- Kde no conectiva 10
Kde no conectiva 10
Ae pessoal, como q tá?
Instalei a versão mínima do conectiva 10, e agora to querendo colocar o KDE , entao fiz:
#apt-get install kdebase
após a instação desse pacote, fiz o
#startX
mas da o seguinte erro:
# _XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6
# _XSERVTransOpen: transport open failed for
# inet6/HOST.DOMÍNIO.COM.BR:0
# _XSERVTransMakeAllCOTSServerListeners: failed to open listener for
# inet6
# XFree86 Version 4.4.0
# Release Date: 29 February 2004
# X Protocol Version 11, Revision 0, Release 6.6
# Build Operating System: Linux 2.6.12-12mdk-i686-up-4GB i686 [ELF]
# Current Operating System: Linux HOST.DOMINIO.COM.BR 2.6.5-
# 63077cl #1 Thu Jun 17 20:05:07 BRT 2004 i686
# Build Date: 21 September 2005
# Changelog Date: 04 March 2004
# Before reporting problems, check http://www.XFree86.Org/
# to make sure that you have the latest version.
# Module Loader present
# Markers: (--) probed, (**) from config file, (==) default setting,
# (++) from command line, (!!) notice, (II) informational,
# (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
# (==) Log file: "/var/log/XFree86.0.log", Time: Wed Nov 16 09:04:32
# 2005
# (EE) Unable to locate/open config file
# xf86AutoConfig: Primary PCI is 1:0:0
# Running "getconfig -X 40400000 -
# I /etc/X11,/usr/X11R6/etc/X11,/usr/X11R6/lib/modules,/usr/X11R6/lib/X
# 11/getconfig -v 0x10de -d 0x0185 -r 0xc1 -s 0x1682 -b 0x201a -c
# 0x0300"
# sh: line 1: getconfig: command not found
# (==) Using default built-in configuration (43 lines)
# (EE) Failed to load module "freetype" (module does not exist, 0)
# (EE) Failed to load module "fbdev" (module does not exist, 0)
# (EE) Failed to load module "vesa" (module does not exist, 0)
# (EE) Failed to load module "vga" (module does not exist, 0)
# (EE) No drivers available.
# Fatal server error:
# no screens found
# When reporting a problem related to a server crash, please send
# the full server output, not just the last messages.
# This can be found in the log file "/var/log/XFree86.0.log".
# Please report problems to [email protected].
# XIO: fatal IO error 104 (Connection reset by peer) on X server ":0.0"
# after 0 requests (0 known processed) with 0 events remaining.
Eu gostaria de saber se eu deixei algum pacote sem instalar, ou se realmente foi um problema mais sério.....
Valeu
X
Cara, vc tem que executar o comando xf86cfg -textmode para configurar os drivers de video, tipo de monitor, mouse, teclado, e outras coisas mais
tenta ai depois vc posta se deu certo.
espero que isso ajude.
