    linuxfull
    Padrão Problema com conf DNS
    Pessoal é o seguinte. to configurando um novo dns (secundario) pra minha rede. Na realidade é para substituir um DNS secundario que ta rodando aqui. Configurei o named.conf e qdo starto o named ele inicia normalmente mas qdo vejo os log da as seguintes mensagens.
    Obs: os arquivos de configuração dos dominios serão criados automaticamente qdo for startado o named???
    Tipo
    abc.com.br
    Alguem pode me ajudar e dizer oque ta acontecendo
    Segue o Log:
    Nov 23 11:03:29 coiote named[8821]: loading configuration from '/etc/named.conf'
    Nov 23 11:03:29 coiote named[8821]: no IPv6 interfaces found
    Nov 23 11:03:29 coiote named[8821]: listening on IPv4 interface lo, 127.0.0.1#53
    Nov 23 11:03:29 coiote named[8821]: binding TCP socket: address in use
    Nov 23 11:03:29 coiote named[8821]: listening on IPv4 interface eth0, 200.148.135.190#53
    Nov 23 11:03:29 coiote named[8821]: listening on IPv4 interface eth0:0, 192.168.0.2#53
    Nov 23 11:03:29 coiote named[8821]: listening on IPv4 interface eth1, 192.168.1.100#53
    Nov 23 11:03:29 coiote named[8821]: couldn't add command channel 127.0.0.1#953: address in use
    Nov 23 11:03:29 coiote named[8821]: named.local:1: no TTL specified; using SOA MINTTL instead
    Nov 23 11:03:29 coiote named[8821]: zone 0.0.127.in-addr.arpa/IN: loaded serial 1997022700
    Nov 23 11:03:29 coiote named[8821]: running
    Nov 23 11:03:29 coiote named[8821]: transfer of 'firb.br/IN' from 200.148.135.186#53: failed while receiving responses: REFUSED
    Nov 23 11:03:29 coiote named[8821]: transfer of 'firb.br/IN' from 200.148.135.186#53: end of transfer
    Nov 23 11:03:29 coiote named[8821]: zone \032135.148.200.in-addr.arpa/IN: refresh: non-authoritative answer from master 200.148.135.186#53
    Nov 23 11:03:30 coiote named[8821]: transfer of 'vestibulareletronico.pro.br/IN' from 200.148.135.186#53: failed while receiving responses: REFUSED
    Nov 23 11:03:30 coiote named[8821]: transfer of 'vestibulareletronico.pro.br/IN' from 200.148.135.186#53: end of transfer
    Nov 23 11:03:30 coiote named[8821]: dumping master file: /sec/tmp-XXXXjpLJrl: open: file not found
    Nov 23 11:03:30 coiote named[8821]: transfer of 'siarsiacc.com.br/IN' from 200.148.135.186#53: failed while receiving responses: file not found
    Nov 23 11:03:30 coiote named[8821]: transfer of 'siarsiacc.com.br/IN' from 200.148.135.186#53: end of transfer
    Nov 23 11:03:53 coiote sshd[8832]: refused connect from 61.247.255.191
    Nov 23 11:04:09 coiote named[8795]: transfer of 'firb.br/IN' from 200.148.135.186#53: failed while receiving responses: REFUSED
    Nov 23 11:04:09 coiote named[8795]: transfer of 'firb.br/IN' from 200.148.135.186#53: end of transfer
    Nov 23 11:04:10 coiote named[8795]: dumping master file: /sec/tmp-XXXXpRQUoS: open: file not found
    Nov 23 11:04:10 coiote named[8795]: transfer of 'siarsiacc.com.br/IN' from 200.148.135.186#53: failed while receiving responses: file not found
    Nov 23 11:04:10 coiote named[8795]: transfer of 'siarsiacc.com.br/IN' from 200.148.135.186#53: end of transfer
    Nov 23 11:04:12 coiote named[8795]: zone \032135.148.200.in-addr.arpa/IN: refresh: non-authoritative answer from master 200.148.135.186#53
    Nov 23 11:04:16 coiote named[8821]: transfer of 'firb.br/IN' from 200.148.135.186#53: failed while receiving responses: REFUSED
    Nov 23 11:04:16 coiote named[8821]: transfer of 'firb.br/IN' from 200.148.135.186#53: end of transfer
    Nov 23 11:04:17 coiote named[8821]: dumping master file: /sec/tmp-XXXXbLdxF2: open: file not found
    Nov 23 11:04:17 coiote named[8821]: transfer of 'siarsiacc.com.br/IN' from 200.148.135.186#53: failed while receiving responses: file not found
    Nov 23 11:04:17 coiote named[8821]: transfer of 'siarsiacc.com.br/IN' from 200.148.135.186#53: end of transfer
    Nov 23 11:04:19 coiote named[8821]: zone \032135.148.200.in-addr.arpa/IN: refresh: non-authoritative answer from master 200.148.135.186#53
    Nov 23 11:04:22 coiote named[8795]: transfer of 'vestibulareletronico.pro.br/IN' from 200.148.135.186#53: failed while receiving responses: REFUSED
    Nov 23 11:04:22 coiote named[8795]: transfer of 'vestibulareletronico.pro.br/IN' from 200.148.135.186#53: end of transfer
    Nov 23 11:04:28 coiote named[8821]: transfer of 'vestibulareletronico.pro.br/IN' from 200.148.135.186#53: failed while receiving responses: REFUSED
    Nov 23 11:04:28 coiote named[8821]: transfer of 'vestibulareletronico.pro.br/IN' from 200.148.135.186#53: end of transfer
    Mostra pra gente como estão os arquivos de configuração dos dois servidores.
    linuxfull
    Segue ai o arquivo named.conf........os arquivos dos dominios ele vai criar automatico certo???
    O DNS primário está em win2kServer
    segue abaixo:
    options {
    directory "/var/named";
    dump-file "/var/named/dump/named_dump.db";
    statistics-file "/var/named/dump/named.stats";
    zone "." {
    type hint;
    file "named.ca";
    zone "0.0.127.in-addr.arpa" {
    type master;
    file "named.local";
    zone "firb.br" {
    type slave;
    file "/sec/firb.br";
    masters{
    200.XXX.XXX.XXX;
    zone "vestibulareletronico.pro.br" {
    type slave;
    file "/sec/vestibulareletronico.pro.br";
    masters{
    200.XXX.XXX.XXX;
    zone "siarsiacc.com.br" {
    type slave;
    file "/sec/siarsiacc.com.br";
    masters{
    200.XXX.XXX.XXX;
    zone " 135.148.200.in-addr.arpa" {
    type slave;
    file "/sec/firb.reverso";
    masters{
    200.XXX.XXX.XXX;
    linuxfull
    Pessoal.....ja resolvi o meu problema......
    Pra informação......é que no DNS primario que é no win2k vc pode deixar liberado pra atualização do secundario ou pode definir os ip que tem essa permissão....e nele não estava constando o meu novo ip, agora que coloquei ta zerado.....atualizado e rodando perfeitamente....
    Valeu......
    LinuxFull
    Padrão Re: Problema com conf DNS
    Citação Postado originalmente por linuxfull
    se for slave sim
