    thiagog
    Padrão gravando CD
    nao consigo gravar cd nenhum na minha gravadora
    #$ cdrecord -scanbus
    scsibus1:
    1,0,0 100) *
    1,1,0 101) 'HL-DT-ST' 'CD-RW GCE-8520B ' '1.00' Removable CD-ROM
    1,2,0 102) *
    1,3,0 103) *
    1,4,0 104) *
    1,5,0 105) *
    1,6,0 106) *
    1,7,0 107) *
    quando tento gravar da o seguinte ERRO: :toim:
    -sh-3.00# cdrecord -v speed=24 dev=1,1,0 -data /ebooks.iso
    cdrecord: No write mode specified.
    cdrecord: Asuming -tao mode.
    cdrecord: Future versions of cdrecord may have different drive dependent default s.
    cdrecord: Continuing in 5 seconds...
    Cdrecord-Clone 2.01-dvd (i686-pc-linux-gnu) Copyright (C) 1995-2004 Jörg Schilling
    Note: This version is an unofficial (modified) version with DVD support
    Note: and therefore may have bugs that are not present in the original.
    Note: Please send bug reports or support requests to http://bugzilla.redhat.com/bugzilla
    Note: The author of cdrecord should not be bothered with problems in this version.
    TOC Type: 1 = CD-ROM
    scsidev: '1,1,0'
    scsibus: 1 target: 1 lun: 0
    cdrecord: Success. Cannot open SCSI driver.
    cdrecord: For possible targets try 'cdrecord -scanbus'.
    cdrecord: For possible transport specifiers try 'cdrecord dev=help'.
    alguma sugestao ?
    meus dispositivos
    hda: SAMSUNG SV4012H, ATA DISK drive
    hdd: HL-DT-ST GCE-8520B, ATAPI CD/DVD-ROM drive
    hdd: ATAPI 40X CD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
    -sh-3.00#
    uso centos ;
    Linux srv01.domain.com.br 2.6.9-22.EL #1 Sat Oct 8 17:48:27 CDT 2005 i686 athlon i386 GNU/Linux
    valeus,
    Padrão gravando CD
    O problema é que você rodou o -scanbus e não definiu o dispositivo como um ide, dai ele assume como se fosse scsi.
    Faça o seguinte.
    Rode isso para procurar o gravador de cd
    Código :
    # cdrecord dev=ATAPI -scanbus
    Ele retornara algo do tipo
    Código :
            0,0,0     0) 'ASUS    ' 'CD-S500/A       ' '1.2D' Removable CD-ROM
            0,1,0     1) 'HL-DT-ST' 'CD-RW GCE-8400B ' '1.02' Removable CD-ROM
    No meu caso o gravador é 0,1,0
    Agora para gravar:
    Código :
    # cdrecord dev=ATAPI:0,1,0 speed=12 imagem.iso
    ssk
    Padrão gravando CD
    Boa Tarde,
    o seu gravador é SCSI ou IDE?
    se for IDE, você precisa ativar a emulação SCSI do kernel durante a inicialização.
    se utilizas o lilo como gerenciador de boot podes editar o arquivo lilo.conf (vi /etc/lilo.conf) e adicionar o parâmetro "hdc=ide-scsi", considerando que o seu gravador seja o MASTER na IDE Secudária, se não configure de acordo com o seu sistema "hd[abcd]=ide-scsi". E depois executar o comando 'lilo' para refletir a alteração na MBR.
    MAS CUIDADO! se você setar a emulação scsi para um hd ele não será mais montado.
    provavelmente isto deve resolver o seu problema
    Padrão gravando CD
    Citação Postado originalmente por ssk
    Boa Tarde,
    Cara não precisa mais ativar emulação scsi faz tempo, é so fazer o que o Skorpyon disse.
    falows
    thiagog
    Padrão gravando CD
    o meu gravador é IDE ; sinistro demais, tudo isso
    nossa q parto ; vou testar agora e ver no que vai dar.
    aproveitando a ajuda de voces, ..
    tem como gravar o cd via CLI (linha de comando) e deixar a midia em aberto para poder continuar gravando quando quiser?
    ou isso so pode ser feito via aplicativo X?
    ate mais,
    Padrão gravando CD
    É só acrescentar o argumento -multi.
    ex:
    Código :
     # cdrecord dev=ATAPI:0,1,0 speed=12 -multi imagem.iso
