Ola Pessoal,
Tenho um servidor FDC3 + PostgreSql que e acessado por usuarios remotos.
Estou realizando testes com o Zebedee, pq preciso diminuir o trafego para
adiar um upgrade de banda, e tbem utilizar a criptografia (mas em segunda
fase), mas nao consigo de jeito nenhum estabelcer uma conexao (tunnel)
entre a minha maquina e o servidor, segue abaixo a configuracao do
Zebedee:
Servidor
verbosity 2 # Slightly more than basic messages
message "DEFAULT CONFIGURATION FILE -- EDIT BEFORE USE"
detached true # You will probably want this 'true' for normal
# use but I want to make sure that you see the
# preceding message if you haven't edited this.
server true # Yes, it's a server!
ipmode both # Operate in mixed TCP/UDP mode
compression zlib:9 # Allow maximum zlib compression
keylength 256 # Allow keys up to 256 bits
keylifetime 36000 # Shared keys last 10 hours
maxbufsize 16383 # Allow maximum possible buffer size
logfile '/var/log/zebedeeserver.log'
keygenlevel 2 # Generate maximum strength private keys
# include './server.key'
# checkidfile './clients.id'
redirect none
target 192.168.2.2:5432
Cliente (Minha Maquina)
verbosity 1 # Slightly more than basic messages
server false # Yes, it's a server!
tunnel 5432:192.168.2.2:5432
logfile 'c:/temp/zebedeeserver.log'
redirect none
target localhost
Se alguem puder me ajudar, ficarei grato... um grande abraco.
Citação
