    guikeller
    Padrão Erro ao compilar driver. [ Intel537EP ]
    Olá, estou tentando compilar o driver do meu modem e estou
    tendo o seguinte erro, alguem poderia me ajudar?
    Código :
    [email protected]:/> su -
    Password:
    opensuse:~ # cd /opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1
    opensuse:/opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1 # make clean
    cd coredrv; make clean
    make[1]: Entering directory `/opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/
    coredrv'
    rm -f *.ko *.o *~ core
    make[1]: Leaving directory `/opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/c
    oredrv'
    rm -f *.o *.ko
    opensuse:/opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1 # make 537
       Module precompile check
       Current running kernel is: 2.6.13-15-default
       /lib/modules...   autoconf.h exists
    diff: /boot/vmlinuz.autoconf.h: No such file or directory
       autoconf.h matches running kernel
    diff: /boot/vmlinuz.version.h: No such file or directory
       version.h matches running kernel
    2.6.13-15-default
    coredrv'
    make -C /lib/modules/2.6.13-15-default/build SUBDIRS=/opt/modem/Intel537EP/intel
    -537EP_secure-2.60.80.1/coredrv modules
    make[2]: Entering directory `/usr/src/linux-2.6.13-15-obj/i386/default'
    make -C ../../../linux-2.6.13-15 O=../linux-2.6.13-15-obj/i386/default modules
      CC [M]  /opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/coredrv/coredrv.o
    gcc: ../inc: No such file or directory
    /opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/coredrv/coredrv.c:70: warning
    : type defaults to ‘int’ in declaration of ‘EXPORT_SYMBOL_NOVERS’
    : parameter names (without types) in function declaration
    : data definition has no type or storage class
    /opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/coredrv/coredrv.c: In functio
    n ‘softcore_init_struct’:
    /opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/coredrv/coredrv.c:336: warnin
    g: assignment from incompatible pointer type
    n ‘open’:
    /opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/coredrv/coredrv.c:394: warnin
    g: ‘pm_register’ is deprecated (declared at /usr/src/linux-2.6.13-15/include/lin
    ux/pm.h:107)
    n ‘close’:
    /opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/coredrv/coredrv.c:416: warnin
    g: ‘pm_unregister’ is deprecated (declared at /usr/src/linux-2.6.13-15/include/l
    inux/pm.h:112)
    n ‘hamproc_write’:
    /opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/coredrv/coredrv.c:660: warnin
    g: ignoring return value of ‘copy_from_user’, declared with attribute warn_unuse
    d_result
    /opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/coredrv/coredrv.c: At top lev
    el:
    /opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/coredrv/coredrv.c:754: warnin
    g: initialization from incompatible pointer type
    /opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/coredrv/coredrv.c:755: warnin                                           g: initialization from incompatible pointer type
    /opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/coredrv/coredrv.c: In functio                                           n ‘kScheduleDPC’:
    /opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/coredrv/coredrv.c:861: error:                                            implicit declaration of function ‘pm_access’
    /opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/coredrv/coredrv.c: In functio                                           n ‘dspdrv_CommRamISR’:
    /opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/coredrv/coredrv.c:877: warnin                                           g: function declaration isn’t a prototype
    make[5]: *** [/opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/coredrv/coredrv                                           .o] Error 1
    make[4]: *** [_module_/opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/coredrv                                           ] Error 2
    make[3]: *** [modules] Error 2
    make[2]: *** [modules] Error 2
    make[2]: Leaving directory `/usr/src/linux-2.6.13-15-obj/i386/default'
    make[1]: *** [537core_26] Error 2
    make[1]: Leaving directory `/opt/modem/Intel537EP/intel-537EP_secure-2.60.80.1/c                                           oredrv'
    2.6.13-15-default
    Failed to build driver
    Obrigado.
    2.6.13-15-default
    nao sei c essas duas chegam a interferir em alguma coisa, mas parece q tem uns erros de sintaxe dentro do codigo do coredrv.c
    nunca fui muito bom nisso... mas veja no README o que ele precisa para funcionar, as vezes pode ser alguma dependencia que esteja faltando, somente assim fica muito vago de dar certeza de algo.... esses drivers sao meio fo...
    guikeller
    Olá, estou com a discussão aqui:
    http://www.kuruminlinux.com.br/comun...ic.php?t=63115
    Já consegui grandes avanços..
    Quem poder olhar o andamento dela e tentar ajudar..
    Obrigado.
