- erro no virtual host
apachectl restart
Re-creating /etc/httpd/extramodules
Shutting down httpd-perl: [ OK ]
Starting httpd-perl: [ OK ]
Starting httpd2: httpd2: Could not determine the server's fully qualified domain name, using 127.0.0.1 for ServerName
[Mon Nov 14 10:47:49 2005] [error] VirtualHost _default_:443 -- mixing * ports and non-* ports with a NameVirtualHost address is not supported, proceeding with undefined results
[Mon Nov 14 10:47:49 2005] [warn] NameVirtualHost athlon2000.com.br:0 has no VirtualHosts
(98)Address already in use: make_sock: could not bind to address [::]:443
no listening sockets available, shutting down
Unable to open logs
[FALHOU]
[root@athlon2000 arquivos-de-conf]#
iptables
$iptables -A INPUT -i $ilocal -p tcp --dport 443 -j ACCEPT #sagu
$iptables -A FORWARD -i $ilocal -p tcp --dport 443 -j ACCEPT #sagu
$iptables -A INPUT -i $ilocal -p udp --dport 443 -j ACCEPT #sagu
$iptables -A FORWARD -i $ilocal -p udp --dport 443 -j ACCEPT #sagu
$iptables -A OUTPUT -i $ilocal -p tcp --dport 443 -j ACCEPT #sagu apache
$iptables -A OUTPUT -i $ilocal -p udp --dport 443 -j ACCEPT #sagu apache
resolv.conf
search MSHOME.NET local athlon2000 athlon2000.com.br
nameserver 127.0.0.1
nameserver 192.168.0.250
nameserver 192.168.0.254
nameserver 200.142.79.10 #silicom
nameserver 200.232.124.133 #silicom
# ppp temp entry
host
192.168.0.250 athlon2000.com.br
127.0.0.1 athlon2000 localhost
vhost.conf
NameVirtualHost 192.168.0.250
<VirtualHost 192.168.0.250>
ServerAdmin [email protected]
DocumentRoot /usr/local/sagu/html
ServerName www.athlon2000.com.br
# ErrorLog logs/host.some_domain.com-error_log
# CustomLog logs/host.some_domain.com-access_log common
</VirtualHost>
<VirtualHost athlon2000.com.br>
ServerName athlon2000.com.br
ServerAlias www.athlon2000.com.br
</VirtualHost>
NameVirtualHost *
<VirtualHost *>
ServerAdmin webmaster@localhost
DocumentRoot /usr/local/miolo/html
ServerName localhost
ErrorLog logs/miolo.develop.error_log
CustomLog logs/miolo.develop.access_log common
<Directory "/usr/local/miolo/html">
Options FollowSymLinks
AllowOverride All
Order allow,deny
Allow from all
</Directory>
</VirtualHost>
ServerName www.miolo.com.br
DirectoryIndex index.htm
#ErrorLog logs/miolo.develop.error_log
#CustomLog logs/miolo.develop.access_log common
<Directory /usr/local/miolo/html>
AllowOverride All
Order allow,deny
Allow from 192.168.0.250 192.168.0.254 192.168.0.1 192.168.0.2 192.168.0.3
</Directory>
