0x00000010 MSFT 0x00000097) @ 0x17ff0000
ACPI: FADT (v001 AMIINT VIA_K7 0x00000011 MSFT 0x00000097) @ 0x17ff0030
ACPI: MADT (v001 AMIINT VIA_K7 0x00000009 MSFT 0x00000097) @ 0x17ff00c0
ACPI: DSDT (v001 VIA VIA_K7 0x00001000 MSFT 0x0100000d) @ 0x00000000
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 6:8 APIC version 16
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 3, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 18000000 (gap: 18000000:e6c00000)
Built 1 zonelists
Kernel command line: root=/dev/hdb1
mapped APIC to ffffd000 (fee00000)
mapped IOAPIC to ffffc000 (fec00000)
Initializing CPU#0
PID hash table entries: 2048 (order: 11, 32768 bytes)
Detected 1780.896 MHz processor.
Using tsc for high-res timesource
Console: colour VGA+ 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 385160k/393152k available (2347k kernel code, 7436k reserved, 1027k data, 328k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay loop... 3497.98 BogoMIPS (lpj=1748992)
Security Framework v1.0.0 initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0383fbff c1cbfbff 00000000 00000000 0000000000000000 00000000
CPU: After vendor identify, caps: 0383fbff c1cbfbff 00000000 00000000 00000000 00000000 00000000
CPU: CLK_CTL MSR was 6003d22f. Reprogramming to 2003d22f
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 256K (64 bytes/line)
CPU: After all inits, caps: 0383fbff c1cbfbff 00000000 00000020 00000000 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU: AMD Sempron(tm) 2500+ stepping 01
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
ENABLING IO-APIC IRQs
..TIMER: vector=0x31 pin1=2 pin2=-1
NET: Registered protocol family 16
EISA bus registered
PCI: PCI BIOS revision 2.10 entry at 0xfdaf1, last bus=1
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20050309
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
Boot video device is 0000:01:00.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: Power Resource [URP1] (off)
ACPI: Power Resource [URP2] (off)
ACPI: Power Resource [FDDP] (off)
ACPI: Power Resource [LPTP] (off)
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 *10 11 12 14 15)
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 10 devices
usbcore: registered new driver usbfs
usbcore: registered new driver hub
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
Machine check exception polling timer started.
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NTFS driver 2.1.22 [Flags: R/W DEBUG].
Initializing Cryptographic API
vga16fb: initializing
vga16fb: mapped to 0xc00a0000
Console: switching to colour frame buffer device 80x30
fb0: VGA16 VGA frame buffer device
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
Serial: 8250/16550 driver $Revision: 1.90 $ 54 ports, IRQ sharing enabled
ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
via-rhine.c:v1.10-LK1.2.0-2.6 June-10-2004 Written by Donald Becker
ACPI: PCI Interrupt 0000:00:12.0[A] -> GSI 23 (level, low) -> IRQ 23
PCI: Via IRQ fixup for 0000:00:12.0, from 11 to 7
eth0: VIA Rhine II at 0x1dc00, 00:11:5b:39:5b:c2, IRQ 23.
eth0: MII PHY found at address 1, status 0x786d advertising 05e1 Link 41e1.
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 0000:00:11.1
ACPI: PCI Interrupt 0000:00:11.1[A]: no GSI
PCI: Via IRQ fixup for 0000:00:11.1, from 255 to 15
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt8235 (rev 00) IDE UDMA133 controller on pci0000:00:11.1
ide0: BM-DMA at 0xfc00-0xfc07, BIOS settings: hda
MA, hdb
MA
ide1: BM-DMA at 0xfc08-0xfc0f, BIOS settings: hdc
MA, hdd
MA
Probing IDE interface ide0...
hda: ST310212A, ATA DISK drive
hdb: SAMSUNG SP0411N, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: HL-DT-STDVDRRW GWA-4161B, ATAPI CD/DVD-ROM drive
hdd: SAMSUNG CD-R/RW DRIVE SW-224B, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
Probing IDE interface ide2...
