    Padrão Dual Headd
    Pessoal, tenho duas placas de video, sendo uma Nvidia Gxforce 5700 (AGP) e uma matrox MGA 2064W (PCI).
    Seguindo o tutorial do guia do hardware
    http://www.guiadohardware.net/artigos/267/
    Tentei fazer um dual head aqui no meu Debian Sarge, mas não funcionou...
    Segue a configuração do X:
    Section "ServerLayout"
    Identifier "Default Layout"
    Screen 0 "Screen0" 0 0
    Screen 1 "Screen1" RightOf "Screen0"
    InputDevice "Generic Keyboard"
    InputDevice "Configured Mouse"
    EndSection
    Section "ServerFlags"
    Option "Xinerama" "true"
    Option "AllowMouseOpenFail" "true"
    EndSection
    Section "Files"
    # local font server
    # if the local font server has problems, we can fall back on these
    FontPath "unix/:7100"
    FontPath "/usr/lib/X11/fonts/misc"
    FontPath "/usr/lib/X11/fonts/cyrillic"
    FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
    FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
    FontPath "/usr/lib/X11/fonts/Type1"
    FontPath "/usr/lib/X11/fonts/CID"
    FontPath "/usr/lib/X11/fonts/Speedo"
    FontPath "/usr/lib/X11/fonts/100dpi"
    FontPath "/usr/lib/X11/fonts/75dpi"
    EndSection
    Section "Module"
    Load "bitmap"
    Load "dbe"
    Load "ddc"
    Load "extmod"
    Load "freetype"
    Load "glx"
    Load "int10"
    Load "record"
    Load "speedo"
    Load "type1"
    Load "vbe"
    EndSection
    Section "InputDevice"
    Identifier "Generic Keyboard"
    Driver "keyboard"
    Option "CoreKeyboard"
    Option "XkbRules" "xfree86"
    Option "XkbModel" "abnt2"
    Option "XkbLayout" "br"
    Option "XkbVariant" "abnt2"
    EndSection
    Identifier "Configured Mouse"
    Driver "mouse"
    Option "CorePointer"
    Option "Device" "/dev/input/mice"
    Option "Protocol" "ImPS/2"
    Option "Emulate3Buttons" "true"
    Option "ZAxisMapping" "4 5"
    EndSection
    Section "Monitor"
    Identifier "Monitor Genérico"
    HorizSync 30.0 - 96.0
    VertRefresh 50.0 - 160.0
    Option "DPMS"
    EndSection
    Section "Monitor"
    Identifier "Monitor1"
    HorizSync 40 - 90.0
    VertRefresh 60.0 - 90
    # Option "DPMS"
    EndSection
    Section "Device"
    Identifier "Placa de Vídeo Genérica"
    Driver "nvidia"
    EndSection
    Section "Device"
    Identifier "Card1"
    Driver "mga"
    VendorName "Matrox Graphics, Inc."
    BoardName "MGA 2064W [Millennium]"
    BusID "PCI:3:2:0"
    EndSection
    Section "Screen"
    Identifier "Screen0"
    Device "Placa de Vídeo Genérica"
    Monitor "Monitor Genérico"
    DefaultDepth 24
    SubSection "Display"
    Depth 1
    Modes "1600x1200" "1280x1024" "1280x960" "1152x864" "1024x768" "800x600" "640x480"
    EndSubSection
    Depth 4
    EndSubSection
    Depth 8
    EndSubSection
    Depth 15
    EndSubSection
    Depth 16
    EndSubSection
    Depth 24
    EndSubSection
    EndSection
    Section "Screen"
    Identifier "Screen1"
    Device "Card1"
    Monitor "Monitor1"
    DefaultDepth 1
    Depth 1
    Modes "1280x1024" "1280x960" "1152x864" "1024x768" "800x600" "640x480"
    EndSubSection
    Depth 4
    EndSubSection
    Depth 8
    EndSubSection
    Depth 15
    EndSubSection
    Depth 16
    EndSubSection
    Depth 24
    EndSubSection
    EndSection
    E nesta configuração ele me retorna o seguinte erro:
    Given depth (1) is not supported by this driver
    Se eu retiro esta opção de DefaultDepth ele Não inicia nenhuma das duas placas, bagunçãndo a tela.
    Padrão Re: Dual Headd
    issu que da usar material de fora da underlinux heheeh
    ve meu artigo ae, a conf tem uns detalhes diferentes que podem ta fazendo diferenca no teu caso
    https://under-linux.org/wiki/Tutoriais/X/2monitores
    e ve isso aqui tb:
    https://under-linux.org/component/op.../topic,27459.0
    e tira fora esses depth abaixo de 8, vc nao vai querer usar 8bits de cores neh? :P
    Valeu Ice,
    Hoje a noite vou brincar com isto, ai eu posto o resultado.
    []'s
    P.s.: Aprendi a lição, não fujo mais do Under.
    Mais uma coisa...
    Eu não recebi a notificação de resposta.
    da uma entrada no seu perfil denovo e veja se esta habilitado tudo certinho
    Ice, quanto a receber as notificações, está tudo normalizado, realmente faltava algumas opções.
    E quanto aos monitores perfeito! Eu realmente não queria o desktop esticado, já que meu monitores possuem tamanhos diferentes (17 e 15), então criei dois desktops.
    Da configuração acima eu alterei o defaultdepth para 24 no screen1 e retirei o ServerFlags.
    Funcionou perfeitamente.
    heheh
    exatamente o mesmo caso de qdo fiz o artigo, 1 17 e 1 15
