    jvdebian
    hello Guys!!
    Ai gente, eu estou tentando instalar o SARG no meu Servidor Debian, que por sinal ja esta rodando o SQUID, mas eu ja tentei Instalar o SARG usando apt-get e me uma mensagem de erro:
    ebserver:/tmp# apt-get -f install libc6
    Reading Package Lists... Done
    Building Dependency Tree... Done
    Sorry, libc6 is already the newest version.
    You might want to run `apt-get -f install' to correct these:
    Sorry, but the following packages have unmet dependencies:
    libdb1-compat: Depends: libc6 (>= 2.2.5-13) but 2.2.5-11.8 is to be installed
    sarg: Depends: libc6 (>= 2.3.2.ds1-21) but 2.2.5-11.8 is to be installed
    Depends: libgd2-noxpm (>= 2.0.33) but it is not going to be installed or
    libgd2-xpm (>= 2.0.33) but it is not installable
    Depends: ttf-bitstream-vera but it is not installable
    E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
    eu ja tentei baixar o pacote .Deb do sarg e instalar com o dpkg:
    webserver:/tmp# dpkg -i sarg_2.0.5.dfsg-1_i386.deb
    (Reading database ... 19486 files and directories currently installed.)
    Preparing to replace sarg 2.0.5.dfsg-1 (using sarg_2.0.5.dfsg-1_i386.deb) ...
    Unpacking replacement sarg ...
    dpkg: dependency problems prevent configuration of sarg:
    sarg depends on libc6 (>= 2.3.2.ds1-21); however:
    Version of libc6 on system is 2.2.5-11.8.
    sarg depends on libgd2-noxpm (>= 2.0.33) | libgd2-xpm (>= 2.0.33); however:
    Package libgd2-noxpm is not installed.
    Package libgd2-xpm is not installed.
    sarg depends on ttf-bitstream-vera; however:
    Package ttf-bitstream-vera is not installed.
    dpkg: error processing sarg (--install):
    dependency problems - leaving unconfigured
    Errors were encountered while processing:
    sarg
    webserver:/tmp#
    ja tentei baixar os pacotes tb ai continua dando erro de dependencias!!
    o q q e possivel de se fazer? por favor pessoal, manda uma luz ai!! brigadao!!!! t+
    wrochal
    Caro,
    Que versão do Debian você usa? E outra coisa porque você não usar o apt-get install sarg?
    Até,
  3. Pelo que entendi vc quer instalar o sarg mas ele tah pedindo a biblioteca libc6 >= 2.3.2.ds1-21 mas a sua versão eh 2.2.5-11.8. Daih vc tentou instalar a libc6 certo.
    Tente fazer isso:
    #apt-get install glibc
    (contém a libc6 e outras libs (é sempre bom ter atualizadas)
    daih de:
    #apt-get isntall sarg
    Lembrando que o sarg tem que ter instalado o apache com módulo php
    jvdebian
    Ae, qto a Versao do Debian, estou usando o 3.0.
    Eu jah tentei "apt-get install sarg" foi dai q tudo comecou tudo.
    ahh tb acabei de testar "apt-get install glibc" olha a resposta:
    webserver:~# apt-get install glibc
    Package glibc has no available version, but exists in the database.
    This typically means that the package was mentioned in a dependency and
    never uploaded, has been obsoleted or is not available with the contents
    of sources.list
    E: Package glibc has no installation candidate
    tentei "apt-get update" e depois "apt-get install glibc" e a mensagem continua a mesma dizendo q o pacote nao tem candidato para instalacao!!! acho q jah esta na sua versao mais nova!!!
    resumindo... ainda nao consegui instalar o sarg!!!!
    webserver:~# apt-get install sarg
    Sorry, sarg is already the newest version.
  5. Antes você tem que atualizar para Sarge, com:
    Código :
    # apt-get -f dist-upgrade
    Mas antes você tem que ter os repositórios no seu /etc/apt/sources.list
    Então você instala o SARG.
    Abraços!
  1. Erro na instalação do Red Hat 9
    Por luiz_nando no fórum Servidores de Rede
    Último Post: 03-03-2004, 06:17
  2. Erro na instalação do logrep para analisar Snort?
    Por Hacinn no fórum Segurança
    Último Post: 05-12-2003, 07:12
  3. Erro na instalação do modem!
    Respostas: 10
    Último Post: 01-12-2003, 13:52
  4. erro na instalação do postfix
    Último Post: 30-10-2003, 12:27
  5. msg de erro na instalacao do modulo Archive::Zip... o que eh
    Por fisicko no fórum Servidores de Rede
    Último Post: 15-08-2003, 14:09
