    Padrão Duvida sobre IP
    Gente peguei este artigo aqui em baixo de como fazer o DNS, minha dúvida e a seguinte, minha maquina tem o ip real, 222.243.345.344(ip ficticio) devo substituir o IP 192.168.0.1 q esta no artigo para o meu IP real??
    seudominio.com.br.db
    seudominio.com.br. IN SOA seuservidor.seudominio.com.br. root.seuservidor.seudominio.com.br. (
    950000
    86400
    3600
    3600000
    3600 )
    seudominio.usp.br. IN A 192.168.0.1
    seudominio.usp.br. IN NS seuservidor.seudominio.com.br.
    seudominio.usp.br. IN MX 5 seuservidordeemail.seudominio.com.br.
    www IN A 192.168.0.1
    seudominio.com.br.rev
    0.168.192.in-addr.arpa. IN SOA seuservidor.seudominio.com.br. root.seuservidor.seudominio.com.br. (
    950000
    86400
    3600
    3600000
    3600 )
    0.168.192.in-addr.arpa. IN NS seuservidor.seudominio.com.br.
    1 IN PTR seuservidor.seudominio.com.br.
    named.conf
    / generated by named-bootconf.pl
    options {
    directory "/var/named";
    * If there is a firewall between you and nameservers you want
    * to talk to, you might need to uncomment the query-source
    * directive below. Previous versions of BIND always asked
    * questions using port 53, but BIND 8.1 uses an unprivileged
    * port by default.
    version "[EF DNS SERVER]";
    query-source address * port 53;
    dump-file "/var/named/dump/named_dump.db";
    statistics-file "/var/named/dump/named.stats";
    allow-transfer { 192.168.0.1 ; };
    // memstatistics-file "/var/named/dump/named.memstats";
    // remove this next line if you want named to listen on
    // all available interfaces, or adjust add new ones as
    // you see fit
    listen-on { 192.168.0.1; 127.0.0.1; };
    // a caching only nameserver config
    zone "." {
    type hint;
    file "named.ca";
    zone "0.0.127.in-addr.arpa" {
    type master;
    file "named.local";
    zone "seudominio.com.br" {
    type master;
    file "seudominio.com.br.db";
    zone "0.168.192.in-addr.arpa" {
    type master;
    file "seudominio.com.br.rev";
    // a shared secret for the rndc tool
    // this key must be the same one that is in the
    // /etc/rndc.conf file
    key key_rndc {
    algorithm "hmac-md5";
    secret "k9uIPpgbI+lUL4MbjpGOlA==";
    // a control channel for the new rndc tool
    controls {
    inet 127.0.0.1 allow { localhost; } keys { key_rndc; };
    Padrão Re: Duvida sobre IP
    Sim vc deve colocar seu ip valido no lugar desse mascarado, e tambem o seu dominio real a ser configurado em todos os campos onde houver:
    seudominio
    Esse exemplo ai e so pra traduzir nomes na rede interna, usando o endereço 192.168.0.1 é claro !!!
    Valeu !!!
    Citação Postado originalmente por gatoseco
    seudominio
    Valeu !!!
    Olá ja fiz isso so que deu o seguinte erro
    couldn't open pid file '/var/run/named/named.pid': Permission denied
    ja dei chown root: /var/run/named/ e o erro continua???
    Citação Postado originalmente por uoquisala
    seudominio
    Valeu !!!
    Esqueci de dizer uso CONECTIVA 10
    cara..
    no conectiva 10 ele já vem configurado pra rodar em chroot
    o diretório de chroot é /var/named/var/named
    mas na hora q o programa roda seria como ele estivesse rodando em /var/named
    então cheque a árvore de diretórios dentro de /var/named e veja se todos os diretórios nocessários estão criados e com suas respsctivas permissões, dono e grupo..
    valew
