olá galera galera..estou tendo muitas duvidas quanto a configuração do servidor freebsd usando velox..por ex:no meu ppp.conf tenho as seguintes linhas..por favor em ordem alguem poderia me dizer coo ficaria em orgens essas linhas..
# PPP Sample Configuration File
# Originally written by Toshiharu OHNO
# Simplified 5/14/1999 by [email protected]
# See /usr/share/examples/ppp/ for some examples
# $FreeBSD: src/etc/ppp/ppp.conf,v 1.8 2001/06/21 15:42:26 brian Exp $
default:
set log Phase Chat LCP IPCP CCP tun command
ident user-ppp VERSION (built COMPILATIONDATE)
# Ensure that "device" references the correct serial port
# for your modem. (cuaa0 = COM1, cuaa1 = COM2)
set device /dev/cuaa1
set speed 115200
set dial "ABORT BUSY ABORT NO\\sCARRIER TIMEOUT 5 \
\"\" AT OK-AT-OK ATE1Q0 OK \\dATDT\\T TIMEOUT 40 CONNECT"
set timeout 180 # 3 minute idle timer (the default)
enable dns # request DNS info (for resolv.conf)
papchap:
# edit the next three lines and replace the items in caps with
# the values which have been assigned by your ISP.
set phone PHONE_NUM
set authname USERNAME
set authkey PASSWORD
set ifaddr 10.0.0.1/0 10.0.0.2/0 255.255.255.0 0.0.0.0
add default HISADDR # Add a (sticky) default route
###############################fim##############
grato
leonardo
msn
[email protected]
