    Padrão squid nao deixa navegar!Resolvido!!!
    Ola pessoal
    Estou tentando configurar o squid no CL 10 aqui mas tá dificil!!!
    quando tento navegar aparece a seguinte msg!!!
    ERROR
    The requested URL could not be retrieved
    While trying to retrieve the URL: /
    The following error was encountered:
    Invalid URL
    Some aspect of the requested URL is incorrect. Possible problems:
    Missing or incorrect access protocol (should be `http://'' or similar)
    Missing hostname
    Illegal double-escape in the URL-Path
    Illegal character in hostname; underscores are not allowed
    Your cache administrator is [email protected].
    aparece isso no /var/log/access.log
    [[email protected] squid]# tail -f /var/log/squid/access.log
    1139852005.037 0 192.168.5.0 TCP_DENIED/400 1465 GET /bandalarga/ - NONE/- text/html
    1139852683.881 9 192.168.5.0 TCP_DENIED/400 1443 GET / - NONE/- text/html
    1139852685.512 0 192.168.5.0 TCP_DENIED/400 1443 GET / - NONE/- text/html
    1139927317.066 0 192.168.5.91 TCP_DENIED/400 1439 GET / - NONE/- text/html
    1139927334.503 0 192.168.5.91 TCP_DENIED/400 1439 GET / - NONE/- text/html
    1139927342.863 0 192.168.5.91 TCP_DENIED/400 1439 GET / - NONE/- text/html
    1139927375.978 0 192.168.5.91 TCP_DENIED/400 1439 GET / - NONE/- text/html
    1139927377.672 0 192.168.5.91 TCP_DENIED/400 1439 GET / - NONE/- text/html
    1139927379.665 0 192.168.5.91 TCP_DENIED/400 1439 GET / - NONE/- text/html
    1139928489.430 0 192.168.5.91 TCP_DENIED/400 1463 GET / - NONE/- text/html
    aqui o squid.conf
    http_port 192.168.5.1:3128
    cache_mem 96 MB
    maximum_object_size 4096 KB
    cache_dir ufs /var/cache/squid 1024 16 256
    cache_log /var/log/squid/cache.log
    cache_store_log none
    emulate_httpd_log off
    #client_netmask 255.255.255.0
    #Default:
    refresh_pattern . 0 20% 4320
    #Defaults:
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 21 443 563 70 210 1025-65535
    acl CONNECT method CONNECT
    acl minharede src 192.168.5.0/255.255.255.0
    #Default configuration:
    http_access deny manager
    http_access deny !Safe_ports
    http_access allow minharede
    http_access deny all
    cache_mgr [email protected]
    cache_effective_user proxy
    cache_effective_group proxy
    visible_hostname servidor.xxxx.com.br
    o q está bloqueando a navegacao???
    Padrão Re: squid nao deixa navegar!!!
    ninguem sabe p q está acontecendo isso???
    Dá uma força ai pessoal
    lobo
    >>>>>>>>>>>http_access deny all<<<<<<<<<<<
    cara eu acho que essa regra aqui esta bloqueando tudo... vc deveria por ela como allow pra ver o que dar,, ou entao colocar ela como allow minharede. testa ai pra ver
    Problema resolvido!!!
    Apaguei tudo e configurei novamente, agora está funcionando
    mas valeu pela força!!!
