    Padrão problemas em conectar no linux com o cisco 2500
    Saldações pessoal,
    to com um problema aqui, que e o seguinte o cisco conecta e navega blz no windows mas nao conecta no linux
    o lnik e da telemar e a conf co routewr e
    seriaal0 200.195.xxx.xxx masc 255.255.255.252
    e a ethernet0 200.149.xx.xx masc 255.255.255.248
    route 0.0.0.0 0.0.0.0 200.195.0.xxx
    podem me ajudar???
    Padrão Re: problemas em conectar no linux com o cisco 2500
    Seguinte voce tem a faixa 200.149.xxx.xxx pra voce certo?? Nao pos esse ip como ip invalido. Fora isso posta a saida do running config e o estado das interfaces, alem disso no linux de um ping no roteador e um traceroute under-linux.org poste os resultados aqui tb.
    falows
    ai o running-config
    Router#show running-config
    Building config
    Current configuration:
    version 11.1
    no service pad
    service udp-small-servers
    service tcp-small-servers
    hostname Router
    interface Ethernet0
    ip address 200.149.10.xxx
    255.255.255.248
    interface Serial0
    ip address 200.195.0.xxx
    255.255.255.252
    encapsulation ppp
    bandwidth 256
    interface Serial1
    no ip address
    shutdown
    interface Serial2
    no ip address
    shutdown
    interface Serial3
    no ip address
    shutdown
    no ip classless
    ip route 0.0.0.0 0.0.0.0 200.195.0.xxx
    line con 0
    line aux 0
    line vty 0 4
    login
    end
    agora as interfaces
    Router#show interfaces
    Ethernet0 is up, line protocol is up
    Hardware is Lance, address is 0000.0c75.d1ba (bia 0000.0c75.d1ba)
    Internet address is 200.149.10.xxx/29
    MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, rely 255/255, load 1/255
    Encapsulation ARPA, loopback not set, keepalive set (10 sec)
    ARP type: ARPA, ARP Timeout 04:00:00
    Last input 00:00:44, output 00:00:00, output hang never
    Last clearing of "show interface" counters never
    Queueing strategy: fifo
    Output queue 0/40, 0 drops; input queue 0/75, 0 drops
    5 minute input rate 0 bits/sec, 0 packets/sec
    5 minute output rate 0 bits/sec, 1 packets/sec
    18742 packets input, 4051541 bytes, 0 no buffer
    Received 727 broadcasts, 0 runts, 0 giants
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
    0 input packets with dribble condition detected
    36284 packets output, 16692903 bytes, 0 underruns
    765 output errors, 1 collisions, 3 interface resets
    0 babbles, 0 late collision, 5 deferred
    765 lost carrier, 0 no carrier
    0 output buffer failures, 0 output buffers swapped out
    Serial0 is up, line protocol is up
    Hardware is HD64570
    Internet address is 200.195.0.xxx/30
    MTU 1500 bytes, BW 256 Kbit, DLY 20000 usec, rely 255/255, load 1/255
    Encapsulation PPP, loopback not set, keepalive set (10 sec)
    LCP Open
    Listen: cdp
    Open: ipcp
    Last input 00:00:00, output 00:00:00, output hang never
    Input queue: 0/75/0 (size/max/drops); Total output drops: 0
    Queueing strategy: weighted fair
    Output queue: 0/64/0 (size/threshold/drops)
    Conversations 0/12 (active/max active)
    Reserved Conversations 0/0 (allocated/max allocated)
    5 minute input rate 0 bits/sec, 1 packets/sec
    5 minute output rate 0 bits/sec, 0 packets/sec
    430405 packets input, 37133372 bytes, 0 no buffer
    Received 276 broadcasts, 0 runts, 0 giants
    307 input errors, 305 CRC, 0 frame, 0 overrun, 0 ignored, 13 abort
    412992 packets output, 24543653 bytes, 0 underruns
    0 output errors, 0 collisions, 28 interface resets
    1 carrier transitions
    DCD=up DSR=up DTR=up RTS=up CTS=up
    agora vou pegar o trace
    So uma coisa esse ip 200 da ethernet como ele chega na ethernet já que voce nao pos nenhuma entrada pra ele no roteador.
    falows
    ai o ping e o trace
    #ping 200.149.10.xxx
    PING 200.149.10.XXX (200.149.10.XXX): 56 Data bytes
    64 dytes from 200.149.10.xxx: icmp_seq=0 ttl=255 time=992.4 ms
    64 dytes from 200.149.10.xxx: icmp_seq=0 ttl=255 time=1.8 ms
    64 dytes from 200.149.10.xxx: icmp_seq=0 ttl=255 time=1.9 ms
    [2]+ Stopped
    agora o trace
    #traceroute under-linux.org
    traceroute: unknown host under-linux.org
    ve se pode me ajudar
    e ai rui deu uma olhada ? oque pode esta acomtecendo?
    Cara ja olhou se o dns no seu linux ta ok??? olha o /etc/resolv.conf e ve se os servidores de dns la tao ok e pingando.
    falows
    PS: desculpa a demora mas nao tinah recebido mensagem de resposta do topico
    tudo bem,
    os dns estão ok no etc/res...
    desconfio que seja no roteador o problema
    Cara acho dificil ser o cisco, tenta dar um traceroute ou um ping nesse ip 200.255.5.4 se funcionar de certeza o problema eh de dns
    falows
    habilite o "ip classless"
    e o ip routing esta ativo?
    da um "show protocols" para mim aí.
    considerando somente problemas no seu router nesse post, quanto ao problema ser no seu cliente tente fazer o traceroute em um ip qualquer na internet e mostre o resultado que ai da para dizer rapido onde é.
    caro amigo o ip rout.. esta ativo
    como habilito este "ip classless" ???
    e no meu route
    da os comandos q eu pedi para voce, mostra o seu show run tbm
    Cara posta o traceroute pro ip que eu pedi pra voce.
    falows
    bom, funciona assim pro ip classless... ativa assim oh:
    > enable
    # conf term
    (conf)# ip classless
    ^Z
    da um show ip route também para gente dar uma olhada.
    e ae cara deu certo??
    falows
    qe nada, ruy, o problema continua, funciona no rwindows mas nao funciona no linux
    Que nada, ruy, continua com o mesmo problema funciona no rwindows mas nao funciona no linux
    Moderador Avatar de Bruno
    Nov 2002
    Guarapuava-PR
    como que é no windows funciona
    então vamus la
    do linux pingue o seu roteador
    do linux ping 200.160.2.3
    do linux ping registro.br
    e deixe seu /etc/resolv.conf em 127.0.0.1 para que o linux resolva os nomes
    Citação Postado originalmente por fasmaia
    se funciona no Rwindows é lógico que tem que funcionar no linux ....
    faça um teste por eliminação ...
    no console do linux você pinga a lan do roteaor ...? a wan do roteador ...? a wan da operadora ...? um ip externo ...? se sim ....:
    você pinga um nome ...?
    se não ...reveja seu dns ...
    veja até em que nó vocÊ pinga ...pois só dai é que podemos ver qual a bromca ....
    só pra desencargo de conciência ...
    digita no linux ...
    rout -n
    e verifica se a rota default tá setada para o roteador ....
    valew
