    Rafael1986
    Padrão Erro na instalação do qmail
    Estou instalando o qmail, e na hora de criar os certificados aparece a seguinte mensagem de erro:
    [email protected]:/usr/src/qmail/qmail-1.03# make cert
    openssl req -new -x509 -nodes \
    -out /var/qmail/control/servercert.pem -days 366 \
    -keyout /var/qmail/control/servercert.pem
    Generating a 1024 bit RSA private key
    writing new private key to '/var/qmail/control/servercert.pem'
    You are about to be asked to enter information that will be incorporated
    into your certificate request.
    What you are about to enter is what is called a Distinguished Name or a DN.
    There are quite a few fields but you can leave some blank
    For some fields there will be a default value,
    If you enter '.', the field will be left blank.
    Country Name (2 letter code) [AU]:BR
    State or Province Name (full name) [Some-State]:SP
    Locality Name (eg, city) []:são paulo
    Organization Name (eg, company) [Internet Widgits Pty Ltd]:sapo.com.br
    Organizational Unit Name (eg, section) []:mail
    Common Name (eg, YOUR name) []:mail.sapo.com.br
    Email Address []:[email protected]
    chmod 640 /var/qmail/control/servercert.pem
    chown qmaild.qmail /var/qmail/control/servercert.pem
    ln -s /var/qmail/control/servercert.pem /var/qmail/control/clientcert.pem
    ln: `/var/qmail/control/clientcert.pem': File exists
    make: *** [cert] Error 1
    ja tentei trocar o endereço, o dominio e tudu mais... mas nu mfoi =(
    wrochal
    Caro,
    remova esses dois arquivo e compile novamente:
    rm -Rf /var/qmail/control/servercert.pem /var/qmail/control/clientcert.pem
    no dir do qmail execute:
    make clean
    E depois compile do zero.
    falou,