Probing IDE interface ide3...
Probing IDE interface ide4...
Probing IDE interface ide5...
hda: max request size: 128KiB
hda: 20005650 sectors (10242 MB) w/512KiB Cache, CHS=19846/16/63, UDMA(33)
hda: cache flushes not supported
hda: hda1 hda2 hda3
hdb: max request size: 1024KiB
hdb: 78242976 sectors (40060 MB) w/2048KiB Cache, CHS=16383/255/63, UDMA(33)
hdb: cache flushes supported
hdb: hdb1 hdb2
usbmon: debugs is not available
ohci_hcd: 2004 Nov 08 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
USB Universal Host Controller Interface driver v2.2
ACPI: PCI Interrupt 0000:00:10.0[A] -> GSI 21 (level, low) -> IRQ 21
PCI: Via IRQ fixup for 0000:00:10.0, from 11 to 5
uhci_hcd 0000:00:10.0: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller
uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:10.0: irq 21, io base 0x0000e400
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.1[B] -> GSI 21 (level, low) -> IRQ 21
uhci_hcd 0000:00:10.1: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller(#2)
uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:10.1: irq 21, io base 0x0000e800
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:10.2[C] -> GSI 21 (level, low) -> IRQ 21
uhci_hcd 0000:00:10.2: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller(#3)
uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:10.2: irq 21, io base 0x0000ec00
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
usb 1-2: new full speed USB device using uhci_hcd and address 2
usbcore: registered new driver aiptek
drivers/usb/input/aiptek.c: v1.5 (May-15-2004): Bryan W. Headley/Chris Atenasio
drivers/usb/input/aiptek.c: Aiptek HyperPen USB Tablet Driver (Linux 2.6.x)
usbcore: registered new driver hiddev
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.01:USB HID core driver
mice: PS/2 mouse device common for all mice
EISA: Probing bus 0 at eisa.0
EISA: Detected 0 cards.
NET: Registered protocol family 2
IP: routing cache hash table of 4096 buckets, 32Kbytes
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
ACPI wakeup devices:
PCI0 UAR1 USB1 USB2 USB3 EHCI AC9 MC9 ILAN SLPB
ACPI: (supports S0 S1 S4 S5)
EXT3-fs: INFO: recovery required on readonly filesystem.
EXT3-fs: write access will be enabled during recovery.
input: AT Translated Set 2 keyboard on isa0060/serio0
kjournald starting. Commit interval 5 seconds
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
VFS: Mounted root (ext3 filesystem) readonly.
Freeing unused kernel memory: 328k freed
Adding 377516k swap on /dev/hda3. Priority:-1 extents:1
EXT3 FS on hdb1, internal journal
Linux agpgart interface v0.101 (c) Dave Jones
SCSI subsystem initialized
ide-scsi is deprecated for cd burning! Use ide-cd and give dev=/dev/hdX as device
scsi0 : SCSI host adapter emulation for IDE ATAPI devices
Vendor: HL-DT-ST Model: DVDRRW GWA-4161B Rev: 1.00
Type: CD-ROM ANSI SCSI revision: 02
scsi1 : SCSI host adapter emulation for IDE ATAPI devices
Vendor: SAMSUNG Model: CD-R/RW SW-224B Rev: R205
NTFS volume version 3.1.
NTFS-fs error (device hda1): ntfs_check_logfile(): The two restart pages in $LogFile do not match.
NTFS-fs warning (device hda1): load_system_files(): Failed to load $LogFile. Will not be able to remount read-write. Mount in Windows.
EXT3 FS on hda2, internal journal
sr0: scsi3-mmc drive: 40x/40x writer cd/rw xa/form2 cdda tray
Uniform CD-ROM driver Revision: 3.20
Attached scsi CD-ROM sr0 at scsi0, channel 0, id 0, lun 0
sr1: scsi3-mmc drive: 40x/40x writer cd/rw xa/form2 cdda tray
Attached scsi CD-ROM sr1 at scsi1, channel 0, id 0, lun 0
eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
nvidia: module license 'NVIDIA' taints kernel.
ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 16
NVRM: loading NVIDIA Linux x86 NVIDIA Kernel Module 1.0-7676 Fri Jul 29 12:58:54 PDT 2005
via82xx: Assuming DXS channels with 48k fixed sample rate.
Please try dxs_support=1 or dxs_support=4 option
and report if it works on your machine.
ACPI: PCI Interrupt 0000:00:11.5[C] -> GSI 22 (level, low) -> IRQ 22
PCI: Via IRQ fixup for 0000:00:11.5, from 5 to 6
PCI: Setting latency timer of device 0000:00:11.5 to 64
ACPI: PCI Interrupt 0000:00:10.3[D] -> GSI 21 (level, low) -> IRQ 21
PCI: Via IRQ fixup for 0000:00:10.3, from 10 to 5
ehci_hcd 0000:00:10.3: VIA Technologies, Inc. USB 2.0
ehci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4
ehci_hcd 0000:00:10.3: irq 21, io mem 0xdfffff00
ehci_hcd 0000:00:10.3: USB 2.0 initialized, EHCI 1.00, driver 10 Dec 2004
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 6 ports detected
usb 1-2: USB disconnect, address 2
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
usb 1-2: new full speed USB device using uhci_hcd and address 3
shpchp: shpc_init : shpc_cap_offset == 0
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
agpgart: Detected VIA KM400/KM400A chipset
agpgart: AGP aperture is 64M @ 0xe0000000
Linux video capture interface: v1.00
/root/app/webcam/spca5xx-20051105/drivers/usb/spca5xx.c: USB SPCA5XX camera found. Type Creative Instant P0620
/root/app/webcam/spca5xx-20051105/drivers/usb/spca5xx.c: [spca5xx_probe:8213] Camera type JPEG
/root/app/webcam/spca5xx-20051105/drivers/usb/zc3xx.h: [zcxx_probeSensor:108] sensor answer1 170
/root/app/webcam/spca5xx-20051105/drivers/usb/zc3xx.h: [zc3xx_config:404] Find Sensor PAS106
/root/app/webcam/spca5xx-20051105/drivers/usb/spca5xx.c: [spca5xx_getcapability:2198] maxw 352 maxh 288 minw 176 minh 144
usbcore: registered new driver spca5xx
/root/app/webcam/spca5xx-20051105/drivers/usb/spca5xx.c: spca5xx driver 00.57.05 registered
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
Real Time Clock Driver v1.12
input: PC Speaker
input: ImPS/2 Generic Wheel Mouse on isa0060/serio1
ts: Compaq touchscreen protocol output
agpgart: Found an AGP 3.5 compliant device at 0000:00:00.0.
agpgart: Device is in legacy mode, falling back to 2.x
agpgart: Putting AGP V2 device at 0000:00:00.0 into 4x mode
agpgart: Putting AGP V2 device at 0000:01:00.0 into 4x mode
Como arrumar isso nem sei por onde começar direito plz ajudem....
aí o link com o arkivo de opções da conf. do kernel (/usr/srv/linux/.config)
http://geocities.yahoo.com.br/dukercs/c/config.txt
__________________________________
dUKer - Rodolpho
Linux User Número:
http://geocities.yahoo.com.br/dukercs/385557.png
Quer se tornar um linux user http://counter.li.org
gente eu já ouvi falar do comando makedev mas no slack 10.1 q uso parece q não tem alguém sabe como posso criar esses dispositivos ?
na verdade...........
na verdade o que aconteceu é que vc ativou a interface ide-scsi para as duas unidades, de forma que estas estao acessíveis somente via /dev/sr0 e /dev/sr1, é só usar estes dispositivos em vez do /dev/hdd e /dev/hdd que vai funcionar
