    omaximo
    Padrão Compilação de PHP em Mandriva 2006.0 Free
    Olá amigos..
    Preciso compilar o php com suporte a Firebird, porém está ocorrendo o seguinte erro:
    [email protected] php512]# ./configure --with-apxs2filter=/usr/sbin/apxs --with-interbase=/opt/firebird --program-prefix= --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --sysconfdir=/etc --datadir=/usr/share --includedir=/usr/include --libdir=/usr/lib --libexecdir=/usr/libexec --localstatedir=/var --with-ttf --with-xml --with-zlib --with-mysql=shared,/usr
    loading cache ./config.cache
    checking for Cygwin environment... no
    checking for mingw32 environment... no
    checking for egrep... grep -E
    checking for a sed that does not truncate output... /bin/sed
    checking host system type... i686-pc-linux-gnu
    checking target system type... i686-pc-linux-gnu
    checking for gcc... gcc
    checking whether the C compiler (gcc ) works... yes
    checking whether the C compiler (gcc ) is a cross-compiler... no
    checking whether we are using GNU C... yes
    checking whether gcc accepts -g... yes
    checking whether gcc and cc understand -c and -o together... yes
    checking how to run the C preprocessor... gcc -E
    checking for AIX... no
    checking whether ln -s works... yes
    checking if compiler supports -R... no
    checking if compiler supports -Wl,-rpath,... yes
    checking for re2c... no
    configure: warning: You will need re2c 0.9.11 or later if you want to regenerate PHP parsers.
    checking for gawk... gawk
    checking for bison... no
    checking for byacc... no
    checking for bison version... invalid
    configure: warning: bison versions supported for regeneration of the Zend/PHP parsers: 1.28 1.35 1.75 1.875 2.0 2.1 (found: none).
    checking for flex... lex
    checking for yywrap in -ll... no
    checking lex output file root... ./configure: line 3246: lex: command not found
    configure: error: cannot find output from lex; giving up
    [[email protected] php512]#
    o que pode estar causando isso?
    Antecipadamente meus agradecimentos pela(s) ajuda(s).
    eyglys
    Padrão abra o arquivo de configuração
    Ao que percebi, ele apresenta um erro em:
    Abra o configure e vá até a linha 3246, verifique se existe um comando lex. Muito provavelmente terá uma chamada ao programa lex, que na sua máquina não existe.
    Pessa a um amigo que tenha uma distribuição linux qualquer, que lhe passe esse programa, e instale em sua máquina, então prossiga a instalação.
