  1. Caros,
    estou tentando conectar no meu apache usando a porta 443 (SSL), mas nao estou tendo exito. Fui ver se a porta estava liberada para conexões usando o comando nmpa -sS ip_da_maquina:
    Starting nmap 3.81 ( http://www.insecure.org/nmap/ ) at 2005-11-16 22:23 BRST
    NET: Registered protocol family 17
    Interesting ports on astra.infojf.com.br (192.168.1.15):
    (The 1654 ports scanned but not shown below are in state: closed)
    PORT STATE SERVICE
    22/tcp open ssh
    53/tcp open domain
    80/tcp open http
    111/tcp open rpcbind
    113/tcp open auth
    139/tcp open netbios-ssn
    445/tcp open microsoft-ds
    977/tcp open unknown
    10000/tcp open snet-sensor-mgmt
    Nmap finished: 1 IP address (1 host up) scanned in 0.660 seconds
    Não tenho firewall configurado na minha maquina, como faço para liberrar a porta 443.
    Estou tendo dificuldades em conectar usando https, e por causa dessa porta estar fechada?
    lelinho
    estou tentando fazer a mesma coisa...
    ERROR
    The requested URL could not be retrieved
    While trying to retrieve the URL: login.live.com:443
    The following error was encountered:
    Access Denied.
    Access control configuration prevents your request from being allowed a
    olha meu squid.conf
    #Recommended minimum configuration:
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 901 # swat
    acl purge method PURGE
    acl CONNECT method CONNECT
    acl USERS_RESTRITOS proxy_auth_regex "/etc/squid/users_restritos"
    acl USERS_LIBERADOS proxy_auth_regex "/etc/squid/users_liberados"
    acl SITES_PERMITIDOS url_regex -i "/etc/squid/site_permitido"
    # Only allow cachemgr access from localhost
    http_access deny manager
    http_access deny purge
    # Deny requests to unknown ports
    http_access deny !Safe_ports
    # Deny CONNECT to other than SSL ports
    # INSERT YOUR OWN RULE(S) HERE TO ALLOW ACCESS FROM YOUR CLIENTS
    # And finally deny all other access to this proxy
    http_access allow localhost
    http_access allow USERS_RESTRITOS SITES_PERMITIDOS
    http_access allow USERS_LIBERADOS
    http_access deny all
    estou fazendo com o usem o squid autenticado, junto ao sarg...
    pras pessoas q deixo liberadas (http_access allow USERS_LIBERADOS) podem acessar https normal, mais as q deixo apenas com sites especificos (http_access allow USERS_RESTRITOS SITES_PERMITIDOS) nao conseguem navegar em qualquer site https sempre mensagem de erro blokeando...
  1. Não consigo liberar porta para jabber
    Por Dedao no fórum Servidores de Rede
    Respostas: 8
    Último Post: 10-05-2007, 15:59
  2. Liberar portas para o Emule
    Por regiscechet no fórum Servidores de Rede
    Último Post: 27-12-2006, 07:56
  3. Liberar porta para o VNC
    Por X-LOGAN no fórum Servidores de Rede
    Último Post: 04-11-2005, 15:10
  4. Liberar Porta para acesso, ,usando squid
    Por Mario_MPS no fórum Servidores de Rede
    Último Post: 17-02-2005, 17:49
  5. Liberar porta para cliente acessar a camera de casa
    Por bandlinux no fórum Servidores de Rede
    Último Post: 27-12-2004, 17:04
